[Patch] Removing legacy method from arm csb336
Vipul Nayyar
nayyar_vipul at yahoo.com
Sun Jun 30 10:47:34 UTC 2013
Hello,
Trying once gain with the arm csb336 patch. I'm explicitly checking the status code returned now, but am I doing the right thing if the status code returned is not RTEMS_SUCCESSFUL ? For now I'm doing the same what happens in BSP_install_rtems_irq_handler & BSP_remove_rtems_irq_handler ?
commit 1887514fd17d17c089c4305f34963c244324eba3
Author: Vipul Nayyar <nayyar_vipul at yahoo.com>
Date: Sun Jun 30 16:08:43 2013 +0530
Updated Legacy code in arm csb336
diff --git a/c/src/lib/libbsp/arm/csb336/console/uart.c b/c/src/lib/libbsp/arm/csb336/console/uart.c
index 4dc409b..758f103 100644
--- a/c/src/lib/libbsp/arm/csb336/console/uart.c
+++ b/c/src/lib/libbsp/arm/csb336/console/uart.c
@@ -246,9 +246,36 @@ static int imx_uart_first_open(int major, int minor, void *arg)
imx_uart_data[minor].tty = args->iop->data1;
+ rtems_status_code sc = RTEMS_SUCCESSFUL;
#if defined(USE_INTERRUPTS)
- BSP_install_rtems_irq_handler(&imx_uart_tx_isr_data[minor]);
- BSP_install_rtems_irq_handler(&imx_uart_rx_isr_data[minor]);
+ sc = rtems_interrupt_handler_install(
+ imx_uart_tx_isr_data[minor].name,
+ "Console",
+ RTEMS_INTERRUPT_UNIQUE,
+ imx_uart_tx_isr_data[minor].hdl,
+ imx_uart_tx_isr_data[minor].handle
+ if (sc != RTEMS_SUCCESSFUL) {
+ return 0;
+ if (imx_uart_tx_isr_data[minor].on != NULL) {
+ imx_uart_tx_isr_data[minor].on(&imx_uart_tx_isr_data[minor]);
+ imx_uart_rx_isr_data[minor].name,
+ "Console",
+ imx_uart_rx_isr_data[minor].hdl,
+ imx_uart_rx_isr_data[minor].handle
+ return 0;
+ if (imx_uart_rx_isr_data[minor].on != NULL) {
+ imx_uart_rx_isr_data[minor].on(&imx_uart_rx_isr_data[minor]);
imx_uart_data[minor].regs->cr1 |= MC9328MXL_UART_CR1_RRDYEN;
#endif
@@ -258,9 +285,32 @@ static int imx_uart_first_open(int major, int minor, void *arg)
static int imx_uart_last_close(int major, int minor, void *arg)
- BSP_remove_rtems_irq_handler(&imx_uart_tx_isr_data[minor]);
- BSP_remove_rtems_irq_handler(&imx_uart_rx_isr_data[minor]);
+ if (imx_uart_tx_isr_data[minor].off != NULL) {
+ imx_uart_tx_isr_data[minor].off(&imx_uart_tx_isr_data[minor]);
+ sc = rtems_interrupt_handler_remove(
+ return 0;
+ if (imx_uart_rx_isr_data[minor].off != NULL) {
+ imx_uart_rx_isr_data[minor].off(&imx_uart_rx_isr_data[minor]);
+ return 0;
#endif
return 0;
diff --git a/c/src/lib/libbsp/arm/csb336/network/network.c b/c/src/lib/libbsp/arm/csb336/network/network.c
index e513595..2441c01 100644
--- a/c/src/lib/libbsp/arm/csb336/network/network.c
+++ b/c/src/lib/libbsp/arm/csb336/network/network.c
@@ -238,6 +238,7 @@ void mc9328mxl_enet_init_hw(mc9328mxl_enet_softc_t *sc)
uint16_t stat;
uint16_t my = 0;
lan91c11x_write_reg(LAN91C11X_RCR, LAN91C11X_RCR_RST);
lan91c11x_write_reg(LAN91C11X_RCR, 0);
@@ -334,7 +335,19 @@ void mc9328mxl_enet_init_hw(mc9328mxl_enet_softc_t *sc)
MC9328MXL_GPIOA_IMR |= bit(3);
/* Install the interrupt handler */
- BSP_install_rtems_irq_handler(&mc9328mxl_enet_isr_data);
+ mc9328mxl_enet_isr_data.name,
+ "Network",
+ mc9328mxl_enet_isr_data.hdl,
+ mc9328mxl_enet_isr_data.handle
+ return 0;
+ if (mc9328mxl_enet_isr_data.on != NULL) {
+ mc9328mxl_enet_isr_data.on(&mc9328mxl_enet_isr_data);
} /* mc9328mxl_enet_init_hw() */
Regards
Vipul Nayyar
________________________________
To: Vipul Nayyar <nayyar_vipul at yahoo.com>
Cc: "rtems-devel at rtems.org" <rtems-devel at rtems.org>; Sebastian Huber <sebastian.huber at embedded-brains.de>; "gedare at rtems.org" <gedare at rtems.org>
Sent: Sunday, 30 June 2013 2:04 AM
Subject: Re: [Patch] Removing legacy method from arm csb336
Please return the status code into a variable and test it separately in the assert. I will defer to Sebastian on whether assert should be used. I tend to think it should be a fatal error call with an explicit test. Using assert increases the code size. Plus this first one gives you a pattern for the rest.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130630/17d87b17/attachment.html>
