[PATCH 1/3] The POSIX Key manager is reimplemented with a red-black tree to store the keys and values. This code was contributed as part of GSOC 2012.
Gedare Bloom
gedare at rtems.org
Tue Mar 5 20:55:08 UTC 2013
cpukit/posix/include/rtems/posix/key.h | 50 +++++++++++++++----
cpukit/posix/include/rtems/posix/threadsup.h | 10 ++++
cpukit/posix/src/key.c | 63 +++++++++++++++++++++---
cpukit/posix/src/keycreate.c | 48 ------------------
cpukit/posix/src/keydelete.c | 3 +-
cpukit/posix/src/keyfreememory.c | 35 ++++++++++++-
cpukit/posix/src/keygetspecific.c | 20 +++++---
cpukit/posix/src/keyrundestructors.c | 67 +++++++++++++++----------
cpukit/posix/src/keysetspecific.c | 33 ++++++++++---
cpukit/posix/src/pthread.c | 3 +
10 files changed, 219 insertions(+), 113 deletions(-)
diff --git a/cpukit/posix/include/rtems/posix/key.h b/cpukit/posix/include/rtems/posix/key.h
index 0bb1dbe..ab1fe04 100644
--- a/cpukit/posix/include/rtems/posix/key.h
+++ b/cpukit/posix/include/rtems/posix/key.h
@@ -8,6 +8,7 @@
+ * Copyright (c) 2012 Zhongwei Yao.
* COPYRIGHT (c) 1989-2011.
* On-Line Applications Research Corporation (OAR).
@@ -20,6 +21,8 @@
#define _RTEMS_POSIX_KEY_H
+#include <rtems/score/rbtree.h>
+#include <rtems/score/chain.h>
* @defgroup POSIX_KEY POSIX Key
@@ -34,27 +37,42 @@ extern "C" {
#endif
- * This is the data Structure used to manage a POSIX key.
- * NOTE: The Values is a table indexed by the index portion of the
- * ID of the currently executing thread.
+ * @brief The rbtree node used to manage a POSIX key and value.
+typedef struct {
+ /** This field is the chain node structure. */
+ Chain_Node ch_node;
+ /** This field is the rbtree node structure. */
+ RBTree_Node rb_node;
+ /** This field is the POSIX key used as an rbtree key */
+ pthread_key_t key;
+ /** This field is the Thread id also used as an rbtree key */
+ Objects_Id thread_id;
+ /** This field points to the POSIX key value of specific thread */
+ void *value;
+ } POSIX_Keys_Rbtree_node;
+ * @brief The data structure used to manage a POSIX key.
typedef struct {
/** This field is the Object control structure. */
Objects_Control Object;
- /** This field points to the optional destructor method. */
- void (*destructor)( void * );
- /** This field points to the values per thread. */
- void **Values[ OBJECTS_APIS_LAST + 1 ];
-} POSIX_Keys_Control;
+ /** This field is the data destructor. */
+ void (*destructor) (void *);
+ } POSIX_Keys_Control;
- * The following defines the information control block used to manage
- * this class of objects.
+ * @brief The information control block used to manage this class of objects.
POSIX_EXTERN Objects_Information _POSIX_Keys_Information;
+ * @brief The rbtree control block used to manage all key values
+POSIX_EXTERN RBTree_Control _POSIX_Keys_Rbtree;
* @brief POSIX keys manager initialization.
* This routine performs the initialization necessary for this manager.
@@ -62,6 +80,16 @@ POSIX_EXTERN Objects_Information _POSIX_Keys_Information;
void _POSIX_Key_Manager_initialization(void);
+ * @brief POSIX keys Red-Black tree node comparison.
+ * This routine compares the rbtree node
+int _POSIX_Keys_Rbtree_compare_function(
+ const RBTree_Node *node1,
+ const RBTree_Node *node2
* @brief Create thread-specific data POSIX key.
* This function executes all the destructors associated with the thread's
diff --git a/cpukit/posix/include/rtems/posix/threadsup.h b/cpukit/posix/include/rtems/posix/threadsup.h
index 80f64dc..d746ea8 100644
--- a/cpukit/posix/include/rtems/posix/threadsup.h
+++ b/cpukit/posix/include/rtems/posix/threadsup.h
@@ -21,6 +21,7 @@
#include <sys/signal.h>
#include <rtems/score/coresem.h>
#include <rtems/score/tqdata.h>
* @defgroup POSIX_THREAD POSIX Thread API Extension
@@ -79,6 +80,15 @@ typedef struct {
/** This is the set of cancelation handlers. */
Chain_Control Cancellation_Handlers;
+ * This is the thread key value chain's control, which is used
+ * to track all key value for specific thread, and when thread
+ * exits, we can remove all key value for specific thread by
+ * iterating this chain, or we have to search a whole rbtree,
+ * which is inefficient.
