[PATCH 2/2] [cpukit/POSIX] Renamed POSIX signal functions to match style of the other POSIX related functions
Andreas Heinig andreas.heinig at cs.tu-dortmund.de
Tue Mar 19 13:48:25 UTC 2013
 cpukit/ChangeLog                                |    8 +--
 cpukit/posix/include/rtems/posix/psignalimpl.h  |   46 ++++++++---------
 cpukit/posix/src/alarm.c                        |    8 +--
 cpukit/posix/src/killinfo.c                     |   22 ++++-----
 cpukit/posix/src/psignal.c                      |   60 +++++++++++------------
 cpukit/posix/src/psignalchecksignal.c           |   18 +++----
 cpukit/posix/src/psignalclearprocesssignals.c   |   10 ++--
 cpukit/posix/src/psignalclearsignals.c          |   16 +++---
 cpukit/posix/src/psignalsetprocesssignals.c     |    4 +-
 cpukit/posix/src/psignalunblockthread.c         |    2 +-
 cpukit/posix/src/pthreadkill.c                  |    6 +--
 cpukit/posix/src/pthreadsigmask.c               |    2 +-
 cpukit/posix/src/sigaction.c                    |    8 +--
 cpukit/posix/src/sigpending.c                   |    2 +-
 cpukit/posix/src/sigtimedwait.c                 |   20 ++++----
 cpukit/posix/src/ualarm.c                       |   10 ++--
 cpukit/sapi/src/posixapi.c                      |    2 +-
 testsuites/psxtests/ChangeLog                   |    2 +-
 testsuites/psxtests/psx15/init.c                |    2 +-
 testsuites/psxtests/psxsignal01/init.c          |    4 +-
 testsuites/psxtests/psxsignal05/init.c          |    6 +--
 testsuites/psxtests/psxsignal05/psxsignal05.doc |    2 +-
 testsuites/psxtests/psxsignal05/psxsignal05.scn |    2 +-
 testsuites/psxtests/psxualarm/init.c            |    2 +-
 24 files changed, 132 insertions(+), 132 deletions(-)
diff --git a/cpukit/ChangeLog b/cpukit/ChangeLog
index 5c8e2b1..358b42d 100644
--- a/cpukit/ChangeLog
+++ b/cpukit/ChangeLog
@@ -101,7 +101,7 @@
 2011-12-10	Ralf Corsépius <ralf.corsepius at rtems.org>
-	* posix/src/sigtimedwait.c: Make _POSIX_signals_Get_lowest static.
+	* posix/src/sigtimedwait.c: Make _POSIX_Signals_Get_lowest static.
 2011-12-09	Joel Sherrill <joel.sherrill at oarcorp.com>
@@ -744,10 +744,10 @@
 	Comment out unused vars "group", "group_base".
 	* libmisc/monitor/mon-editor.c (rtems_monitor_task):
 	Comment out unused vars "debugee", "rp", "fp".
-	* posix/src/alarm.c: Make _POSIX_signals_Alarm_TSR static.
+	* posix/src/alarm.c: Make _POSIX_Signals_Alarm_TSR static.
 	Remove unused var "status".
 	* libmisc/shell/main_ls.c: Comment out unused var kflag.
-	* posix/src/ualarm.c: Make _POSIX_signals_Ualarm_TSR static.
+	* posix/src/ualarm.c: Make _POSIX_Signals_Ualarm_TSR static.
 2011-10-12	Ralf Corsépius <ralf.corsepius at rtems.org>
@@ -7393,7 +7393,7 @@
 2009-08-05	Joel Sherrill <joel.sherrill at oarcorp.com>
-	* posix/src/sigaction.c: _POSIX_signals_Clear_process_signals now takes
+	* posix/src/sigaction.c: _POSIX_Signals_Clear_process_signals now takes
 	signal number not mask.
