[PATCH 2/5] bsps: Add fatal errors for shared console driver
Thu Jun 20 10:06:09 UTC 2013
 c/src/lib/libbsp/shared/console.c               |   22 ++++++++--------------
 c/src/lib/libbsp/shared/console_select.c        |    3 ++-
 c/src/lib/libbsp/shared/include/generic-fatal.h |   10 +++++++++-
 3 files changed, 19 insertions(+), 16 deletions(-)
diff --git a/c/src/lib/libbsp/shared/console.c b/c/src/lib/libbsp/shared/console.c
index b3c3d75..7aba7ac 100644
--- a/c/src/lib/libbsp/shared/console.c
+++ b/c/src/lib/libbsp/shared/console.c
@@ -16,13 +16,13 @@
 #include <bsp.h>
+#include <bsp/generic-fatal.h>
 #include <rtems/libio.h>
 #include <assert.h>
 #include <termios.h>
 #include <rtems/termiostypes.h>
-#include <rtems/error.h>  /* rtems_panic */
 #include <libchip/serial.h>
 #include "console_private.h"
@@ -48,7 +48,7 @@ static void console_initialize_pointers(void)
   Console_Port_Count = Console_Configuration_Count;
   Console_Port_Tbl   = malloc( Console_Port_Count * sizeof( console_tbl * ) );
   if (Console_Port_Tbl == NULL)
-    rtems_panic("No memory for console pointers");
+    bsp_generic_fatal( BSP_GENERIC_FATAL_CONSOLE_NO_MEMORY_0 );
   for (i=0 ; i < Console_Port_Count ; i++)
     Console_Port_Tbl[i] = &Console_Configuration_Ports[i];
@@ -75,8 +75,7 @@ void console_register_devices(
    *  register devices.
   if ( console_initialized ) {
-    printk( "Attempt to register console devices after driver initialized\n" );
-    rtems_fatal_error_occurred( 0xdead0001 );
+    bsp_generic_fatal( BSP_GENERIC_FATAL_CONSOLE_MULTI_INIT );
@@ -89,14 +88,12 @@ void console_register_devices(
   if ( Console_Port_Tbl == NULL ) {
-    printk( "Unable to allocate pointer table for registering console devices\n" );
-    rtems_fatal_error_occurred( 0xdead0002 );
+    bsp_generic_fatal( BSP_GENERIC_FATAL_CONSOLE_NO_MEMORY_1 );
   Console_Port_Data  = calloc( Console_Port_Count, sizeof( console_data ) );
   if ( Console_Port_Data == NULL ) {
-    printk( "Unable to allocate data table for console devices\n" );
-    rtems_fatal_error_occurred( 0xdead0003 );
+    bsp_generic_fatal( BSP_GENERIC_FATAL_CONSOLE_NO_MEMORY_2 );
@@ -257,8 +254,7 @@ rtems_device_driver console_initialize(
     console_initialize_pointers();
+      bsp_generic_fatal( BSP_GENERIC_FATAL_CONSOLE_NO_MEMORY_3 );
@@ -293,8 +289,7 @@ rtems_device_driver console_initialize(
       if (port->sDeviceName != NULL) {
         status = rtems_io_register_name( port->sDeviceName, major, minor );
         if (status != RTEMS_SUCCESSFUL) {
-          printk( "Unable to register %s\n",  port->sDeviceName );
-          rtems_fatal_error_occurred(status);
+          bsp_generic_fatal( BSP_GENERIC_FATAL_CONSOLE_REGISTER_DEV_0 );
@@ -305,8 +300,7 @@ rtems_device_driver console_initialize(
 #endif
         status = rtems_io_register_name( "dev/console", major, minor );
-          printk( "Unable to register /dev/console\n" );
+          bsp_generic_fatal( BSP_GENERIC_FATAL_CONSOLE_REGISTER_DEV_1 );
diff --git a/c/src/lib/libbsp/shared/console_select.c b/c/src/lib/libbsp/shared/console_select.c
index 8578a5d..4803a8f 100644
--- a/c/src/lib/libbsp/shared/console_select.c
+++ b/c/src/lib/libbsp/shared/console_select.c
@@ -19,6 +19,7 @@
 #include <bsp.h>
 #include <assert.h>
@@ -71,7 +72,7 @@ static rtems_device_minor_number bsp_First_Available_Device( void )
    *  Error No devices were found.  We will want to bail here.
-  rtems_fatal_error_occurred(RTEMS_IO_ERROR);
+  bsp_generic_fatal(BSP_GENERIC_FATAL_CONSOLE_NO_DEV);
 void bsp_console_select(void)
diff --git a/c/src/lib/libbsp/shared/include/generic-fatal.h b/c/src/lib/libbsp/shared/include/generic-fatal.h
index 4edf467..ec2dfb6 100644
--- a/c/src/lib/libbsp/shared/include/generic-fatal.h
+++ b/c/src/lib/libbsp/shared/include/generic-fatal.h
@@ -27,7 +27,15 @@ extern "C" {
 typedef enum {
   BSP_GENERIC_FATAL_EXCEPTION_INITIALIZATION,
   BSP_GENERIC_FATAL_INTERRUPT_INITIALIZATION,
-  BSP_GENERIC_FATAL_SPURIOUS_INTERRUPT
+  BSP_GENERIC_FATAL_SPURIOUS_INTERRUPT,
+  BSP_GENERIC_FATAL_CONSOLE_MULTI_INIT,
+  BSP_GENERIC_FATAL_CONSOLE_NO_MEMORY_0,
+  BSP_GENERIC_FATAL_CONSOLE_NO_MEMORY_1,
+  BSP_GENERIC_FATAL_CONSOLE_NO_MEMORY_2,
+  BSP_GENERIC_FATAL_CONSOLE_NO_MEMORY_3,
+  BSP_GENERIC_FATAL_CONSOLE_REGISTER_DEV_0,
+  BSP_GENERIC_FATAL_CONSOLE_REGISTER_DEV_1,
+  BSP_GENERIC_FATAL_CONSOLE_NO_DEV
 } bsp_generic_fatal_code;
 static inline void bsp_generic_fatal( bsp_generic_fatal_code code )
1.7.7
