[PATCH 1/4] modify the atomic API to be compatible with C11 stdatomic.h
WeiY
wei.a.yang at gmail.com
Sat Jun 22 13:24:39 UTC 2013
cpukit/score/cpu/arm/rtems/score/cpuatomic.h | 1 +
cpukit/score/include/rtems/score/atomic.h | 80 +++----
.../score/include/rtems/score/genericatomicops.h | 240 ++++++++++----------
.../score/include/rtems/score/genericcpuatomic.h | 21 +-
cpukit/score/inline/rtems/score/atomic.inl | 80 +++----
5 files changed, 217 insertions(+), 205 deletions(-)
diff --git a/cpukit/score/cpu/arm/rtems/score/cpuatomic.h b/cpukit/score/cpu/arm/rtems/score/cpuatomic.h
index 227b3ce..5680c3c 100644
--- a/cpukit/score/cpu/arm/rtems/score/cpuatomic.h
+++ b/cpukit/score/cpu/arm/rtems/score/cpuatomic.h
@@ -29,6 +29,7 @@ extern "C" {
#if !defined(RTEMS_SMP)
#include <rtems/score/genericatomicops.h>
#else
+#include <rtems/score/genericstdatomicops.h>
#endif
#ifdef __cplusplus
diff --git a/cpukit/score/include/rtems/score/atomic.h b/cpukit/score/include/rtems/score/atomic.h
index 3b62cb1..a2126be 100644
--- a/cpukit/score/include/rtems/score/atomic.h
+++ b/cpukit/score/include/rtems/score/atomic.h
@@ -56,23 +56,23 @@ typedef enum {
* a type of Atomic_Memory_barrier @a memory_barrier. The @a memory_barrier
* shall not be ATOMIC_RELEASE_BARRIER.
-RTEMS_INLINE_ROUTINE Atomic_Int _Atomic_Load_int(
+RTEMS_INLINE_ROUTINE unsigned int _Atomic_Load_int(
volatile Atomic_Int *address,
Atomic_Memory_barrier memory_barrier
-RTEMS_INLINE_ROUTINE Atomic_Long _Atomic_Load_long(
+RTEMS_INLINE_ROUTINE unsigned long _Atomic_Load_long(
volatile Atomic_Long *address,
-RTEMS_INLINE_ROUTINE Atomic_Pointer _Atomic_Load_ptr(
+RTEMS_INLINE_ROUTINE uintptr_t _Atomic_Load_ptr(
volatile Atomic_Pointer *address,
-RTEMS_INLINE_ROUTINE Atomic_Int32 _Atomic_Load_32(
+RTEMS_INLINE_ROUTINE uint32_t _Atomic_Load_32(
volatile Atomic_Int32 *address,
-RTEMS_INLINE_ROUTINE Atomic_Int64 _Atomic_Load_64(
+RTEMS_INLINE_ROUTINE uint64_t _Atomic_Load_64(
volatile Atomic_Int64 *address,
@@ -84,27 +84,27 @@ RTEMS_INLINE_ROUTINE Atomic_Int64 _Atomic_Load_64(
RTEMS_INLINE_ROUTINE void _Atomic_Store_int(
- Atomic_Int value,
+ unsigned int value,
RTEMS_INLINE_ROUTINE void _Atomic_Store_long(
- Atomic_Long value,
+ unsigned long value,
RTEMS_INLINE_ROUTINE void _Atomic_Store_ptr(
- Atomic_Pointer value,
+ uintptr_t value,
RTEMS_INLINE_ROUTINE void _Atomic_Store_32(
- Atomic_Int32 value,
+ uint32_t value,
RTEMS_INLINE_ROUTINE void _Atomic_Store_64(
- Atomic_Int64 value,
+ uint64_t value,
@@ -114,27 +114,27 @@ RTEMS_INLINE_ROUTINE void _Atomic_Store_64(
RTEMS_INLINE_ROUTINE void _Atomic_Fetch_add_int(
- Atomic_Int value,
