[PATCH] RTEMS: Use strict DWARF-2 on ARM, PowerPC, SPARC
Tue Jun 18 17:32:23 UTC 2013
Please post to gcc-patches.
I would like to hear their opinion before committing it.
On 6/18/2013 6:58 AM, Sebastian Huber wrote:
> Some debuggers do not cope with the new DWARF3/4 debug format introduced
> with GCC 4.8.  Default to strict DWARF-2 on ARM, PowerPC and SPARC for
> now.
> This patch should be committed to GCC 4.8 and 4.9.
> gcc/ChangeLog
> 2013-06-18  Sebastian Huber  <sebastian.huber at embedded-brains.de>
> 	* config/rtems.c: New.
> 	* config.gcc (*-*-rtems*): Set extra_objs.
> 	* config/rtems.h (rtems_override_options): Declare.
> 	(RTEMS_OVERRIDE_OPTIONS): Define.
> 	* config/t-rtems (rtems.o): New.
> 	* config/arm/rtems-eabi.h (SUBTARGET_OVERRIDE_OPTIONS): Define.
> 	* config/rs6000/rtems.h (SUBSUBTARGET_OVERRIDE_OPTIONS): Define.
> 	* config/sparc/rtemself.h (SUBTARGET_OVERRIDE_OPTIONS): Define.
>   gcc/config.gcc              |    1 +
>   gcc/config/arm/rtems-eabi.h |    3 +++
>   gcc/config/rs6000/rtems.h   |    3 +++
>   gcc/config/rtems.c          |   37 +++++++++++++++++++++++++++++++++++++
>   gcc/config/rtems.h          |    4 ++++
>   gcc/config/sparc/rtemself.h |    3 +++
>   gcc/config/t-rtems          |    4 ++++
>   7 files changed, 55 insertions(+), 0 deletions(-)
>   create mode 100644 gcc/config/rtems.c
> diff --git a/gcc/config.gcc b/gcc/config.gcc
> index 1a0be50..6394551 100644
> --- a/gcc/config.gcc
> +++ b/gcc/config.gcc
> @@ -734,6 +734,7 @@ case ${target} in
>       yes) thread_file='rtems' ;;
>     esac
>     extra_options="${extra_options} rtems.opt"
> +  extra_objs="rtems.o"
>     use_gcc_stdint=wrap
>   *-*-uclinux*)
> diff --git a/gcc/config/arm/rtems-eabi.h b/gcc/config/arm/rtems-eabi.h
> index 77fcf1a..a7ccdae 100644
> --- a/gcc/config/arm/rtems-eabi.h
> +++ b/gcc/config/arm/rtems-eabi.h
> @@ -27,3 +27,6 @@
>   	builtin_assert ("system=rtems");	\
>   	TARGET_BPABI_CPP_BUILTINS();    	\
>       } while (0)
> +#undef SUBTARGET_OVERRIDE_OPTIONS
> +#define SUBTARGET_OVERRIDE_OPTIONS RTEMS_OVERRIDE_OPTIONS
> diff --git a/gcc/config/rs6000/rtems.h b/gcc/config/rs6000/rtems.h
> index b910b5e..cf53592 100644
> --- a/gcc/config/rs6000/rtems.h
> +++ b/gcc/config/rs6000/rtems.h
> @@ -34,6 +34,9 @@
>     while (0)
> +#undef SUBSUBTARGET_OVERRIDE_OPTIONS
> +#define SUBSUBTARGET_OVERRIDE_OPTIONS RTEMS_OVERRIDE_OPTIONS
>   #undef CPP_OS_DEFAULT_SPEC
>   #define CPP_OS_DEFAULT_SPEC "%(cpp_os_rtems)"
> diff --git a/gcc/config/rtems.c b/gcc/config/rtems.c
> new file mode 100644
> index 0000000..4250ba3
> --- /dev/null
> +++ b/gcc/config/rtems.c
> @@ -0,0 +1,37 @@
> +/* Common RTEMS target definitions for GNU compiler.
> +   Copyright (C) 2013 Free Software Foundation, Inc.
> +This file is part of GCC.
> +GCC is free software; you can redistribute it and/or modify it under
> +the terms of the GNU General Public License as published by the Free
> +Software Foundation; either version 3, or (at your option) any later
> +version.
> +GCC is distributed in the hope that it will be useful, but WITHOUT ANY
> +WARRANTY; without even the implied warranty of MERCHANTABILITY or
> +FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License
> +for more details.
> +You should have received a copy of the GNU General Public License
> +along with GCC; see the file COPYING3.  If not see
> +<http://www.gnu.org/licenses/>.  */
> +#include "config.h"
> +#include "system.h"
> +#include "coretypes.h"
> +#include "target.h"
> +#include "tm.h"
> +void
> +rtems_override_options (void)
> +  /* Use strict DWARF-2 unless specifically selected.  This is a
> +     workaround for a lack of tool support.  */
> +  if (!global_options_set.x_dwarf_strict)
> +    dwarf_strict = 1;
> +  if (!global_options_set.x_dwarf_version)
> +    dwarf_version = 2;
> diff --git a/gcc/config/rtems.h b/gcc/config/rtems.h
> index 4d94f82..8ea97fe 100644
> --- a/gcc/config/rtems.h
> +++ b/gcc/config/rtems.h
> @@ -43,3 +43,7 @@ along with GCC; see the file COPYING3.  If not see
>    -lc -lgcc --end-group %{!qnolinkcmds: -T linkcmds%s}}}"
>   #define TARGET_POSIX_IO
> +/* Do RTEMS specific parts of TARGET_OPTION_OVERRIDE.  */
> +extern void rtems_override_options (void);
> +#define RTEMS_OVERRIDE_OPTIONS rtems_override_options ()
> diff --git a/gcc/config/sparc/rtemself.h b/gcc/config/sparc/rtemself.h
> index 7a69dfa..2ee939c 100644
> --- a/gcc/config/sparc/rtemself.h
> +++ b/gcc/config/sparc/rtemself.h
> @@ -29,5 +29,8 @@ along with GCC; see the file COPYING3.  If not see
>     while (0)
>   /* Use the default */
>   #undef LINK_GCC_C_SEQUENCE_SPEC
> diff --git a/gcc/config/t-rtems b/gcc/config/t-rtems
> index baa00d8..5a8e88a 100644
> --- a/gcc/config/t-rtems
> +++ b/gcc/config/t-rtems
> @@ -1,2 +1,6 @@
>   # RTEMS always has limits.h.
>   LIMITS_H_TEST = true
> +rtems.o: $(srcdir)/config/rtems.c $(CONFIG_H) $(SYSTEM_H) coretypes.h \
> +	$(TARGET_H) $(TM_H)
> +	$(COMPILER) -c $(ALL_COMPILERFLAGS) $(ALL_CPPFLAGS) $(INCLUDES) $<