 2009-08-05	Joel Sherrill <joel.sherrill at OARcorp.com>
diff --git a/cpukit/posix/include/rtems/posix/psignalimpl.h b/cpukit/posix/include/rtems/posix/psignalimpl.h
index 481a7ea..334c2fa 100644
--- a/cpukit/posix/include/rtems/posix/psignalimpl.h
+++ b/cpukit/posix/include/rtems/posix/psignalimpl.h
@@ -39,13 +39,13 @@
       (STATES_WAITING_FOR_SIGNAL|STATES_INTERRUPTIBLE_BY_SIGNAL))
 #define SIGACTION_TERMINATE \
-  { 0, SIGNAL_ALL_MASK, {_POSIX_signals_Abnormal_termination_handler} }
+  { 0, SIGNAL_ALL_MASK, {_POSIX_Signals_Abnormal_termination_handler} }
 #define SIGACTION_IGNORE \
   { 0, SIGNAL_ALL_MASK, {SIG_IGN} }
 #define SIGACTION_STOP \
-  { 0, SIGNAL_ALL_MASK, {_POSIX_signals_Stop_handler} }
+  { 0, SIGNAL_ALL_MASK, {_POSIX_Signals_Stop_handler} }
 #define SIGACTION_CONTINUE \
-  { 0, SIGNAL_ALL_MASK, {_POSIX_signals_Continue_handler} }
+  { 0, SIGNAL_ALL_MASK, {_POSIX_Signals_Continue_handler} }
 #define SIG_ARRAY_MAX  (SIGRTMAX + 1)
@@ -53,23 +53,23 @@
  *  Variables
-extern sigset_t  _POSIX_signals_Pending;
+extern sigset_t  _POSIX_Signals_Pending;
-extern const struct sigaction _POSIX_signals_Default_vectors[ SIG_ARRAY_MAX ];
+extern const struct sigaction _POSIX_Signals_Default_vectors[ SIG_ARRAY_MAX ];
-extern struct sigaction _POSIX_signals_Vectors[ SIG_ARRAY_MAX ];
+extern struct sigaction _POSIX_Signals_Vectors[ SIG_ARRAY_MAX ];
-extern Watchdog_Control _POSIX_signals_Alarm_timer;
+extern Watchdog_Control _POSIX_Signals_Alarm_timer;
-extern Watchdog_Control _POSIX_signals_Ualarm_timer;
+extern Watchdog_Control _POSIX_Signals_Ualarm_timer;
-extern Thread_queue_Control _POSIX_signals_Wait_queue;
+extern Thread_queue_Control _POSIX_Signals_Wait_queue;
-extern Chain_Control _POSIX_signals_Inactive_siginfo;
+extern Chain_Control _POSIX_Signals_Inactive_siginfo;
-extern Chain_Control _POSIX_signals_Siginfo[ SIG_ARRAY_MAX ];
+extern Chain_Control _POSIX_Signals_Siginfo[ SIG_ARRAY_MAX ];
-extern API_extensions_Post_switch_control _POSIX_signals_Post_switch;
+extern API_extensions_Post_switch_control _POSIX_Signals_Post_switch;
  *  Internal routines
@@ -78,11 +78,11 @@ extern API_extensions_Post_switch_control _POSIX_signals_Post_switch;
  * @brief POSIX signals manager initialization.
-void _POSIX_signals_Manager_Initialization(void);
+void _POSIX_Signals_Manager_initialization(void);
-static inline void _POSIX_signals_Add_post_switch_extension(void)
+static inline void _POSIX_Signals_Add_post_switch_extension(void)
-  _API_extensions_Add_post_switch( &_POSIX_signals_Post_switch );
+  _API_extensions_Add_post_switch( &_POSIX_Signals_Post_switch );
@@ -90,7 +90,7 @@ static inline void _POSIX_signals_Add_post_switch_extension(void)
  * XXX this routine could probably be cleaned up
-bool _POSIX_signals_Unblock_thread(
+bool _POSIX_Signals_Unblock_thread(
   Thread_Control  *the_thread,
   int              signo,
   siginfo_t       *info
@@ -99,7 +99,7 @@ bool _POSIX_signals_Unblock_thread(
  *  @brief Check POSIX signal.
-bool _POSIX_signals_Check_signal(
+bool _POSIX_Signals_Check_signal(
   POSIX_API_Control  *api,
   int                 signo,
   bool                is_global
@@ -108,7 +108,7 @@ bool _POSIX_signals_Check_signal(
  * @brief Clear POSIX signals.
-bool _POSIX_signals_Clear_signals(
+bool _POSIX_Signals_Clear_signals(
   int                 signo,
   siginfo_t          *info,
@@ -125,11 +125,11 @@ int killinfo(
  *  @brief Set POSIX process signals.