RTEMS_INLINE_ROUTINE void _Atomic_Fetch_add_long(
RTEMS_INLINE_ROUTINE void _Atomic_Fetch_add_ptr(
+ uintptr_t value,
RTEMS_INLINE_ROUTINE void _Atomic_Fetch_add_32(
+ uint32_t value,
RTEMS_INLINE_ROUTINE void _Atomic_Fetch_add_64(
+ uint64_t value,
@@ -144,27 +144,27 @@ RTEMS_INLINE_ROUTINE void _Atomic_Fetch_add_64(
RTEMS_INLINE_ROUTINE void _Atomic_Fetch_sub_int(
- Atomic_Int value,
RTEMS_INLINE_ROUTINE void _Atomic_Fetch_sub_long(
RTEMS_INLINE_ROUTINE void _Atomic_Fetch_sub_ptr(
+ uintptr_t value,
RTEMS_INLINE_ROUTINE void _Atomic_Fetch_sub_32(
+ uint32_t value,
RTEMS_INLINE_ROUTINE void _Atomic_Fetch_sub_64(
+ uint64_t value,
@@ -174,27 +174,27 @@ RTEMS_INLINE_ROUTINE void _Atomic_Fetch_sub_64(
RTEMS_INLINE_ROUTINE void _Atomic_Fetch_or_int(
- Atomic_Int value,
RTEMS_INLINE_ROUTINE void _Atomic_Fetch_or_long(
RTEMS_INLINE_ROUTINE void _Atomic_Fetch_or_ptr(
+ uintptr_t value,
RTEMS_INLINE_ROUTINE void _Atomic_Fetch_or_32(
+ uint32_t value,
RTEMS_INLINE_ROUTINE void _Atomic_Fetch_or_64(
+ uint64_t value,
@@ -204,27 +204,27 @@ RTEMS_INLINE_ROUTINE void _Atomic_Fetch_or_64(
RTEMS_INLINE_ROUTINE void _Atomic_Fetch_and_int(
- Atomic_Int value,
RTEMS_INLINE_ROUTINE void _Atomic_Fetch_and_long(
RTEMS_INLINE_ROUTINE void _Atomic_Fetch_and_ptr(
+ uintptr_t value,
RTEMS_INLINE_ROUTINE void _Atomic_Fetch_and_32(
+ uint32_t value,
RTEMS_INLINE_ROUTINE void _Atomic_Fetch_and_64(
+ uint64_t value,
@@ -237,32 +237,32 @@ RTEMS_INLINE_ROUTINE void _Atomic_Fetch_and_64(
RTEMS_INLINE_ROUTINE int _Atomic_Compare_exchange_int(
- Atomic_Int old_value,
- Atomic_Int new_value,
+ unsigned int *old_value,
+ unsigned int new_value,
RTEMS_INLINE_ROUTINE int _Atomic_Compare_exchange_long(
- Atomic_Long old_value,
- Atomic_Long new_value,
+ unsigned long *old_value,
+ unsigned long new_value,
RTEMS_INLINE_ROUTINE int _Atomic_Compare_exchange_ptr(
- Atomic_Pointer old_value,
- Atomic_Pointer new_value,
+ uintptr_t *old_value,
+ uintptr_t new_value,
RTEMS_INLINE_ROUTINE int _Atomic_Compare_exchange_32(
- Atomic_Int32 old_value,
- Atomic_Int32 new_value,
+ uint32_t *old_value,
+ uint32_t new_value,
RTEMS_INLINE_ROUTINE int _Atomic_Compare_exchange_64(
- Atomic_Int64 old_value,
- Atomic_Int64 new_value,
+ uint64_t *old_value,
+ uint64_t new_value,
diff --git a/cpukit/score/include/rtems/score/genericatomicops.h b/cpukit/score/include/rtems/score/genericatomicops.h
index a6c09d3..271089f 100644
--- a/cpukit/score/include/rtems/score/genericatomicops.h
+++ b/cpukit/score/include/rtems/score/genericatomicops.h
@@ -36,190 +36,190 @@ extern "C" {
* @brief Atomically load an atomic type value from address @a address.
