[PATCH] confdefs: update the CONFIGURE_MEMORY_FOR_POSIX_KEYS for rbtree version.
Wed Mar 6 15:05:39 UTC 2013
I see. So your solution is to add another CONFIGURE option that lets a
user specify the total number of specific keys that might be needed,
i.e. the number of rbtree nodes that can maximally be allocated. I
think this is a fine solution. In the worst case it would still be
threads*keys, but a user can override it. Also, I guess it needs to be
the total threads and not just the pthreads.
Is it possible for an application developer to know some temporal
properties about the keys that lets them have key_pairs < keys? For
example, I might have two keys and one thread, and I could know that
at any time in my program, the thread only uses one of the keys? In
that case, the key_pairs can be 1? Or is that too far fetched?
-Gedare
On Wed, Mar 6, 2013 at 9:37 AM, Ashi <ashi08104 at gmail.com> wrote:
> Gedare, I'm very sorry to find(just now) there is some work hasn't been
> included in this patch, it is exactly related to confdefs.h,
> because use thread*keys to caculate memory is not very accurate, I introduce
> a key_pair
> variable(http://www.rtems.org/wiki/index.php/Use_Hash_or_Map_in_POSIX_Key),
> there are several commits on my
> github(https://github.com/ashi08104/rtems/commits/one_rbtree, commits after
> Aug 28,2012 are related). I'll update the patch as soon as possible.
> On Wed, Mar 6, 2013 at 6:12 AM, Gedare Bloom <gedare at rtems.org> wrote:
>>  cpukit/sapi/include/confdefs.h |    7 ++++++-
>>  1 files changed, 6 insertions(+), 1 deletions(-)
>> diff --git a/cpukit/sapi/include/confdefs.h
>> b/cpukit/sapi/include/confdefs.h
>> index cc55e92..fcfdb44 100644
>> --- a/cpukit/sapi/include/confdefs.h
>> +++ b/cpukit/sapi/include/confdefs.h
>> @@ -1713,7 +1713,12 @@ rtems_fs_init_functions_t    rtems_fs_init_helper =
>>    #else
>>      #define CONFIGURE_MEMORY_FOR_POSIX_KEYS(_keys) \
>>        (_Configure_Object_RAM(_keys, sizeof(POSIX_Keys_Control) ) \
>> -        + (_keys) * 3 * _Configure_From_workspace(sizeof(void *) * 2))
>> +        + _Configure_From_workspace( \
>> +          _Configure_Max_Objects(CONFIGURE_MAXIMUM_POSIX_THREADS) \
>> +          * _Configure_Max_Objects(_keys) \
>> +          * sizeof(POSIX_Keys_Rbtree_node) \
>>    #endif
>>    #ifndef CONFIGURE_MAXIMUM_POSIX_TIMERS
>> 1.7.1
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
