[rtems commit] Added in_cksum_sparc. h to optimize IP checksum calculations for SPARC.
Jiri Gaisler
jiri at gaisler.se
Thu Jun 20 22:15:28 UTC 2013
On 06/20/2013 11:14 AM, Ralf Corsepius wrote:
> On 06/19/2013 03:16 PM, Joel Sherrill wrote:
>> Module: rtems
>> Branch: master
>> Commit: 1f4ee306d3ab326a84d0bf74ad6afdedaaa435f8
>> Changeset:
>> http://git.rtems.org/rtems/commit/?id=1f4ee306d3ab326a84d0bf74ad6afdedaaa435f8
>> Author: Jiri Gaisler <jiri at gaisler.se>
>> Date: Sun Jun 16 00:13:41 2013 +0200
>> Added in_cksum_sparc.h to optimize IP checksum calculations for SPARC.
>> cpukit/libnetworking/netinet/in_cksum.c | 4 +
>> cpukit/libnetworking/netinet/in_cksum_sparc.h | 308 +++++++++++++++++++++++++
>> 2 files changed, 312 insertions(+), 0 deletions(-)
>> diff --git a/cpukit/libnetworking/netinet/in_cksum.c
>> b/cpukit/libnetworking/netinet/in_cksum.c
>> index ec7e49c..ff25ad6 100644
>> --- a/cpukit/libnetworking/netinet/in_cksum.c
>> +++ b/cpukit/libnetworking/netinet/in_cksum.c
>> @@ -61,6 +61,10 @@
>> #include "in_cksum_nios2.h"
>> +#elif (defined(__GNUC__) && defined(__sparc))
>> +#include "in_cksum_sparc.h"
>> #else
> I am having several issues with this patch:
> a) Has this code been tested with/checked against sparc64-rtems4.11 toolchains?
No, it has been tested against sparc-rtems4.11. sparc64 is a different
architecture which requires its own implementation of in_cksum_xxx.h.
> I haven't tried to check which code paths are being used with the sparc64 and
> hardly won't have a possibility to check in near future, so this question could
> be a red herring.
> b) This code should use __sparc__ instead of __sparc.
> __sparc is a pre-POSIX anachronism, is still supported by GCC but actually
> should not be used anymore.
Good point. I believe Joel has fixed this already.
Jiri.
> Ralf
> rtems-devel mailing list
> rtems-devel at rtems.org