-#define ATOMIC_LOAD(NAME, TYPE) \
-RTEMS_INLINE_ROUTINE Atomic_##TYPE _CPU_Atomic_Load_##NAME( \
+#define ATOMIC_LOAD(NAME, TYPE, R_TYPE) \
+RTEMS_INLINE_ROUTINE R_TYPE _CPU_Atomic_Load_##NAME( \
volatile Atomic_##TYPE *address \
- Atomic_##TYPE tmp; \
+ R_TYPE tmp; \
ISR_Level level; \
_ISR_Disable( level ); \
- tmp = *address; \
+ tmp = address->__val; \
_ISR_Enable( level ); \
return tmp; \
-ATOMIC_LOAD(int, Int);
-ATOMIC_LOAD(acq_int, Int);
-ATOMIC_LOAD(long, Long);
-ATOMIC_LOAD(acq_long, Long);
-ATOMIC_LOAD(ptr, Pointer);
-ATOMIC_LOAD(acq_ptr, Pointer);
-ATOMIC_LOAD(32, Int32);
-ATOMIC_LOAD(acq_32, Int32);
-ATOMIC_LOAD(64, Int64);
-ATOMIC_LOAD(acq_64, Int64);
+ATOMIC_LOAD(int, Int, unsigned int);
+ATOMIC_LOAD(acq_int, Int, unsigned int);
+ATOMIC_LOAD(long, Long, unsigned long);
+ATOMIC_LOAD(acq_long, Long, unsigned long);
+ATOMIC_LOAD(ptr, Pointer, uintptr_t);
+ATOMIC_LOAD(acq_ptr, Pointer, uintptr_t);
+ATOMIC_LOAD(32, Int32, uint32_t);
+ATOMIC_LOAD(acq_32, Int32, uint32_t);
+ATOMIC_LOAD(64, Int64, uint64_t);
+ATOMIC_LOAD(acq_64, Int64, uint64_t);
* @brief Atomically store an atomic type value @a value into address @a
* address.
-#define ATOMIC_STORE(NAME, TYPE) \
-RTEMS_INLINE_ROUTINE void _CPU_Atomic_Store_##NAME( \
+#define ATOMIC_STORE(NAME, TYPE, R_TYPE) \
+RTEMS_INLINE_ROUTINE void _CPU_Atomic_Store_##NAME( \
volatile Atomic_##TYPE *address, \
- Atomic_##TYPE value \
+ R_TYPE value \
ISR_Level level; \
- *address = value; \
+ address->__val = value; \
-ATOMIC_STORE(int, Int);
-ATOMIC_STORE(rel_int, Int);
-ATOMIC_STORE(long, Long);
-ATOMIC_STORE(rel_long, Long);
-ATOMIC_STORE(ptr, Pointer);
-ATOMIC_STORE(rel_ptr, Pointer);
-ATOMIC_STORE(32, Int32);
-ATOMIC_STORE(rel_32, Int32);
-ATOMIC_STORE(64, Int64);
-ATOMIC_STORE(rel_64, Int64);
+ATOMIC_STORE(int, Int, unsigned int);
+ATOMIC_STORE(rel_int, Int, unsigned int);
+ATOMIC_STORE(long, Long, unsigned long);
+ATOMIC_STORE(rel_long, Long, unsigned long);
+ATOMIC_STORE(ptr, Pointer, uintptr_t);
+ATOMIC_STORE(rel_ptr, Pointer, uintptr_t);
+ATOMIC_STORE(32, Int32, uint32_t);
+ATOMIC_STORE(rel_32, Int32, uint32_t);
+ATOMIC_STORE(64, Int64, uint64_t);
+ATOMIC_STORE(rel_64, Int64, uint64_t);
* @brief Atomically load-add-store an atomic type value @a value into address
* @a address.