-void _POSIX_signals_Set_process_signals(
+void _POSIX_Signals_Set_process_signals(
   sigset_t   mask
-void _POSIX_signals_Clear_process_signals(
+void _POSIX_Signals_Clear_process_signals(
   int        signo
@@ -137,10 +137,10 @@ void _POSIX_signals_Clear_process_signals(
  *  Default signal handlers
-#define _POSIX_signals_Stop_handler NULL
-#define _POSIX_signals_Continue_handler NULL
+#define _POSIX_Signals_Stop_handler NULL
+#define _POSIX_Signals_Continue_handler NULL
-void _POSIX_signals_Abnormal_termination_handler( int signo );
+void _POSIX_Signals_Abnormal_termination_handler( int signo );
diff --git a/cpukit/posix/src/alarm.c b/cpukit/posix/src/alarm.c
index 5130b01..bbe45cb 100644
--- a/cpukit/posix/src/alarm.c
+++ b/cpukit/posix/src/alarm.c
@@ -28,10 +28,10 @@
 #include <rtems/posix/psignalimpl.h>
- *  _POSIX_signals_Alarm_TSR
+ *  _POSIX_Signals_Alarm_TSR
-static void _POSIX_signals_Alarm_TSR(
+static void _POSIX_Signals_Alarm_TSR(
   Objects_Id      id __attribute__((unused)),
   void           *argument __attribute__((unused))
@@ -47,14 +47,14 @@ unsigned int alarm(
   unsigned int      remaining = 0;
   Watchdog_Control *the_timer;
-  the_timer = &_POSIX_signals_Alarm_timer;
+  the_timer = &_POSIX_Signals_Alarm_timer;
    *  Initialize the timer used to implement alarm().
   if ( !the_timer->routine ) {
-    _Watchdog_Initialize( the_timer, _POSIX_signals_Alarm_TSR, 0, NULL );
+    _Watchdog_Initialize( the_timer, _POSIX_Signals_Alarm_TSR, 0, NULL );
   } else {
     Watchdog_States state;
diff --git a/cpukit/posix/src/killinfo.c b/cpukit/posix/src/killinfo.c
index f386757..c2b1967 100644
--- a/cpukit/posix/src/killinfo.c
+++ b/cpukit/posix/src/killinfo.c
@@ -51,7 +51,7 @@
  *  NOTE: Behavior of kill() depends on _POSIX_SAVED_IDS.
-#define _POSIX_signals_Is_interested( _api, _mask ) \
+#define _POSIX_Signals_Is_interested( _api, _mask ) \
   ( ~(_api)->signals_blocked & (_mask) )
 int killinfo(
@@ -94,7 +94,7 @@ int killinfo(
    *  If the signal is being ignored, then we are out of here.
-  if ( _POSIX_signals_Vectors[ sig ].sa_handler == SIG_IGN )
+  if ( _POSIX_Signals_Vectors[ sig ].sa_handler == SIG_IGN )
     return 0;
@@ -121,7 +121,7 @@ int killinfo(
   _Thread_Disable_dispatch();
-  _POSIX_signals_Add_post_switch_extension();
+  _POSIX_Signals_Add_post_switch_extension();
    *  Is the currently executing thread interested?  If so then it will
@@ -130,7 +130,7 @@ int killinfo(
   the_thread = _Thread_Executing;
   api = the_thread->API_Extensions[ THREAD_API_POSIX ];
-  if ( _POSIX_signals_Is_interested( api, mask ) ) {
+  if ( _POSIX_Signals_Is_interested( api, mask ) ) {
     goto process_it;
@@ -142,7 +142,7 @@ int killinfo(
   /* XXX violation of visibility -- need to define thread queue support */
-  the_chain = &_POSIX_signals_Wait_queue.Queues.Fifo;
+  the_chain = &_POSIX_Signals_Wait_queue.Queues.Fifo;
   for ( the_node = _Chain_First( the_chain );
         !_Chain_Is_tail( the_chain, the_node ) ;
@@ -244,7 +244,7 @@ int killinfo(
           continue;
       #endif
-      if ( !_POSIX_signals_Is_interested( api, mask ) )
+      if ( !_POSIX_Signals_Is_interested( api, mask ) )
         continue;
       DEBUG_STEP("3");
@@ -325,7 +325,7 @@ process_it:
    *  Returns true if the signal was synchronously given to a thread
    *  blocked waiting for the signal.
