[PATCH 6/6] smp: Delete _SMP_Request_other_cores_to_dispatch()
Gedare Bloom
gedare at rtems.org
Fri Jun 14 15:34:41 UTC 2013
This and the previous patches in series seem ok.
On Fri, Jun 14, 2013 at 10:32 AM, Sebastian Huber
> Use an event triggered unicast to inform remote processors about a
> necessary thread dispatch instead.
> cpukit/score/include/rtems/score/smp.h | 8 --------
> cpukit/score/src/isrsmp.c | 3 ---
> cpukit/score/src/schedulersimplesmp.c | 9 +++++++++
> cpukit/score/src/smp.c | 21 ---------------------
> cpukit/score/src/threaddispatch.c | 5 -----
> 5 files changed, 9 insertions(+), 37 deletions(-)
> diff --git a/cpukit/score/include/rtems/score/smp.h b/cpukit/score/include/rtems/score/smp.h
> index fedf9ab..2c2b46a 100644
> --- a/cpukit/score/include/rtems/score/smp.h
> +++ b/cpukit/score/include/rtems/score/smp.h
> @@ -96,14 +96,6 @@ void _SMP_Broadcast_message(
> void _SMP_Request_other_cores_to_perform_first_context_switch(void);
> - * @brief Request dispatch on other cores.
> - * Send message to other cores requesting them to perform
> - * a thread dispatch operation.
> -void _SMP_Request_other_cores_to_dispatch(void);
> * @brief Request other cores to shutdown.
> * Send message to other cores requesting them to shutdown.
> diff --git a/cpukit/score/src/isrsmp.c b/cpukit/score/src/isrsmp.c
> index 9244287..d97c9c3 100644
> --- a/cpukit/score/src/isrsmp.c
> +++ b/cpukit/score/src/isrsmp.c
> @@ -96,8 +96,5 @@ int _ISR_SMP_Exit(void)
> _Thread_Dispatch_decrement_disable_level();
> - if ( retval == 0 )
> - _SMP_Request_other_cores_to_dispatch();
> return retval;
> diff --git a/cpukit/score/src/schedulersimplesmp.c b/cpukit/score/src/schedulersimplesmp.c
> index ec1b0e2..2329c1a 100644
> --- a/cpukit/score/src/schedulersimplesmp.c
> +++ b/cpukit/score/src/schedulersimplesmp.c
> @@ -56,9 +56,18 @@ static void _Scheduler_simple_smp_Allocate_processor(
> if ( heir != victim ) {
> + Per_CPU_Control *cpu_of_executing =
> + &_Per_CPU_Information[ _SMP_Get_current_processor() ];
> heir->cpu = cpu_of_victim;
> cpu_of_victim->heir = heir;
> cpu_of_victim->dispatch_necessary = true;
> + if ( cpu_of_victim != cpu_of_executing ) {
> + _CPU_SMP_Send_interrupt(
> + cpu_of_victim - &_Per_CPU_Information[ 0 ]
> diff --git a/cpukit/score/src/smp.c b/cpukit/score/src/smp.c
> index 4d2a1b5..6cd4fdd 100644
> --- a/cpukit/score/src/smp.c
> +++ b/cpukit/score/src/smp.c
> @@ -162,27 +162,6 @@ void _SMP_Request_other_cores_to_perform_first_context_switch( void )
> -void _SMP_Request_other_cores_to_dispatch( void )
> - if ( _System_state_Is_up( _System_state_Get() ) ) {
> - uint32_t self = _SMP_Get_current_processor();
> - uint32_t ncpus = _SMP_Get_processor_count();
> - uint32_t cpu;
> - for ( cpu = 0 ; cpu < ncpus ; ++cpu ) {
> - const Per_CPU_Control *per_cpu = &_Per_CPU_Information[ cpu ];
> - if (
> - cpu != self
> - && per_cpu->state == PER_CPU_STATE_UP
> - && per_cpu->dispatch_necessary
> - _SMP_Send_message( cpu, 0 );
> void _SMP_Request_other_cores_to_shutdown( void )
> diff --git a/cpukit/score/src/threaddispatch.c b/cpukit/score/src/threaddispatch.c
> index 7000220..9ef5618 100644
> --- a/cpukit/score/src/threaddispatch.c
> +++ b/cpukit/score/src/threaddispatch.c
> @@ -80,11 +80,6 @@ void _Thread_Dispatch( void )
> * once someone calls _Thread_Dispatch().
> _Thread_Disable_dispatch();
> - * If necessary, send dispatch request to other cores.
> #endif
> 1.7.7
> rtems-devel mailing list
> rtems-devel at rtems.org