-#define ATOMIC_FETCH_ADD(NAME, TYPE) \
+#define ATOMIC_FETCH_ADD(NAME, TYPE, R_TYPE) \
RTEMS_INLINE_ROUTINE void _CPU_Atomic_Fetch_add_##NAME( \
+ R_TYPE value \
ISR_Level level; \
- *address += value; \
+ address->__val += value; \
-ATOMIC_FETCH_ADD(int, Int);
-ATOMIC_FETCH_ADD(acq_int, Int);
-ATOMIC_FETCH_ADD(rel_int, Int);
-ATOMIC_FETCH_ADD(long, Long);
-ATOMIC_FETCH_ADD(acq_long, Long);
-ATOMIC_FETCH_ADD(rel_long, Long);
-ATOMIC_FETCH_ADD(ptr, Pointer);
-ATOMIC_FETCH_ADD(acq_ptr, Pointer);
-ATOMIC_FETCH_ADD(rel_ptr, Pointer);
-ATOMIC_FETCH_ADD(32, Int32);
-ATOMIC_FETCH_ADD(acq_32, Int32);
-ATOMIC_FETCH_ADD(rel_32, Int32);
-ATOMIC_FETCH_ADD(64, Int64);
-ATOMIC_FETCH_ADD(acq_64, Int64);
-ATOMIC_FETCH_ADD(rel_64, Int64);
+ATOMIC_FETCH_ADD(int, Int, unsigned int);
+ATOMIC_FETCH_ADD(acq_int, Int, unsigned int);
+ATOMIC_FETCH_ADD(rel_int, Int, unsigned int);
+ATOMIC_FETCH_ADD(long, Long, unsigned long);
+ATOMIC_FETCH_ADD(acq_long, Long, unsigned long);
+ATOMIC_FETCH_ADD(rel_long, Long, unsigned long);
+ATOMIC_FETCH_ADD(ptr, Pointer, uintptr_t);
+ATOMIC_FETCH_ADD(acq_ptr, Pointer, uintptr_t);
+ATOMIC_FETCH_ADD(rel_ptr, Pointer, uintptr_t);
+ATOMIC_FETCH_ADD(32, Int32, uint32_t);
+ATOMIC_FETCH_ADD(acq_32, Int32, uint32_t);
+ATOMIC_FETCH_ADD(rel_32, Int32, uint32_t);
+ATOMIC_FETCH_ADD(64, Int64, uint64_t);
+ATOMIC_FETCH_ADD(acq_64, Int64, uint64_t);
+ATOMIC_FETCH_ADD(rel_64, Int64, uint64_t);
* @brief Atomically load-sub-store an atomic type value @a value into address
* @a address.
-#define ATOMIC_FETCH_SUB(NAME, TYPE) \
+#define ATOMIC_FETCH_SUB(NAME, TYPE, R_TYPE) \
RTEMS_INLINE_ROUTINE void _CPU_Atomic_Fetch_sub_##NAME( \
+ R_TYPE value \
ISR_Level level; \
- *address -= value; \
+ address->__val -= value; \
-ATOMIC_FETCH_SUB(int, Int);
-ATOMIC_FETCH_SUB(acq_int, Int);
-ATOMIC_FETCH_SUB(rel_int, Int);
-ATOMIC_FETCH_SUB(long, Long);
-ATOMIC_FETCH_SUB(acq_long, Long);
-ATOMIC_FETCH_SUB(rel_long, Long);
-ATOMIC_FETCH_SUB(ptr, Pointer);
-ATOMIC_FETCH_SUB(acq_ptr, Pointer);
-ATOMIC_FETCH_SUB(rel_ptr, Pointer);
-ATOMIC_FETCH_SUB(32, Int32);
-ATOMIC_FETCH_SUB(acq_32, Int32);
-ATOMIC_FETCH_SUB(rel_32, Int32);
-ATOMIC_FETCH_SUB(64, Int64);
-ATOMIC_FETCH_SUB(acq_64, Int64);
-ATOMIC_FETCH_SUB(rel_64, Int64);
+ATOMIC_FETCH_SUB(int, Int, unsigned int);
+ATOMIC_FETCH_SUB(acq_int, Int, unsigned int);
+ATOMIC_FETCH_SUB(rel_int, Int, unsigned int);
+ATOMIC_FETCH_SUB(long, Long, unsigned long);
+ATOMIC_FETCH_SUB(acq_long, Long, unsigned long);
+ATOMIC_FETCH_SUB(rel_long, Long, unsigned long);
+ATOMIC_FETCH_SUB(ptr, Pointer, uintptr_t);
+ATOMIC_FETCH_SUB(acq_ptr, Pointer, uintptr_t);
+ATOMIC_FETCH_SUB(rel_ptr, Pointer, uintptr_t);
+ATOMIC_FETCH_SUB(32, Int32, uint32_t);
+ATOMIC_FETCH_SUB(acq_32, Int32, uint32_t);
+ATOMIC_FETCH_SUB(rel_32, Int32, uint32_t);
+ATOMIC_FETCH_SUB(64, Int64, uint64_t);
+ATOMIC_FETCH_SUB(acq_64, Int64, uint64_t);
+ATOMIC_FETCH_SUB(rel_64, Int64, uint64_t);
* @brief Atomically load-or-store an atomic type value @a value into address
* @a address.