-  if ( _POSIX_signals_Unblock_thread( the_thread, sig, siginfo ) ) {
+  if ( _POSIX_Signals_Unblock_thread( the_thread, sig, siginfo ) ) {
     _Thread_Enable_dispatch();
     return 0;
@@ -336,12 +336,12 @@ post_process_signal:
    *  We may have woken up a thread but we definitely need to post the
    *  signal to the process wide information set.
-  _POSIX_signals_Set_process_signals( mask );
+  _POSIX_Signals_Set_process_signals( mask );
-  if ( _POSIX_signals_Vectors[ sig ].sa_flags == SA_SIGINFO ) {
+  if ( _POSIX_Signals_Vectors[ sig ].sa_flags == SA_SIGINFO ) {
     psiginfo = (POSIX_signals_Siginfo_node *)
-               _Chain_Get( &_POSIX_signals_Inactive_siginfo );
+               _Chain_Get( &_POSIX_Signals_Inactive_siginfo );
     if ( !psiginfo ) {
       rtems_set_errno_and_return_minus_one( EAGAIN );
@@ -349,7 +349,7 @@ post_process_signal:
     psiginfo->Info = *siginfo;
-    _Chain_Append( &_POSIX_signals_Siginfo[ sig ], &psiginfo->Node );
+    _Chain_Append( &_POSIX_Signals_Siginfo[ sig ], &psiginfo->Node );
   DEBUG_STEP("\n");
diff --git a/cpukit/posix/src/psignal.c b/cpukit/posix/src/psignal.c
index e490877..fbd0dd9 100644
--- a/cpukit/posix/src/psignal.c
+++ b/cpukit/posix/src/psignal.c
@@ -42,16 +42,16 @@
 /*** PROCESS WIDE STUFF ****/
-sigset_t  _POSIX_signals_Pending;
+sigset_t  _POSIX_Signals_Pending;
   int signo __attribute__((unused)) )
   exit( 1 );
-const struct sigaction _POSIX_signals_Default_vectors[ SIG_ARRAY_MAX ] = {
+const struct sigaction _POSIX_Signals_Default_vectors[ SIG_ARRAY_MAX ] = {
   /* NO SIGNAL 0 */  SIGACTION_IGNORE,
   /* SIGHUP    1 */  SIGACTION_TERMINATE,
   /* SIGINT    2 */  SIGACTION_TERMINATE,
@@ -87,15 +87,15 @@ const struct sigaction _POSIX_signals_Default_vectors[ SIG_ARRAY_MAX ] = {
   /* SIGRTMAX 31 */  SIGACTION_TERMINATE
-struct sigaction _POSIX_signals_Vectors[ SIG_ARRAY_MAX ];
+struct sigaction _POSIX_Signals_Vectors[ SIG_ARRAY_MAX ];
-Thread_queue_Control _POSIX_signals_Wait_queue;
+Thread_queue_Control _POSIX_Signals_Wait_queue;
-Chain_Control _POSIX_signals_Inactive_siginfo;
-Chain_Control _POSIX_signals_Siginfo[ SIG_ARRAY_MAX ];
+Chain_Control _POSIX_Signals_Inactive_siginfo;
+Chain_Control _POSIX_Signals_Siginfo[ SIG_ARRAY_MAX ];
-Watchdog_Control _POSIX_signals_Alarm_timer;
-Watchdog_Control _POSIX_signals_Ualarm_timer;
+Watchdog_Control _POSIX_Signals_Alarm_timer;
+Watchdog_Control _POSIX_Signals_Ualarm_timer;
  *  XXX - move these
@@ -107,10 +107,10 @@ Watchdog_Control _POSIX_signals_Ualarm_timer;
- *  _POSIX_signals_Post_switch_extension
+ *  _POSIX_Signals_Post_switch_extension
-static void _POSIX_signals_Post_switch_hook(
+static void _POSIX_Signals_Post_switch_hook(
@@ -144,32 +144,32 @@ static void _POSIX_signals_Post_switch_hook(
   while (1) {
     _ISR_Disable( level );
       if ( !(~api->signals_blocked &
-            (api->signals_pending | _POSIX_signals_Pending)) ) {
+            (api->signals_pending | _POSIX_Signals_Pending)) ) {
        _ISR_Enable( level );
        break;
     for ( signo = SIGRTMIN ; signo <= SIGRTMAX ; signo++ ) {
-      _POSIX_signals_Check_signal( api, signo, false );
-      _POSIX_signals_Check_signal( api, signo, true );
+      _POSIX_Signals_Check_signal( api, signo, false );