+ Chain_Control Key_Chain;
} POSIX_API_Control;
diff --git a/cpukit/posix/src/key.c b/cpukit/posix/src/key.c
index 6eace26..177543d 100644
--- a/cpukit/posix/src/key.c
+++ b/cpukit/posix/src/key.c
@@ -29,17 +29,58 @@
#include <rtems/posix/key.h>
- * _POSIX_Key_Manager_initialization
- * DESCRIPTION:
- * This routine performs the initialization necessary for this manager.
+ * @brief This routine compares the rbtree node by comparing POSIX key first
+ * and comparing thread id second.
- * Input parameters: NONE
+ * if either of the input nodes's thread_id member is 0, then it will only
+ * compare the pthread_key_t member. That is when we pass thread_id = 0 node
+ * as a search node, the search is done only by pthread_key_t.
- * Output parameters: NONE
+ * @param[in] node1 The node to be compared *
+ * @param[in] node2 The node to be compared
+ * @retval positive if first node has higher key than second
+ * @retval negative if lower
+ * @retval 0 if equal,and for all the thread id is unique, then return 0 is
+ * impossible
+ pthread_key_t key1 = _RBTree_Container_of(node1,
+ POSIX_Keys_Rbtree_node,
+ rb_node)->key;
+ pthread_key_t key2 = _RBTree_Container_of(node2,
+ rb_node)->key;
+ Objects_Id thread_id1 = _RBTree_Container_of(node1,
+ rb_node)->thread_id;
+ Objects_Id thread_id2 = _RBTree_Container_of(node2,
+ int diff = key1 - key2;
+ if ( diff )
+ return diff;
+ * if thread_id1 or thread_id2 equals to 0, only key1 and key2 is valued.
+ * it enables us search node only by pthread_key_t type key.
+ if ( thread_id1 && thread_id2 )
+ return thread_id1 - thread_id2;
+ return 0;
+ * @brief This routine performs the initialization necessary for this manager.
@@ -60,4 +101,10 @@ void _POSIX_Key_Manager_initialization(void)
NULL /* Proxy extraction support callout */
#endif
+ _RBTree_Initialize_empty(
+ &_POSIX_Keys_Rbtree,
+ _POSIX_Keys_Rbtree_compare_function,
+ true
diff --git a/cpukit/posix/src/keycreate.c b/cpukit/posix/src/keycreate.c
index b41b590..2d31d86 100644
--- a/cpukit/posix/src/keycreate.c
+++ b/cpukit/posix/src/keycreate.c
@@ -37,10 +37,6 @@ int pthread_key_create(
POSIX_Keys_Control *the_key;
- void *table;
- uint32_t the_api;
- uint32_t bytes_to_allocate;
_Thread_Disable_dispatch();
@@ -52,50 +48,6 @@ int pthread_key_create(
the_key->destructor = destructor;
- * This is a bit more complex than one might initially expect because
- * APIs are optional.
- * NOTE: Currently RTEMS Classic API tasks are always enabled.
- for ( the_api = 1; the_api <= OBJECTS_APIS_LAST; the_api++ ) {
- the_key->Values[ the_api ] = NULL;
- #if defined(RTEMS_DEBUG)
- * Since the removal of ITRON, this cannot occur.
- if ( !_Objects_Information_table[ the_api ] )
- continue;
- * Currently all managers are installed if the API is installed.
- * This would be a horrible implementation error.
