[PATCH 3/6] smp: Add and use _CPU_SMP_Send_interrupt()
Sebastian Huber
Fri Jun 14 14:31:58 UTC 2013
Delete bsp_smp_interrupt_cpu().
c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c | 4 ++--
c/src/lib/libbsp/i386/shared/smp/smp-imps.c | 6 ++----
c/src/lib/libbsp/powerpc/qoriq/startup/smp.c | 5 +++--
c/src/lib/libbsp/shared/smp/smp_stub.c | 4 +---
c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c | 8 +++-----
cpukit/score/cpu/arm/rtems/score/cpu.h | 2 ++
cpukit/score/cpu/i386/rtems/score/cpu.h | 2 ++
cpukit/score/cpu/no_cpu/rtems/score/cpu.h | 10 ++++++++++
cpukit/score/cpu/powerpc/rtems/score/cpu.h | 1 +
cpukit/score/cpu/sparc/rtems/score/cpu.h | 2 ++
cpukit/score/include/rtems/bspsmp.h | 12 ------------
cpukit/score/src/smp.c | 2 +-
12 files changed, 29 insertions(+), 29 deletions(-)
diff --git a/c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c b/c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c
index e647b4f..3005bcf 100644
--- a/c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c
+++ b/c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c
@@ -56,11 +56,11 @@ void bsp_smp_broadcast_interrupt(void)
-void bsp_smp_interrupt_cpu(int cpu)
+void _CPU_SMP_Send_interrupt( uint32_t target_processor_index )
rtems_status_code sc = arm_gic_irq_generate_software_irq(
ARM_GIC_IRQ_SGI_0,
ARM_GIC_IRQ_SOFTWARE_IRQ_TO_ALL_IN_LIST,
- (uint8_t) (1U << cpu)
+ (uint8_t) (1U << target_processor_index)
diff --git a/c/src/lib/libbsp/i386/shared/smp/smp-imps.c b/c/src/lib/libbsp/i386/shared/smp/smp-imps.c
index 916379e..806cfb9 100644
--- a/c/src/lib/libbsp/i386/shared/smp/smp-imps.c
+++ b/c/src/lib/libbsp/i386/shared/smp/smp-imps.c
@@ -803,11 +803,9 @@ uint32_t bsp_smp_initialize( uint32_t configured_cpu_count )
return cores;
- int cpu
- send_ipi( cpu, 0x30 );
+ send_ipi( target_processor_index, 0x30 );
diff --git a/c/src/lib/libbsp/powerpc/qoriq/startup/smp.c b/c/src/lib/libbsp/powerpc/qoriq/startup/smp.c
index b16adb8..595729a 100644
--- a/c/src/lib/libbsp/powerpc/qoriq/startup/smp.c
+++ b/c/src/lib/libbsp/powerpc/qoriq/startup/smp.c
@@ -167,8 +167,9 @@ void bsp_smp_broadcast_interrupt(void)
qoriq.pic.per_cpu [self].ipidr [IPI_INDEX].reg = ALL_CORES;
-void bsp_smp_interrupt_cpu(int core)
+void _CPU_SMP_Send_interrupt(uint32_t target_processor_index)
uint32_t self = ppc_processor_id();
- qoriq.pic.per_cpu [self].ipidr [IPI_INDEX].reg = ONE_CORE(core);
+ qoriq.pic.per_cpu [self].ipidr [IPI_INDEX].reg =
+ ONE_CORE(target_processor_index);
diff --git a/c/src/lib/libbsp/shared/smp/smp_stub.c b/c/src/lib/libbsp/shared/smp/smp_stub.c
index 62338b9..175af9d 100644
--- a/c/src/lib/libbsp/shared/smp/smp_stub.c
+++ b/c/src/lib/libbsp/shared/smp/smp_stub.c
@@ -31,9 +31,7 @@ void bsp_smp_broadcast_message(
- int cpu
diff --git a/c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c b/c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c
index 39fc9f9..8862ca5 100644
--- a/c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c
+++ b/c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c
@@ -115,12 +115,10 @@ uint32_t bsp_smp_initialize( uint32_t configured_cpu_count )
return found_cpus;
- int cpu
/* send interrupt to destination CPU */
- LEON3_IrqCtrl_Regs->force[cpu] = 1 << LEON3_MP_IRQ;
+ LEON3_IrqCtrl_Regs->force[target_processor_index] = 1 << LEON3_MP_IRQ;