+      _POSIX_Signals_Check_signal( api, signo, true );
     /* Unfortunately - nothing like __SIGFIRSTNOTRT in newlib signal .h */
     for ( signo = SIGHUP ; signo <= __SIGLASTNOTRT ; signo++ ) {
   _Thread_Executing->Wait.return_code = hold_errno;
-API_extensions_Post_switch_control _POSIX_signals_Post_switch = {
-  .hook = _POSIX_signals_Post_switch_hook
+API_extensions_Post_switch_control _POSIX_Signals_Post_switch = {
+  .hook = _POSIX_Signals_Post_switch_hook
   uint32_t   signo;
   uint32_t   maximum_queued_signals;
@@ -182,26 +182,26 @@ void _POSIX_signals_Manager_Initialization(void)
   #if defined(RTEMS_DEBUG)
     assert(
-     sizeof(_POSIX_signals_Vectors) == sizeof(_POSIX_signals_Default_vectors)
+     sizeof(_POSIX_Signals_Vectors) == sizeof(_POSIX_Signals_Default_vectors)
   #endif
   memcpy(
-    _POSIX_signals_Vectors,
-    _POSIX_signals_Default_vectors,
-    sizeof( _POSIX_signals_Vectors )
+    _POSIX_Signals_Vectors,
+    _POSIX_Signals_Default_vectors,
+    sizeof( _POSIX_Signals_Vectors )
    *  Initialize the set of pending signals for the entire process
-  sigemptyset( &_POSIX_signals_Pending );
+  sigemptyset( &_POSIX_Signals_Pending );
    *  Initialize the queue we use to block for signals
   _Thread_queue_Initialize(
-    &_POSIX_signals_Wait_queue,
+    &_POSIX_Signals_Wait_queue,
     THREAD_QUEUE_DISCIPLINE_FIFO,
     STATES_WAITING_FOR_SIGNAL | STATES_INTERRUPTIBLE_BY_SIGNAL,
     EAGAIN
@@ -213,11 +213,11 @@ void _POSIX_signals_Manager_Initialization(void)
    *  Allocate the siginfo pools.
   for ( signo=1 ; signo<= SIGRTMAX ; signo++ )
-    _Chain_Initialize_empty( &_POSIX_signals_Siginfo[ signo ] );
+    _Chain_Initialize_empty( &_POSIX_Signals_Siginfo[ signo ] );
   if ( maximum_queued_signals ) {
     _Chain_Initialize(
-      &_POSIX_signals_Inactive_siginfo,
+      &_POSIX_Signals_Inactive_siginfo,
       _Workspace_Allocate_or_fatal_error(
         maximum_queued_signals * sizeof( POSIX_signals_Siginfo_node )
@@ -225,12 +225,12 @@ void _POSIX_signals_Manager_Initialization(void)
   } else {
-    _Chain_Initialize_empty( &_POSIX_signals_Inactive_siginfo );
+    _Chain_Initialize_empty( &_POSIX_Signals_Inactive_siginfo );
    *  Initialize the Alarm Timer
-  _Watchdog_Initialize( &_POSIX_signals_Alarm_timer, NULL, 0, NULL );
-  _Watchdog_Initialize( &_POSIX_signals_Ualarm_timer, NULL, 0, NULL );
+  _Watchdog_Initialize( &_POSIX_Signals_Alarm_timer, NULL, 0, NULL );
+  _Watchdog_Initialize( &_POSIX_Signals_Ualarm_timer, NULL, 0, NULL );
diff --git a/cpukit/posix/src/psignalchecksignal.c b/cpukit/posix/src/psignalchecksignal.c
index 57237d3..f2c0e1b 100644
--- a/cpukit/posix/src/psignalchecksignal.c
+++ b/cpukit/posix/src/psignalchecksignal.c
@@ -38,7 +38,7 @@
 #include <rtems/posix/time.h>
   int                 signo,
   bool                is_global
@@ -48,7 +48,7 @@ bool    _POSIX_signals_Check_signal(
   sigset_t                    saved_signals_blocked;
   Thread_Wait_information     stored_thread_wait_information;
-  if ( ! _POSIX_signals_Clear_signals( api, signo, &siginfo_struct,
+  if ( ! _POSIX_Signals_Clear_signals( api, signo, &siginfo_struct,
                                        is_global, true ) )
     return false;
@@ -57,21 +57,21 @@ bool    _POSIX_signals_Check_signal(
    *  safer.
