[PATCH 4/9] score: Simplify _CORE_semaphore_Seize_isr_disable
Wed Jun 5 15:22:02 UTC 2013
 cpukit/rtems/src/semobtain.c                |    2 +-
 cpukit/score/inline/rtems/score/coresem.inl |   10 +++++-----
 2 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/cpukit/rtems/src/semobtain.c b/cpukit/rtems/src/semobtain.c
index fe5710e..14ed515 100644
--- a/cpukit/rtems/src/semobtain.c
+++ b/cpukit/rtems/src/semobtain.c
@@ -70,7 +70,7 @@ rtems_status_code rtems_semaphore_obtain(
         id,
         ((_Options_Is_no_wait( option_set )) ? false : true),
         timeout,
-        &level
+        level
       return _Semaphore_Translate_core_semaphore_return_code(
                   _Thread_Executing->Wait.return_code );
diff --git a/cpukit/score/inline/rtems/score/coresem.inl b/cpukit/score/inline/rtems/score/coresem.inl
index 69a7b26..aa021eb 100644
--- a/cpukit/score/inline/rtems/score/coresem.inl
+++ b/cpukit/score/inline/rtems/score/coresem.inl
@@ -70,7 +70,7 @@ RTEMS_INLINE_ROUTINE uint32_t  _CORE_semaphore_Get_count(
  * @param[in] id is the Id of the owning API level Semaphore object
  * @param[in] wait is true if the thread is willing to wait
  * @param[in] timeout is the maximum number of ticks to block
- * @param[in] level_p is a temporary variable used to contain the ISR
+ * @param[in] level is a temporary variable used to contain the ISR
  *        disable level cookie
  * @note There is currently no MACRO version of this routine.
@@ -80,7 +80,7 @@ RTEMS_INLINE_ROUTINE void _CORE_semaphore_Seize_isr_disable(
   Objects_Id               id,
   bool                     wait,
   Watchdog_Interval        timeout,
-  ISR_Level               *level_p
+  ISR_Level                level
   Thread_Control *executing;
@@ -91,12 +91,12 @@ RTEMS_INLINE_ROUTINE void _CORE_semaphore_Seize_isr_disable(
   executing->Wait.return_code = CORE_SEMAPHORE_STATUS_SUCCESSFUL;
   if ( the_semaphore->count != 0 ) {
     the_semaphore->count -= 1;
-    _ISR_Enable( *level_p );
+    _ISR_Enable( level );
     return;
   if ( !wait ) {
     executing->Wait.return_code = CORE_SEMAPHORE_STATUS_UNSATISFIED_NOWAIT;
     return;
@@ -105,7 +105,7 @@ RTEMS_INLINE_ROUTINE void _CORE_semaphore_Seize_isr_disable(
   _Thread_queue_Enter_critical_section( &the_semaphore->Wait_queue );
   executing->Wait.queue          = &the_semaphore->Wait_queue;
   executing->Wait.id             = id;
   _Thread_queue_Enqueue( &the_semaphore->Wait_queue, timeout );
   _Thread_Enable_dispatch();
1.7.7
