globaledf
Sree Harsha Konduri
sreehars at buffalo.edu
Fri Jun 21 19:30:24 UTC 2013
I do have auto tools in my Path. After i do configure with
--enable-maintainer-mode
i cant see the Makefile.in refreshing, or new headers being included.
So i ran bootstrap with -c to clear all the auto tools generated files. Now
when i re run bootstrap with -p only preinstall.am gets generated and after
configure with --enable-maintainer-mode there is no Makefile.in generated?
Thanks,
Harsha
On Fri, Jun 21, 2013 at 6:05 AM, Ralf Corsepius <ralf.corsepius at rtems.org>wrote:
> On 06/21/2013 03:07 AM, Gedare Bloom wrote:
>> Cc:rtems-devel
>> When modifying the build system i.e. Makefile.am files, you need to
>> rerun the bootstrap script and maybe with the -p flag if you add new
>> header files. Run bootstrap in the nearest directory to the modified
>> Makefile.am that contains a configure.ac <http://configure.ac> file.
>> Then recompile rtems.
> Make sure to have RTEMS autoconf and automake in $PATH,
> then pass --enable-maintainer-mode to configure
> then running make will automatically take care about this in most cases.
> Ralf
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130621/9152da93/attachment.html>