-    assert( _POSIX_signals_Vectors[ signo ].sa_handler ||
-            _POSIX_signals_Vectors[ signo ].sa_sigaction );
+    assert( _POSIX_Signals_Vectors[ signo ].sa_handler ||
+            _POSIX_Signals_Vectors[ signo ].sa_sigaction );
   #endif
    *  Just to prevent sending a signal which is currently being ignored.
-  if ( _POSIX_signals_Vectors[ signo ].sa_handler == SIG_IGN )
+  if ( _POSIX_Signals_Vectors[ signo ].sa_handler == SIG_IGN )
     return false;
    *  Block the signals requested in sa_mask
   saved_signals_blocked = api->signals_blocked;
-  api->signals_blocked |= _POSIX_signals_Vectors[ signo ].sa_mask;
+  api->signals_blocked |= _POSIX_Signals_Vectors[ signo ].sa_mask;
    *  We have to save the blocking information of the current wait queue
@@ -84,16 +84,16 @@ bool    _POSIX_signals_Check_signal(
    *  Here, the signal handler function executes
-  switch ( _POSIX_signals_Vectors[ signo ].sa_flags ) {
+  switch ( _POSIX_Signals_Vectors[ signo ].sa_flags ) {
     case SA_SIGINFO:
-      (*_POSIX_signals_Vectors[ signo ].sa_sigaction)(
+      (*_POSIX_Signals_Vectors[ signo ].sa_sigaction)(
         signo,
         &siginfo_struct,
         NULL        /* context is undefined per 1003.1b-1993, p. 66 */
       break;
     default:
-      (*_POSIX_signals_Vectors[ signo ].sa_handler)( signo );
+      (*_POSIX_Signals_Vectors[ signo ].sa_handler)( signo );
       break;
diff --git a/cpukit/posix/src/psignalclearprocesssignals.c b/cpukit/posix/src/psignalclearprocesssignals.c
index b16398c..c8336cd 100644
--- a/cpukit/posix/src/psignalclearprocesssignals.c
+++ b/cpukit/posix/src/psignalclearprocesssignals.c
@@ -35,10 +35,10 @@
- *  _POSIX_signals_Clear_process_signals
+ *  _POSIX_Signals_Clear_process_signals
   int signo
@@ -51,12 +51,12 @@ void _POSIX_signals_Clear_process_signals(
   ISR_Level  level;
-    if ( _POSIX_signals_Vectors[ signo ].sa_flags == SA_SIGINFO ) {
-      if ( !_Chain_Is_empty( &_POSIX_signals_Siginfo[ signo ] ) )
+    if ( _POSIX_Signals_Vectors[ signo ].sa_flags == SA_SIGINFO ) {
+      if ( !_Chain_Is_empty( &_POSIX_Signals_Siginfo[ signo ] ) )
        clear_signal = false;
     if ( clear_signal ) {
-      _POSIX_signals_Pending &= ~mask;
+      _POSIX_Signals_Pending &= ~mask;
diff --git a/cpukit/posix/src/psignalclearsignals.c b/cpukit/posix/src/psignalclearsignals.c
index e71f2fa..4f9e54e 100644
--- a/cpukit/posix/src/psignalclearsignals.c
+++ b/cpukit/posix/src/psignalclearsignals.c
@@ -35,10 +35,10 @@
- *  _POSIX_signals_Clear_signals
+ *  _POSIX_Signals_Clear_signals
   int                 signo,
   siginfo_t          *info,
@@ -70,11 +70,11 @@ bool _POSIX_signals_Clear_signals(
     if ( is_global ) {
-       if ( mask & (_POSIX_signals_Pending & signals_blocked) ) {
+       if ( mask & (_POSIX_Signals_Pending & signals_blocked) ) {
-             _Chain_Get_unprotected( &_POSIX_signals_Siginfo[ signo ] );
-           _POSIX_signals_Clear_process_signals( signo );
+             _Chain_Get_unprotected( &_POSIX_Signals_Siginfo[ signo ] );
+           _POSIX_Signals_Clear_process_signals( signo );