- if (_Objects_Information_table[ the_api ][ 1 ] == NULL )
- _Internal_error_Occurred(
- INTERNAL_ERROR_CORE,
- true,
- INTERNAL_ERROR_IMPLEMENTATION_KEY_CREATE_INCONSISTENCY
- #endif
- bytes_to_allocate = sizeof( void * ) *
- (_Objects_Information_table[ the_api ][ 1 ]->maximum + 1);
- table = _Workspace_Allocate( bytes_to_allocate );
- if ( !table ) {
- _POSIX_Keys_Free_memory( the_key );
- _POSIX_Keys_Free( the_key );
- _Thread_Enable_dispatch();
- return ENOMEM;
- the_key->Values[ the_api ] = table;
- memset( table, '\0', bytes_to_allocate );
_Objects_Open_u32( &_POSIX_Keys_Information, &the_key->Object, 0 );
*key = the_key->Object.id;
diff --git a/cpukit/posix/src/keydelete.c b/cpukit/posix/src/keydelete.c
index 5ef6261..ae15b7f 100644
--- a/cpukit/posix/src/keydelete.c
+++ b/cpukit/posix/src/keydelete.c
@@ -42,8 +42,6 @@ int pthread_key_delete(
switch ( location ) {
case OBJECTS_LOCAL:
- _Objects_Close( &_POSIX_Keys_Information, &the_key->Object );
@@ -51,6 +49,7 @@ int pthread_key_delete(
* of the application to free the memory.
+ _Objects_Close( &_POSIX_Keys_Information, &the_key->Object );
return 0;
diff --git a/cpukit/posix/src/keyfreememory.c b/cpukit/posix/src/keyfreememory.c
index f71af4f..5f7764b 100644
--- a/cpukit/posix/src/keyfreememory.c
+++ b/cpukit/posix/src/keyfreememory.c
@@ -21,14 +21,43 @@
void _POSIX_Keys_Free_memory(
- uint32_t the_api;
+ POSIX_Keys_Rbtree_node search_node;
+ POSIX_Keys_Rbtree_node *p;
+ RBTree_Node *iter, *next;
- _Workspace_Free( the_key->Values[ the_api ] );
+ search_node.key = the_key->Object.id;
+ search_node.thread_id = 0;
+ iter = _RBTree_Find_unprotected( &_POSIX_Keys_Rbtree, &search_node.rb_node);
+ if ( !iter )
+ return;
+ * find the smallest thread_id node in the rbtree.
+ next = _RBTree_Next_unprotected( iter, RBT_LEFT );
+ p = _RBTree_Container_of( next, POSIX_Keys_Rbtree_node, rb_node );
+ while ( p->key == the_key->Object.id) {
+ iter = next;
+ * delete all nodes belongs to the_key from the rbtree and chain.
+ p = _RBTree_Container_of( iter, POSIX_Keys_Rbtree_node, rb_node );
+ while ( p->key == the_key->Object.id ) {
+ next = _RBTree_Next_unprotected( iter, RBT_RIGHT );
+ _RBTree_Extract_unprotected( &_POSIX_Keys_Rbtree, iter );
+ _Chain_Extract_unprotected( &p->ch_node );
+ _Workspace_Free( p );
+ iter = next;
diff --git a/cpukit/posix/src/keygetspecific.c b/cpukit/posix/src/keygetspecific.c
index debad83..eafa0ea 100644
--- a/cpukit/posix/src/keygetspecific.c
+++ b/cpukit/posix/src/keygetspecific.c
@@ -26,6 +26,7 @@
@@ -36,19 +37,24 @@ void *pthread_getspecific(
pthread_key_t key
- register POSIX_Keys_Control *the_key;
- uint32_t api;
- uint32_t index;
Objects_Locations location;
+ RBTree_Node *p;
void *key_data;
- the_key = _POSIX_Keys_Get( key, &location );
+ _POSIX_Keys_Get( key, &location );
case OBJECTS_LOCAL:
- api = _Objects_Get_API( _Thread_Executing->Object.id );
- index = _Objects_Get_index( _Thread_Executing->Object.id );
- key_data = (void *) the_key->Values[ api ][ index ];
+ search_node.key = key;
+ search_node.thread_id = _Thread_Executing->Object.id;
+ p = _RBTree_Find_unprotected( &_POSIX_Keys_Rbtree, &search_node.rb_node);
+ key_data = NULL;
+ if ( p ) {
+ key_data = _RBTree_Container_of( p,
+ rb_node )->value;
return key_data;
diff --git a/cpukit/posix/src/keyrundestructors.c b/cpukit/posix/src/keyrundestructors.c
index 9f48888..a6e1090 100644
--- a/cpukit/posix/src/keyrundestructors.c
+++ b/cpukit/posix/src/keyrundestructors.c
@@ -23,7 +23,10 @@
+#include <rtems/score/wkspace.h>
+#include <rtems/posix/threadsup.h>
* _POSIX_Keys_Run_destructors
@@ -38,36 +41,46 @@ void _POSIX_Keys_Run_destructors(
Thread_Control *thread
- Objects_Maximum thread_index = _Objects_Get_index( thread->Object.id );
- Objects_APIs thread_api = _Objects_Get_API( thread->Object.id );
- bool done = false;
+ Chain_Control *chain;
+ Chain_Node *iter, *next;
+ void *value;
+ POSIX_Keys_Control *the_key;
+ Objects_Locations location;
- * The standard allows one to avoid a potential infinite loop and limit the
- * number of iterations. An infinite loop may happen if destructors set
- * thread specific data. This can be considered dubious.
