[PATCH 10/12] scheduler: Simplify simple scheduler
Sebastian Huber
Thu Jun 13 18:21:42 UTC 2013
On 13/06/13 18:06, Gedare Bloom wrote:
> On Thu, Jun 13, 2013 at 12:01 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> On Wed, Jun 12, 2013 at 11:29 AM, Sebastian Huber
>> <sebastian.huber at embedded-brains.de> wrote:
>>> Add and use _Scheduler_simple_Insert_as_first_order(),
>>> _Scheduler_simple_Insert_as_last_order(),
>>> _Scheduler_simple_Insert_as_first() and
>>> _Scheduler_simple_Insert_as_last().
>>> .../score/inline/rtems/score/schedulersimple.inl | 46 ++++++++++++++++++++
>>> .../score/src/schedulersimplereadyqueueenqueue.c | 21 +--------
>>> .../src/schedulersimplereadyqueueenqueuefirst.c | 26 +----------
>>> 3 files changed, 50 insertions(+), 43 deletions(-)
>>> diff --git a/cpukit/score/inline/rtems/score/schedulersimple.inl b/cpukit/score/inline/rtems/score/schedulersimple.inl
>>> index e67fc3c..1b58c85 100644
>>> --- a/cpukit/score/inline/rtems/score/schedulersimple.inl
>>> +++ b/cpukit/score/inline/rtems/score/schedulersimple.inl
>>> @@ -48,6 +48,52 @@ RTEMS_INLINE_ROUTINE void _Scheduler_simple_Ready_queue_requeue(
>>> _Scheduler_simple_Ready_queue_enqueue( the_thread );
>>> +RTEMS_INLINE_ROUTINE bool _Scheduler_simple_Insert_as_first_order(
>>> + const Chain_Node *to_insert,
>>> + const Chain_Node *next
>>> + const Thread_Control *thread_to_insert = (const Thread_Control *) to_insert;
>>> + const Thread_Control *thread_next = (const Thread_Control *) next;
>>> + return thread_to_insert->current_priority <= thread_next->current_priority;
>>> +RTEMS_INLINE_ROUTINE bool _Scheduler_simple_Insert_as_last_order(
>>> + return thread_to_insert->current_priority < thread_next->current_priority;
>>> +RTEMS_INLINE_ROUTINE void _Scheduler_simple_Insert_as_first(
>>> + Chain_Control *chain,
>>> + Thread_Control *to_insert
>>> + _Chain_Insert_ordered_unprotected(
>>> + chain,
>>> + &to_insert->Object.Node,
>>> + _Scheduler_simple_Insert_as_first_order
>>> +RTEMS_INLINE_ROUTINE void _Scheduler_simple_Insert_as_last(
>>> + chain,
>>> + _Scheduler_simple_Insert_as_last_order
>> For these functions _Scheduler_simple_Insert_as_first() and
>> _Scheduler_simple_Insert_as_last() the name means they break priority
>> ties by FIFO and LIFO semantics? Before I read the code, I thought it
>> meant break ties by inserting to the first or last position of ties,
>> which is the opposite. I would prefer to have
>> _Scheduler_simple_Insert_as_fifo()/lifo() instead for added clarity.
> I guess saying fifo/lifo could be confusing also, since the insert is
> not fifo/lifo, just how priority ties are broken. So maybe
> _Scheduler_simple_Insert_priority_fifo()/lifo()?
Suppose we have 0 < 5_0 <= 5_1 < 10, then insert 5_2 as first will yield
0 < 5_2 <= 5_0 <= 5_1 < 10
and insert 5_2 as last will yield
0 < 5_0 <= 5_1 <= 5_2 < 10
I will use your suggestions.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