@@ -135,7 +133,7 @@ void bsp_smp_broadcast_interrupt(void)
for ( dest_cpu=0 ; dest_cpu < max_cpus ; dest_cpu++ ) {
if ( cpu == dest_cpu )
continue;
- bsp_smp_interrupt_cpu( dest_cpu );
+ _CPU_SMP_Send_interrupt( dest_cpu );
/* this is likely needed due to the ISR code not being SMP aware yet */
bsp_smp_delay( 100000 );
diff --git a/cpukit/score/cpu/arm/rtems/score/cpu.h b/cpukit/score/cpu/arm/rtems/score/cpu.h
index ed1b605..519d486 100644
--- a/cpukit/score/cpu/arm/rtems/score/cpu.h
+++ b/cpukit/score/cpu/arm/rtems/score/cpu.h
@@ -457,6 +457,8 @@ void _CPU_Context_validate( uintptr_t pattern );
return mpidr & 0xffU;
+ void _CPU_SMP_Send_interrupt( uint32_t target_processor_index );
static inline void _ARM_Data_memory_barrier( void )
__asm__ volatile ( "dmb" : : : "memory" );
diff --git a/cpukit/score/cpu/i386/rtems/score/cpu.h b/cpukit/score/cpu/i386/rtems/score/cpu.h
index b00ae3b..092ba99 100644
--- a/cpukit/score/cpu/i386/rtems/score/cpu.h
+++ b/cpukit/score/cpu/i386/rtems/score/cpu.h
@@ -457,6 +457,8 @@ uint32_t _CPU_ISR_Get_level( void );
RTEMS_COMPILER_PURE_ATTRIBUTE uint32_t _CPU_SMP_Get_current_processor( void );
static inline void _CPU_Processor_event_broadcast( void )
__asm__ volatile ( "" : : : "memory" );
diff --git a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
index d368e51..dc48d2b 100644
--- a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
+++ b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
@@ -1417,6 +1417,16 @@ static inline uint32_t CPU_swap_u32(
+ * @brief Sends an inter-processor interrupt to the specified target
+ * processor.
+ * This operation is undefined for target processor indices out of range.
+ * @param[in] target_processor_index The target processor index.
* @brief Broadcasts a processor event.
* Some architectures provide a low-level synchronization primitive for
diff --git a/cpukit/score/cpu/powerpc/rtems/score/cpu.h b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
index 9b1917e..759f9dd 100644
--- a/cpukit/score/cpu/powerpc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
@@ -1014,6 +1014,7 @@ void _CPU_Context_validate( uintptr_t pattern );
return pir;
diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
index e4eb65e..8ba7a41 100644
--- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
@@ -1188,6 +1188,8 @@ void _CPU_Context_restore(
diff --git a/cpukit/score/include/rtems/bspsmp.h b/cpukit/score/include/rtems/bspsmp.h
index 57f5a7a..ec8be9f 100644
--- a/cpukit/score/include/rtems/bspsmp.h
+++ b/cpukit/score/include/rtems/bspsmp.h
@@ -84,18 +84,6 @@ uint32_t bsp_smp_initialize( uint32_t configured_cpu_count );
void bsp_smp_broadcast_interrupt(void);
- * @brief Generate a interprocessor interrupt.
- * This method is invoked by RTEMS to let @a cpu know that it
- * has sent it a message.
- * @param [in] cpu is the recipient CPU
- int cpu
* @brief Performs high-level initialization of a secondary processor and runs
* the application threads.
diff --git a/cpukit/score/src/smp.c b/cpukit/score/src/smp.c
index 8e06d04..4d2a1b5 100644
--- a/cpukit/score/src/smp.c
+++ b/cpukit/score/src/smp.c
@@ -121,7 +121,7 @@ void _SMP_Send_message( uint32_t cpu, uint32_t message )
per_cpu->message |= message;
_Per_CPU_Lock_release( per_cpu, level );
- bsp_smp_interrupt_cpu( cpu );
+ _CPU_SMP_Send_interrupt( cpu );
void _SMP_Broadcast_message( uint32_t message )
1.7.7