             *  It may be impossible to get here with an empty chain
             *  BUT until that is proven we need to be defensive and
@@ -83,13 +83,13 @@ bool _POSIX_signals_Clear_signals(
            if ( psiginfo ) {
              *info = psiginfo->Info;
              _Chain_Append_unprotected(
                &psiginfo->Node
            } else
              do_callout = false;
          do_callout = true;
     } else {
diff --git a/cpukit/posix/src/psignalsetprocesssignals.c b/cpukit/posix/src/psignalsetprocesssignals.c
index 92c1d81..7ecb8e6 100644
--- a/cpukit/posix/src/psignalsetprocesssignals.c
+++ b/cpukit/posix/src/psignalsetprocesssignals.c
@@ -34,13 +34,13 @@
   sigset_t   mask
   ISR_Level  level;
-    _POSIX_signals_Pending |= mask;
+    _POSIX_Signals_Pending |= mask;
diff --git a/cpukit/posix/src/psignalunblockthread.c b/cpukit/posix/src/psignalunblockthread.c
index 0603a7f..29316bd 100644
--- a/cpukit/posix/src/psignalunblockthread.c
+++ b/cpukit/posix/src/psignalunblockthread.c
@@ -34,7 +34,7 @@
   int              signo,
   siginfo_t       *info
diff --git a/cpukit/posix/src/pthreadkill.c b/cpukit/posix/src/pthreadkill.c
index e0f3950..18cf36c 100644
--- a/cpukit/posix/src/pthreadkill.c
+++ b/cpukit/posix/src/pthreadkill.c
@@ -53,13 +53,13 @@ int pthread_kill(
        *  If sig == 0 then just validate arguments
       if ( sig ) {
-        if ( _POSIX_signals_Vectors[ sig ].sa_handler == SIG_IGN ) {
+        if ( _POSIX_Signals_Vectors[ sig ].sa_handler == SIG_IGN ) {
           return 0;
@@ -68,7 +68,7 @@ int pthread_kill(
         api->signals_pending |= signo_to_mask( sig );
-        (void) _POSIX_signals_Unblock_thread( the_thread, sig, NULL );
+        (void) _POSIX_Signals_Unblock_thread( the_thread, sig, NULL );
         if ( _ISR_Is_in_progress() && _Thread_Is_executing( the_thread ) )
 	  _Thread_Dispatch_necessary = true;
diff --git a/cpukit/posix/src/pthreadsigmask.c b/cpukit/posix/src/pthreadsigmask.c
index 3f985bf..6b340ca 100644
--- a/cpukit/posix/src/pthreadsigmask.c
+++ b/cpukit/posix/src/pthreadsigmask.c
@@ -69,7 +69,7 @@ int pthread_sigmask(
   /* XXX evaluate the new set */
   if ( ~api->signals_blocked &
-       (api->signals_pending | _POSIX_signals_Pending) ) {
+       (api->signals_pending | _POSIX_Signals_Pending) ) {
     _Thread_Dispatch();
diff --git a/cpukit/posix/src/sigaction.c b/cpukit/posix/src/sigaction.c
index cfcc65c..ac2b4c9 100644
--- a/cpukit/posix/src/sigaction.c
+++ b/cpukit/posix/src/sigaction.c
@@ -45,7 +45,7 @@ int sigaction(
   ISR_Level     level;
   if ( oact )
-    *oact = _POSIX_signals_Vectors[ sig ];
+    *oact = _POSIX_Signals_Vectors[ sig ];
   if ( !sig )
     rtems_set_errno_and_return_minus_one( EINVAL );
@@ -77,10 +77,10 @@ int sigaction(
       if ( act->sa_handler == SIG_DFL ) {
-        _POSIX_signals_Vectors[ sig ] = _POSIX_signals_Default_vectors[ sig ];
+        _POSIX_Signals_Vectors[ sig ] = _POSIX_Signals_Default_vectors[ sig ];
       } else {
-         _POSIX_signals_Clear_process_signals( sig );
-         _POSIX_signals_Vectors[ sig ] = *act;
+         _POSIX_Signals_Clear_process_signals( sig );