-#define ATOMIC_FETCH_OR(NAME, TYPE) \
+#define ATOMIC_FETCH_OR(NAME, TYPE, R_TYPE) \
RTEMS_INLINE_ROUTINE void _CPU_Atomic_Fetch_or_##NAME( \
+ R_TYPE value \
ISR_Level level; \
- *address |= value; \
+ address->__val |= value; \
-ATOMIC_FETCH_OR(int, Int);
-ATOMIC_FETCH_OR(acq_int, Int);
-ATOMIC_FETCH_OR(rel_int, Int);
-ATOMIC_FETCH_OR(long, Long);
-ATOMIC_FETCH_OR(acq_long, Long);
-ATOMIC_FETCH_OR(rel_long, Long);
-ATOMIC_FETCH_OR(ptr, Pointer);
-ATOMIC_FETCH_OR(acq_ptr, Pointer);
-ATOMIC_FETCH_OR(rel_ptr, Pointer);
-ATOMIC_FETCH_OR(32, Int32);
-ATOMIC_FETCH_OR(acq_32, Int32);
-ATOMIC_FETCH_OR(rel_32, Int32);
-ATOMIC_FETCH_OR(64, Int64);
-ATOMIC_FETCH_OR(acq_64, Int64);
-ATOMIC_FETCH_OR(rel_64, Int64);
+ATOMIC_FETCH_OR(int, Int, unsigned int);
+ATOMIC_FETCH_OR(acq_int, Int, unsigned int);
+ATOMIC_FETCH_OR(rel_int, Int, unsigned int);
+ATOMIC_FETCH_OR(long, Long, unsigned long);
+ATOMIC_FETCH_OR(acq_long, Long, unsigned long);
+ATOMIC_FETCH_OR(rel_long, Long, unsigned long);
+ATOMIC_FETCH_OR(ptr, Pointer, uintptr_t);
+ATOMIC_FETCH_OR(acq_ptr, Pointer, uintptr_t);
+ATOMIC_FETCH_OR(rel_ptr, Pointer, uintptr_t);
+ATOMIC_FETCH_OR(32, Int32, uint32_t);
+ATOMIC_FETCH_OR(acq_32, Int32, uint32_t);
+ATOMIC_FETCH_OR(rel_32, Int32, uint32_t);
+ATOMIC_FETCH_OR(64, Int64, uint64_t);
+ATOMIC_FETCH_OR(acq_64, Int64, uint64_t);
+ATOMIC_FETCH_OR(rel_64, Int64, uint64_t);
* @brief Atomically load-and-store an atomic type value @a value into address
* @a address.
