[rtems commit] Added in_cksum_sparc. h to optimize IP checksum calculations for SPARC.
Ralf Corsepius
ralf.corsepius at rtems.org
Thu Jun 20 09:14:53 UTC 2013
On 06/19/2013 03:16 PM, Joel Sherrill wrote:
> Module: rtems
> Branch: master
> Commit: 1f4ee306d3ab326a84d0bf74ad6afdedaaa435f8
> Changeset: http://git.rtems.org/rtems/commit/?id=1f4ee306d3ab326a84d0bf74ad6afdedaaa435f8
> Author: Jiri Gaisler <jiri at gaisler.se>
> Date: Sun Jun 16 00:13:41 2013 +0200
> Added in_cksum_sparc.h to optimize IP checksum calculations for SPARC.
> cpukit/libnetworking/netinet/in_cksum.c | 4 +
> cpukit/libnetworking/netinet/in_cksum_sparc.h | 308 +++++++++++++++++++++++++
> 2 files changed, 312 insertions(+), 0 deletions(-)
> diff --git a/cpukit/libnetworking/netinet/in_cksum.c b/cpukit/libnetworking/netinet/in_cksum.c
> index ec7e49c..ff25ad6 100644
> --- a/cpukit/libnetworking/netinet/in_cksum.c
> +++ b/cpukit/libnetworking/netinet/in_cksum.c
> @@ -61,6 +61,10 @@
> #include "in_cksum_nios2.h"
> +#elif (defined(__GNUC__) && defined(__sparc))
> +#include "in_cksum_sparc.h"
> #else
I am having several issues with this patch:
a) Has this code been tested with/checked against sparc64-rtems4.11
toolchains?
I haven't tried to check which code paths are being used with the
sparc64 and hardly won't have a possibility to check in near future, so
this question could be a red herring.
b) This code should use __sparc__ instead of __sparc.
__sparc is a pre-POSIX anachronism, is still supported by GCC but
actually should not be used anymore.
Ralf
