RTEMS_malta board support
CHINTHA MOL C.S. chintha308 at gmail.com
Tue Jun 25 11:20:10 UTC 2013
Hi all,
I would like to port RTEMS to malta mips evaluation board.
I successfully built RTEMS 4.10.99 with malta BSP.
I need to load the generated hello.ralf to malta board with YAMON
bootloader.
I edited the MIPS Malta linker script .
RAM base is changed from 0x80000000 to 0x800c0000. and section start from
0x80010000 to 0x80100000.
I converted the hello.ralf file to srec format using mips-retms4.11-objcopy
and successfully loaded it via tftp. But while running it, exception in TLB
occures. the error log is given below.
How can i successfully run this rtems-application (hello.ralf) in malta
board?
Compilation time =              Dec  7 2006
19:00:35
Board type/revision =           0x02 (Malta) /
0x00
Core board type/revision =      0x01 (CoreLV) /
0x01
System controller/revision =    Galileo /
GT_64120A-B-2
FPGA revision =
0x0001
MAC address =
00.d0.a0.00.05.e9
Board S/N =
0000001245
PCI bus frequency =             33.33
MHz
Processor Company ID/options =  0x01 (MIPS Technologies, Inc.) /
0x80
Processor ID/revision =         0x90 (MIPS 4KEc) /
0x68
Endianness =
Little
CPU/Bus frequency =             240 MHz / 80
MHz
Flash memory size =             4
MByte
SDRAM size =                    128
MByte
First free SDRAM address =      0x800b7350
YAMON>
load
About to load tftp://10.1.125.98/hello.srec
Press Ctrl-C to
break
Start = 0x80100024, range = (0x80100000,0x801348a7), format =
SREC
YAMON> go 0x80100024
* Exception (user) : TLB (store)
BadVAddr = 0x00004234  Cause     =
0xd080800c
Compare  = 0xced7cdbf  Config    =
0x80250483
Config1  = 0xbe994c8e  Config2   =
0x80000000
Config3  = 0x00000020  Context   =
0xdf800020
Count    = 0xc21f9d1d  DEPC      =
0xdf5f1e43
Debug    = 0x0e017c3f  EBase     =
0x80000000
EPC      = 0x80100050  EntryHi   =
0x000040ff
EntryLo0 = 0x01f7f555  EntryLo1  =
0x01bf36d7
ErrorEPC = 0xbfc00380  HWREna    =
0x00000000
Index    = 0x80000014  IntCtl    =
0xe0000000
PRId     = 0x80019068  PageGrain =
0x00000000
PageMask = 0x19ffe000  Random    =
0x0000001e
SRSCtl   = 0x00000000  SRSMap    =
0x00000000
Status   = 0x00002c02  WatchHi   =
0x00000000
WatchLo  = 0x00000000  Wired     =
0x00000000
Hi       = 0x00000000  Lo        =
0x80100020
$ 0(zr):0x00000000  $ 8(t0):0x00000000  $16(s0):0x00000000
$24(t8):0x00000000
$ 1(at):0x00000000  $ 9(t1):0x00000000  $17(s1):0x00000000
$25(t9):0x00000000
$ 2(v0):0x00000000  $10(t2):0x00000000  $18(s2):0x00000000
$26(k0):0x00000000
$ 3(v1):0x00000000  $11(t3):0x00000000  $19(s3):0x00000000
$27(k1):0x800abf20
$ 4(a0):0x00000001  $12(t4):0x00000000  $20(s4):0x00000000
$28(gp):0x00000000
$ 5(a1):0x800ad268  $13(t5):0x00000000  $21(s5):0x00000000
$29(sp):0x800b7340
$ 6(a2):0x8006dccc  $14(t6):0x00000000  $22(s6):0x00000000
$30(s8):0x800b7340
$ 7(a3):0x08000000  $15(t7):0x00000000  $23(s7):0x00000000
$31(ra):0x8003ca34
Regards,
Chintha
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130625/0ebb8fa2/attachment-0001.html>