- * Reference: 17.1.1.2 P1003.1c/Draft 10, p. 163, line 99.
- while ( !done ) {
- Objects_Maximum index = 0;
- Objects_Maximum max = _POSIX_Keys_Information.maximum;
+ _Thread_Disable_dispatch();
- done = true;
+ chain = &((POSIX_API_Control *)\
+ thread->API_Extensions[ THREAD_API_POSIX ])->Key_Chain;
+ iter = _Chain_First( chain );
+ while ( !_Chain_Is_tail( chain, iter ) ) {
+ next = _Chain_Next( iter );
+ * remove key from rbtree and chain.
+ * here Chain_Node *iter can be convert to POSIX_Keys_Rbtree_node *,
+ * because Chain_Node is the first member of POSIX_Keys_Rbtree_node
+ * structure.
+ &((POSIX_Keys_Rbtree_node *)iter)->rb_node );
+ _Chain_Extract_unprotected( iter );
- for ( index = 1 ; index <= max ; ++index ) {
- POSIX_Keys_Control *key = (POSIX_Keys_Control *)
- _POSIX_Keys_Information.local_table [ index ];
+ * run key value's destructor if destructor and value are both non-null.
+ the_key = _POSIX_Keys_Get( ((POSIX_Keys_Rbtree_node *)iter)->key,
+ &location);
+ destructor = the_key->destructor;
+ value = ((POSIX_Keys_Rbtree_node *)iter)->value;
+ if ( destructor != NULL && value != NULL )
+ (*destructor)( value );
+ * disable dispatch is nested here
+ _Thread_Enable_dispatch();
- if ( key != NULL && key->destructor != NULL ) {
- void *value = key->Values [ thread_api ][ thread_index ];
- if ( value != NULL ) {
- key->Values [ thread_api ][ thread_index ] = NULL;
- (*key->destructor)( value );
- done = false;
+ _Workspace_Free( (POSIX_Keys_Rbtree_node *)iter );
+ iter = next;
diff --git a/cpukit/posix/src/keysetspecific.c b/cpukit/posix/src/keysetspecific.c
index b25e44c..eae1917 100644
--- a/cpukit/posix/src/keysetspecific.c
+++ b/cpukit/posix/src/keysetspecific.c
@@ -26,7 +26,9 @@
* 17.1.2 Thread-Specific Data Management, P1003.1c/Draft 10, p. 165
@@ -37,18 +39,35 @@ int pthread_setspecific(
const void *value
- uint32_t api;
- uint32_t index;
+ POSIX_Keys_Rbtree_node *rb_node;
+ POSIX_API_Control *api;
case OBJECTS_LOCAL:
- the_key->Values[ api ][ index ] = (void *) value;
+ rb_node = _Workspace_Allocate( sizeof( POSIX_Keys_Rbtree_node ) );
+ if ( !rb_node ) {
+ return ENOMEM;
+ rb_node->key = key;
+ rb_node->thread_id = _Thread_Executing->Object.id;
+ rb_node->value = value;
+ if (_RBTree_Insert_unprotected( &_POSIX_Keys_Rbtree,
+ &(rb_node->rb_node) ) ) {
+ _Workspace_Free( rb_node );
+ return EAGAIN;
+ /** append rb_node to the thread API extension's chain */
+ api = (POSIX_API_Control *)\
+ (_Thread_Executing->API_Extensions[THREAD_API_POSIX]);
+ _Chain_Append_unprotected( &api->Key_Chain, &rb_node->ch_node );
return 0;
diff --git a/cpukit/posix/src/pthread.c b/cpukit/posix/src/pthread.c
index 873449a..0ea44f1 100644
--- a/cpukit/posix/src/pthread.c
+++ b/cpukit/posix/src/pthread.c
@@ -234,6 +234,9 @@ static bool _POSIX_Threads_Create_extension(
created
+ /** initialize thread's key vaule node chain */
+ _Chain_Initialize_empty( &api->Key_Chain );
return true;
1.7.1
