globaledf
Sree Harsha Konduri
sreehars at buffalo.edu
Sat Jun 22 10:47:50 UTC 2013
Hello,
As disscussed earlier in the week, i have a GlobalEDF scheduler template
with the same functionality of the simplesmp scheduler.
I've tested it with some of the smp tests using rtems-testing.
In order to test with rtems-schedsim do i have to configure rtems-schedsim
again from scratch? since there are changes to the cpukit with added header
files.
Thanks,
Harsha
On Fri, Jun 21, 2013 at 3:38 PM, Joel Sherrill <Joel.Sherrill at oarcorp.com>wrote:
> You have added a .h file. You need to run bootstrap -p and bootstrap in cpukit.
> Do that followed by a build from scratch and see if it helps
> Sree Harsha Konduri <sreehars at buffalo.edu> wrote:
> I do have auto tools in my Path. After i do configure with --enable-maintainer-mode
> i cant see the Makefile.in refreshing, or new headers being included.
> So i ran bootstrap with -c to clear all the auto tools generated files.
> Now when i re run bootstrap with -p only preinstall.am gets generated and
> after configure with --enable-maintainer-mode there is no Makefile.in
> generated?
> Thanks,
> Harsha
> On Fri, Jun 21, 2013 at 6:05 AM, Ralf Corsepius <ralf.corsepius at rtems.org>wrote:
>> On 06/21/2013 03:07 AM, Gedare Bloom wrote:
>>> Cc:rtems-devel
>>> When modifying the build system i.e. Makefile.am files, you need to
>>> rerun the bootstrap script and maybe with the -p flag if you add new
>>> header files. Run bootstrap in the nearest directory to the modified
>>> Makefile.am that contains a configure.ac <http://configure.ac> file.
>>> Then recompile rtems.
>> Make sure to have RTEMS autoconf and automake in $PATH,
>> then pass --enable-maintainer-mode to configure
>> then running make will automatically take care about this in most cases.
>> Ralf
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130622/bc8e947a/attachment.html>