-#define ATOMIC_FETCH_AND(NAME, TYPE) \
+#define ATOMIC_FETCH_AND(NAME, TYPE, R_TYPE) \
RTEMS_INLINE_ROUTINE void _CPU_Atomic_Fetch_and_##NAME( \
+ R_TYPE value \
ISR_Level level; \
- *address &= value; \
+ address->__val &= value; \
-ATOMIC_FETCH_AND(int, Int);
-ATOMIC_FETCH_AND(acq_int, Int);
-ATOMIC_FETCH_AND(rel_int, Int);
-ATOMIC_FETCH_AND(long, Long);
-ATOMIC_FETCH_AND(acq_long, Long);
-ATOMIC_FETCH_AND(rel_long, Long);
-ATOMIC_FETCH_AND(ptr, Pointer);
-ATOMIC_FETCH_AND(acq_ptr, Pointer);
-ATOMIC_FETCH_AND(rel_ptr, Pointer);
-ATOMIC_FETCH_AND(32, Int32);
-ATOMIC_FETCH_AND(acq_32, Int32);
-ATOMIC_FETCH_AND(rel_32, Int32);
-ATOMIC_FETCH_AND(64, Int64);
-ATOMIC_FETCH_AND(acq_64, Int64);
-ATOMIC_FETCH_AND(rel_64, Int64);
+ATOMIC_FETCH_AND(int, Int, unsigned int);
+ATOMIC_FETCH_AND(acq_int, Int, unsigned int);
+ATOMIC_FETCH_AND(rel_int, Int, unsigned int);
+ATOMIC_FETCH_AND(long, Long, unsigned long);
+ATOMIC_FETCH_AND(acq_long, Long, unsigned long);
+ATOMIC_FETCH_AND(rel_long, Long, unsigned long);
+ATOMIC_FETCH_AND(ptr, Pointer, uintptr_t);
+ATOMIC_FETCH_AND(acq_ptr, Pointer, uintptr_t);
+ATOMIC_FETCH_AND(rel_ptr, Pointer, uintptr_t);
+ATOMIC_FETCH_AND(32, Int32, uint32_t);
+ATOMIC_FETCH_AND(acq_32, Int32, uint32_t);
+ATOMIC_FETCH_AND(rel_32, Int32, uint32_t);
+ATOMIC_FETCH_AND(64, Int64, uint64_t);
+ATOMIC_FETCH_AND(acq_64, Int64, uint64_t);
+ATOMIC_FETCH_AND(rel_64, Int64, uint64_t);
* @brief Atomically compare the value stored at @a address with @a
@@ -227,19 +227,19 @@ ATOMIC_FETCH_AND(rel_64, Int64);
* address with @a new_value. Returns zero if the compare failed,
* nonzero otherwise.
-#define ATOMIC_COMPARE_EXCHANGE(NAME, TYPE) \
+#define ATOMIC_COMPARE_EXCHANGE(NAME, TYPE, R_TYPE) \
RTEMS_INLINE_ROUTINE int _CPU_Atomic_Compare_exchange_##NAME( \
- Atomic_##TYPE old_value, \
- Atomic_##TYPE new_value \
+ R_TYPE *old_value, \
+ R_TYPE new_value \
ISR_Level level; \
int ret; \
- if (*address == old_value) { \
- *address = new_value; \
+ if (address->__val == *old_value) { \
+ address->__val = new_value; \
ret = TRUE; \
} else { \
ret = FALSE; \
@@ -249,21 +249,21 @@ RTEMS_INLINE_ROUTINE int _CPU_Atomic_Compare_exchange_##NAME( \
return ret; \
-ATOMIC_COMPARE_EXCHANGE(int, Int);
-ATOMIC_COMPARE_EXCHANGE(acq_int, Int);
-ATOMIC_COMPARE_EXCHANGE(rel_int, Int);
-ATOMIC_COMPARE_EXCHANGE(long, Long);
-ATOMIC_COMPARE_EXCHANGE(acq_long, Long);
-ATOMIC_COMPARE_EXCHANGE(rel_long, Long);
-ATOMIC_COMPARE_EXCHANGE(ptr, Pointer);
-ATOMIC_COMPARE_EXCHANGE(acq_ptr, Pointer);
-ATOMIC_COMPARE_EXCHANGE(rel_ptr, Pointer);
-ATOMIC_COMPARE_EXCHANGE(32, Int32);
-ATOMIC_COMPARE_EXCHANGE(acq_32, Int32);
-ATOMIC_COMPARE_EXCHANGE(rel_32, Int32);
-ATOMIC_COMPARE_EXCHANGE(64, Int64);
-ATOMIC_COMPARE_EXCHANGE(acq_64, Int64);
