network-demos
Claus, Ric claus at slac.stanford.edu
Mon Mar 18 23:45:58 UTC 2013
Hi Cynthia,
  Thanks very much!  That helps a whole lot!  I had done the 'find' but neglected the trailing '\*', and didn't think to look in the install directory.
  Knowing that setting RTEMS_MAKEFILE_PATH is the only additional thing I need to do before 'make' is also a good thing.  Unfortunately, it hits the wall pretty quickly with "init.c:158:7: error: too few arguments to function 'mg_start'" in http/, but I can sort that out later.
  Thanks for the help.  I really appreciate it.
	Cheers,
			Ric
On Mar 18, 2013, at 4:23 PM, Rempel, Cynthia wrote:
> Hi Ric Claus,
> In my prefix directory I ran
> find -name Makefile.inc
> and got
> ./sparc-rtems4.11/sis/Makefile.inc
> ./sparc-rtems4.11/leon3/Makefile.inc
> I was messing with some build variables, so you may need to run find as well
> In my rtems directory I ran
> find -name Makefile.inc\*
> and got
> ./c/src/make/Makefile.inc.in
> I never tried checking out an RTEMS application in the source tree, (it might work...) usually I check it out in the same directory like this:
> ~/rtems
> ~/network-demos
> ... but I think you could check it out wherever you'd like (probably not in the rtems tree though).
> To build the network-demos:
> cd network-demos
> export RTEMS_MAKEFILE_PATH=/opt/rtems-4.11/i386-rtems4.11/pc386/
> make
> I'm not sure which version of network-demos would be the best though... that's a really good question!
> Hope this helps!
> Cynthia Rempel
> ________________________________________
> From: rtems-devel-bounces at rtems.org [rtems-devel-bounces at rtems.org] on behalf of Claus, Ric [claus at slac.stanford.edu]
> Sent: Monday, March 18, 2013 1:32 PM
> To: RTEMS
> Subject: network-demos
> Can someone please tell me how to build the network-demos that I find on RTEMS git site?  It's probably obvious, but can't seem to find Makefile.inc.  I'd prefer to do this in conjunction with 4.11, but 4.10.2 might also work.
> Is there any particular place (e.g. somewhere in the RTEMS tree) where I should check-out network-demos into?
> I see several copies of network-demos on the git site, of which Joel's seems the most recently updated.  Is it better to grab that or or another one?
> Why?  I'd like to use some of this code to debug an ethernet driver.  Along these lines, it might be nice to take a look at libbsdport or rtems-libbsd.git at some point, too, so I would be grateful for any pointers along those lines, too.
>        Thanks,
>                        Ric
> rtems-devel mailing list
> rtems-devel at rtems.org
