[PATCH 9/9] score: Add and use _Objects_Release()
Gedare Bloom
gedare at rtems.org
Thu Jun 6 13:35:32 UTC 2013
On Thu, Jun 6, 2013 at 6:53 AM, Sebastian Huber
> On 06/05/2013 05:22 PM, Sebastian Huber wrote:
>> Add and use _Objects_Release_without_thread_dispatch(). These two
>> functions pair with the _Objects_Get() function. This helps to
>> introduce object specific SMP locks to avoid lock contention.
> Maybe it is better to name it _Objects_Put(). So we have
> obj = _Objects_Get()
> do_something_with_it(obj)
> _Objects_Put(obj)
Yes I think "Put" is a better inverse operation to "Get". Though given
the following discussion, might it be better to say "Acquire/Release"?
Objects_Get already does a dispatch disable crit section, so the
semantic meaning probably makes sense.
> For SMP it is desirable to gradually introduce more fine grained locking.
> So we may add a SMP lock to Objects_Control and use new functions
> _Objects_Acquire() and _Objects_Release() to protect the object state. For
> example a mutex obtain may use only the object specific lock if it is free
> and use additional locks if it has to perform a blocking operation which
> requires intervention of the scheduler.
Will there need to be new functions, or can "Get/Put" determine
whether the object needs to be locked/unlocked?
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> rtems-devel mailing list
> rtems-devel at rtems.org