-ATOMIC_COMPARE_EXCHANGE(rel_64, Int64);
+ATOMIC_COMPARE_EXCHANGE(int, Int, unsigned int);
+ATOMIC_COMPARE_EXCHANGE(acq_int, Int, unsigned int);
+ATOMIC_COMPARE_EXCHANGE(rel_int, Int, unsigned int);
+ATOMIC_COMPARE_EXCHANGE(long, Long, unsigned long);
+ATOMIC_COMPARE_EXCHANGE(acq_long, Long, unsigned long);
+ATOMIC_COMPARE_EXCHANGE(rel_long, Long, unsigned long);
+ATOMIC_COMPARE_EXCHANGE(ptr, Pointer, uintptr_t);
+ATOMIC_COMPARE_EXCHANGE(acq_ptr, Pointer, uintptr_t);
+ATOMIC_COMPARE_EXCHANGE(rel_ptr, Pointer, uintptr_t);
+ATOMIC_COMPARE_EXCHANGE(32, Int32, uint32_t);
+ATOMIC_COMPARE_EXCHANGE(acq_32, Int32, uint32_t);
+ATOMIC_COMPARE_EXCHANGE(rel_32, Int32, uint32_t);
+ATOMIC_COMPARE_EXCHANGE(64, Int64, uint64_t);
+ATOMIC_COMPARE_EXCHANGE(acq_64, Int64, uint64_t);
+ATOMIC_COMPARE_EXCHANGE(rel_64, Int64, uint64_t);
#ifdef __cplusplus
diff --git a/cpukit/score/include/rtems/score/genericcpuatomic.h b/cpukit/score/include/rtems/score/genericcpuatomic.h
index 2599d0d..ed5868a 100644
--- a/cpukit/score/include/rtems/score/genericcpuatomic.h
+++ b/cpukit/score/include/rtems/score/genericcpuatomic.h
@@ -16,6 +16,7 @@
#define _RTEMS_SCORE_GEMERAL_ATOMIC_CPU_H
#include <stdint.h>
+#include <stdatomic.h>
#ifdef __cplusplus
extern "C" {
@@ -31,27 +32,37 @@ extern "C" {
* @brief atomic operation unsigned integer type
-typedef unsigned int Atomic_Int;
+//typedef unsigned int Atomic_Int;
+//typedef _Atomic(unsigned int) Atomic_Int;
+typedef atomic_uint Atomic_Int;
* @brief atomic operation unsigned long integer type
-typedef unsigned long Atomic_Long;
+//typedef unsigned long Atomic_Long;
+//typedef _Atomic(unsigned long) Atomic_Long;
+typedef atomic_ulong Atomic_Long;
* @brief atomic operation unsigned 32-bit integer type
-typedef uint32_t Atomic_Int32;
+//typedef uint32_t Atomic_Int32;
+//typedef _Atomic(uint32_t) Atomic_Int32;
+typedef atomic_uint_least32_t Atomic_Int32;
* @brief atomic operation unsigned 64-bit integer type
-typedef uint64_t Atomic_Int64;
+//typedef uint64_t Atomic_Int64;
+//typedef _Atomic(uint64_t) Atomic_Int64;
+typedef atomic_uint_least64_t Atomic_Int64;
* @brief atomic operation unsigned integer the size of a pointer type
-typedef uintptr_t Atomic_Pointer;
+//typedef uintptr_t Atomic_Pointer;
+//typedef _Atomic(uintptr_t) Atomic_Pointer;
+typedef atomic_uintptr_t Atomic_Pointer;
#ifdef __cplusplus
diff --git a/cpukit/score/inline/rtems/score/atomic.inl b/cpukit/score/inline/rtems/score/atomic.inl
index 313366c..3486924 100644
--- a/cpukit/score/inline/rtems/score/atomic.inl
+++ b/cpukit/score/inline/rtems/score/atomic.inl
@@ -31,7 +31,7 @@
#ifndef _RTEMS_SCORE_ATOMIC_INL
#define _RTEMS_SCORE_ATOMIC_INL
@@ -41,7 +41,7 @@ RTEMS_INLINE_ROUTINE Atomic_Int _Atomic_Load_int(
return _CPU_Atomic_Load_int(address);
