[PATCH 04/12] score: Add _Chain_Insert_ordered_unprotected()
Gedare Bloom
gedare at rtems.org
Thu Jun 13 18:46:53 UTC 2013
On Thu, Jun 13, 2013 at 2:41 PM, Sebastian Huber
> On 13/06/13 20:31, Gedare Bloom wrote:
>> Yes. It implements a sorted linked list, decrementing the timeout of
>> the insert node by the timeout of each node on the chain until it
>> reaches 0 or the tail. Off the top of my head, I think it would be
>> possible to use this new Insert function with a comparison hook that
>> implements the decrement + comparison. Although I don't know if
>> rewriting the watchdog function is such a good idea, "if it ain't
>> broke, don't fix it"
> The delta chain handling is quite complex. You have several state
> transitions to keep the interrupt disabled time low. During the insert
> interrupt service routines can add and remove items.
Yes good point. Let's let sleeping dogs lie. ;)
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
