[rtems commit] sparc/cpu.h: Add comments
Mon Mar 18 18:14:28 UTC 2013
On 3/18/2013 1:05 PM, Gedare Bloom wrote:
> Why is your comment a question?
Most of the CPU port comment blocks are questions about the parameter
and a description of that parameter. This is followed by a port specific
answer.
I didn't know the best way to phrase the answer.  [And I wanted to get
this patch off my microblaze branch.]
I think Sebastian added this definition to every port with no comment
block.  If you like, I can propagate the question to all ports with an
answer like:
The size of a pointer (e.g. void *) is always XXX bytes.
OR
The size of a pointer (e.g. void *) is varies based upon the multilib
variant. For X and Y, it is NNN bytes. For all others, it is MMM bytes.
Are those viable options?
--joel
On Mon, Mar 18, 2013 at 12:36 PM, Joel Sherrill <joel at rtems.org> wrote:
>> Module:    rtems
>> Branch:    master
>> Commit:    af99ec255b904d1c04e52b994b49d613476829bb
>> Changeset: http://git.rtems.org/rtems/commit/?id=af99ec255b904d1c04e52b994b49d613476829bb
>> Author:    Joel Sherrill <joel.sherrill at oarcorp.com>
>> Date:      Tue Mar 12 10:15:47 2013 -0500
>>   cpukit/score/cpu/sparc/rtems/score/cpu.h |    3 +++
>>   1 files changed, 3 insertions(+), 0 deletions(-)
>> diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
>> index 6102355..b95d411 100644
>> --- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
>> +++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
>> @@ -877,6 +877,9 @@ extern const CPU_Trap_table_entry _CPU_Trap_slot_template;
>>   #define CPU_STACK_MINIMUM_SIZE  (1024*4)
>> + * What is the size of a pointer on this architecture?
>>   #define CPU_SIZEOF_POINTER 4
>> rtems-vc mailing list
>> rtems-vc at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-vc
> rtems-devel mailing list
> rtems-devel at rtems.org