@@ -51,7 +51,7 @@ RTEMS_INLINE_ROUTINE Atomic_Long _Atomic_Load_long(
return _CPU_Atomic_Load_long(address);
@@ -61,7 +61,7 @@ RTEMS_INLINE_ROUTINE Atomic_Pointer _Atomic_Load_ptr(
return _CPU_Atomic_Load_ptr(address);
@@ -71,7 +71,7 @@ RTEMS_INLINE_ROUTINE Atomic_Int32 _Atomic_Load_32(
return _CPU_Atomic_Load_32(address);
@@ -84,7 +84,7 @@ RTEMS_INLINE_ROUTINE Atomic_Int64 _Atomic_Load_64(
- Atomic_Int value,
@@ -95,7 +95,7 @@ RTEMS_INLINE_ROUTINE void _Atomic_Store_int(
@@ -106,7 +106,7 @@ RTEMS_INLINE_ROUTINE void _Atomic_Store_long(
+ uintptr_t value,
@@ -117,7 +117,7 @@ RTEMS_INLINE_ROUTINE void _Atomic_Store_ptr(
+ uint32_t value,
@@ -128,7 +128,7 @@ RTEMS_INLINE_ROUTINE void _Atomic_Store_32(
+ uint64_t value,
@@ -139,7 +139,7 @@ RTEMS_INLINE_ROUTINE void _Atomic_Store_64(
- Atomic_Int value,
@@ -153,7 +153,7 @@ RTEMS_INLINE_ROUTINE void _Atomic_Fetch_add_int(
@@ -167,7 +167,7 @@ RTEMS_INLINE_ROUTINE void _Atomic_Fetch_add_long(
+ uintptr_t value,
@@ -181,7 +181,7 @@ RTEMS_INLINE_ROUTINE void _Atomic_Fetch_add_ptr(
+ uint32_t value,
@@ -195,7 +195,7 @@ RTEMS_INLINE_ROUTINE void _Atomic_Fetch_add_32(
+ uint64_t value,
@@ -209,7 +209,7 @@ RTEMS_INLINE_ROUTINE void _Atomic_Fetch_add_64(
- Atomic_Int value,
@@ -223,7 +223,7 @@ RTEMS_INLINE_ROUTINE void _Atomic_Fetch_sub_int(
@@ -237,7 +237,7 @@ RTEMS_INLINE_ROUTINE void _Atomic_Fetch_sub_long(
+ uintptr_t value,
@@ -251,7 +251,7 @@ RTEMS_INLINE_ROUTINE void _Atomic_Fetch_sub_ptr(
+ uint32_t value,
@@ -265,7 +265,7 @@ RTEMS_INLINE_ROUTINE void _Atomic_Fetch_sub_32(
+ uint64_t value,
@@ -279,7 +279,7 @@ RTEMS_INLINE_ROUTINE void _Atomic_Fetch_sub_64(
- Atomic_Int value,
@@ -293,7 +293,7 @@ RTEMS_INLINE_ROUTINE void _Atomic_Fetch_or_int(
@@ -307,7 +307,7 @@ RTEMS_INLINE_ROUTINE void _Atomic_Fetch_or_long(
+ uintptr_t value,
@@ -321,7 +321,7 @@ RTEMS_INLINE_ROUTINE void _Atomic_Fetch_or_ptr(
+ uint32_t value,
@@ -335,7 +335,7 @@ RTEMS_INLINE_ROUTINE void _Atomic_Fetch_or_32(
+ uint64_t value,
@@ -349,7 +349,7 @@ RTEMS_INLINE_ROUTINE void _Atomic_Fetch_or_64(
- Atomic_Int value,
@@ -363,7 +363,7 @@ RTEMS_INLINE_ROUTINE void _Atomic_Fetch_and_int(
@@ -377,7 +377,7 @@ RTEMS_INLINE_ROUTINE void _Atomic_Fetch_and_long(
+ uintptr_t value,
@@ -391,7 +391,7 @@ RTEMS_INLINE_ROUTINE void _Atomic_Fetch_and_ptr(
+ uint32_t value,
@@ -405,7 +405,7 @@ RTEMS_INLINE_ROUTINE void _Atomic_Fetch_and_32(
+ uint64_t value,
@@ -419,8 +419,8 @@ RTEMS_INLINE_ROUTINE void _Atomic_Fetch_and_64(
@@ -434,8 +434,8 @@ RTEMS_INLINE_ROUTINE int _Atomic_Compare_exchange_int(
@@ -449,8 +449,8 @@ RTEMS_INLINE_ROUTINE int _Atomic_Compare_exchange_long(
@@ -464,8 +464,8 @@ RTEMS_INLINE_ROUTINE int _Atomic_Compare_exchange_ptr(
@@ -479,8 +479,8 @@ RTEMS_INLINE_ROUTINE int _Atomic_Compare_exchange_32(
1.7.9.5
