[Patch] Removing legacy method from arm csb336
Sebastian Huber
Thu Jun 27 09:06:57 UTC 2013
On 06/26/2013 05:28 PM, Vipul Nayyar wrote:
> diff --git a/c/src/lib/libbsp/arm/csb336/console/uart.c
> b/c/src/lib/libbsp/arm/csb336/console/uart.c
> index 4dc409b..0c4ab39 100644
> --- a/c/src/lib/libbsp/arm/csb336/console/uart.c
> +++ b/c/src/lib/libbsp/arm/csb336/console/uart.c
> @@ -246,9 +246,13 @@ static int imx_uart_first_open(int major, int minor, void
> *arg)
> imx_uart_data[minor].tty = args->iop->data1;
> + const rtems_irq_connect_data *uart_tx = &imx_uart_tx_isr_data[minor];
> + const rtems_irq_connect_data *uart_rx = &imx_uart_rx_isr_data[minor];
Please remove the rtems_irq_connect_data items. Make sure that the on/off
helper side effects are preserved as part of the install/remove operation.
> #if defined(USE_INTERRUPTS)
> - BSP_install_rtems_irq_handler(&imx_uart_tx_isr_data[minor]);
> - BSP_install_rtems_irq_handler(&imx_uart_rx_isr_data[minor]);
> + rtems_interrupt_handler_install(uart_tx->name,"LEGACY
> REMOVED",RTEMS_INTERRUPT_UNIQUE,uart_tx->hdl,uart_tx->handle);
> + rtems_interrupt_handler_install(uart_rx->name,"LEGACY
> REMOVED",RTEMS_INTERRUPT_UNIQUE,uart_rx->hdl,uart_rx->handle);
Please replace "LEGACY REMOVED" with something useful. Adhere the 80
characters line limit, e.g. write
uart_rx->name,
"LEGACY REMOVED",
uart_rx->hdl,
uart_rx->handle
Check the return value of this function at least with an assert().
> imx_uart_data[minor].regs->cr1 |= MC9328MXL_UART_CR1_RRDYEN;
> #endif
> diff --git a/c/src/lib/libbsp/arm/csb336/network/network.c
> b/c/src/lib/libbsp/arm/csb336/network/network.c
> index e513595..7f54230 100644
> --- a/c/src/lib/libbsp/arm/csb336/network/network.c
> +++ b/c/src/lib/libbsp/arm/csb336/network/network.c
> @@ -334,7 +334,7 @@ void mc9328mxl_enet_init_hw(mc9328mxl_enet_softc_t *sc)
> MC9328MXL_GPIOA_IMR |= bit(3);
> /* Install the interrupt handler */
> - BSP_install_rtems_irq_handler(&mc9328mxl_enet_isr_data);
> + rtems_interrupt_handler_install(mc9328mxl_enet_isr_data.name,"LEGACY
> REMOVED",RTEMS_INTERRUPT_UNIQUE,mc9328mxl_enet_isr_data.hdl,mc9328mxl_enet_isr_data.handle);
> } /* mc9328mxl_enet_init_hw() */
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
