[GSOC|virtLayer] hello sample compiles
Philipp Eppelt philipp.eppelt at mailbox.tu-dresden.de
Thu Jun 20 11:19:26 UTC 2013
On 06/19/2013 09:11 PM, Gedare Bloom wrote:
> On Wed, Jun 19, 2013 at 11:02 AM, Philipp Eppelt
> <philipp.eppelt at mailbox.tu-dresden.de> wrote:
>> This is implemented in POK and libpart.a is compiled and copied to
>> rtems/libbsp/i386/virtPok.
>> The virtPok makefile creates a new library file called libpokpart.a.
>> If libpart.a is not present, virtPok fails at compile time.
>> I thought 'noinst_LIBRARIES' would define the libraries going into
>> librtemsbsp.a but sadly this is not dynamic. I had to modify
>> c/src/wrapup/Makefile.am to include libpokpart.a. This is not final, as it
>> breaks all other BSPs ...
> This part sounds like it could use some better design. I do not have
> the answer at the moment.
I already changed this, instead of building a new library, I just append
it to libbsp.a.
> OK. What's next?
* Startup, including workspace setup, idt setup, ...
* Remove GDT.
@Cynthia: I have my own dev-diary and will write a nice build process
explanation in the next two weeks. After this process is set.
I have a little issue with Makefile.am and the use of virtPok/include
directory. bsp.h and tm27.h are copied to the build tree, but my
virtLayer*.h files are not. Why? Where should they go instead?
  14 include_HEADERS = include/bsp.h
  15 include_HEADERS += ../../shared/include/tm27.h
  16 include_HEADERS += include/virtLayerBSP.h
  17 include_HEADERS += include/virtLayerCPU.h
Regards,
Philipp