+         _POSIX_Signals_Vectors[ sig ] = *act;
diff --git a/cpukit/posix/src/sigpending.c b/cpukit/posix/src/sigpending.c
index 44dbe93..dbd6329 100644
--- a/cpukit/posix/src/sigpending.c
+++ b/cpukit/posix/src/sigpending.c
@@ -37,7 +37,7 @@ int sigpending(
   api = _Thread_Executing->API_Extensions[ THREAD_API_POSIX ];
-  *set = api->signals_pending | _POSIX_signals_Pending;
+  *set = api->signals_pending | _POSIX_Signals_Pending;
   return 0;
diff --git a/cpukit/posix/src/sigtimedwait.c b/cpukit/posix/src/sigtimedwait.c
index ef8bbdf..92ff89d 100644
--- a/cpukit/posix/src/sigtimedwait.c
+++ b/cpukit/posix/src/sigtimedwait.c
@@ -29,7 +29,7 @@
 #include <rtems/score/isr.h>
-static int _POSIX_signals_Get_lowest(
+static int _POSIX_Signals_Get_lowest(
   sigset_t   set
@@ -121,8 +121,8 @@ int sigtimedwait(
   if ( *set & api->signals_pending ) {
     /* XXX real info later */
-    the_info->si_signo = _POSIX_signals_Get_lowest( api->signals_pending );
-    _POSIX_signals_Clear_signals(
+    the_info->si_signo = _POSIX_Signals_Get_lowest( api->signals_pending );
+    _POSIX_Signals_Clear_signals(
       api,
       the_info->si_signo,
       the_info,
@@ -138,9 +138,9 @@ int sigtimedwait(
   /* Process pending signals? */
-  if ( *set & _POSIX_signals_Pending ) {
-    signo = _POSIX_signals_Get_lowest( _POSIX_signals_Pending );
-    _POSIX_signals_Clear_signals( api, signo, the_info, true, false );
+  if ( *set & _POSIX_Signals_Pending ) {
+    signo = _POSIX_Signals_Get_lowest( _POSIX_Signals_Pending );
+    _POSIX_Signals_Clear_signals( api, signo, the_info, true, false );
     the_info->si_signo = signo;
@@ -152,13 +152,13 @@ int sigtimedwait(
   the_info->si_signo = -1;
-    the_thread->Wait.queue           = &_POSIX_signals_Wait_queue;
+    the_thread->Wait.queue           = &_POSIX_Signals_Wait_queue;
     the_thread->Wait.return_code     = EINTR;
     the_thread->Wait.option          = *set;
     the_thread->Wait.return_argument = the_info;
-    _Thread_queue_Enter_critical_section( &_POSIX_signals_Wait_queue );
+    _Thread_queue_Enter_critical_section( &_POSIX_Signals_Wait_queue );
-    _Thread_queue_Enqueue( &_POSIX_signals_Wait_queue, interval );
+    _Thread_queue_Enqueue( &_POSIX_Signals_Wait_queue, interval );
@@ -166,7 +166,7 @@ int sigtimedwait(
    * the signal.
-  _POSIX_signals_Clear_signals( api, the_info->si_signo, the_info, false, false );
+  _POSIX_Signals_Clear_signals( api, the_info->si_signo, the_info, false, false );
   /* Set errno only if return code is not EINTR or
    * if EINTR was caused by a signal being caught, which
diff --git a/cpukit/posix/src/ualarm.c b/cpukit/posix/src/ualarm.c
index e9a4bb8..4a1b176 100644
--- a/cpukit/posix/src/ualarm.c
+++ b/cpukit/posix/src/ualarm.c
@@ -27,10 +27,10 @@
- *  _POSIX_signals_Ualarm_TSR
+ *  _POSIX_Signals_Ualarm_TSR
-static void _POSIX_signals_Ualarm_TSR(
+static void _POSIX_Signals_Ualarm_TSR(
@@ -44,7 +44,7 @@ static void _POSIX_signals_Ualarm_TSR(
    * If the reset interval is non-zero, reschedule ourselves.
-  _Watchdog_Reset( &_POSIX_signals_Ualarm_timer );
+  _Watchdog_Reset( &_POSIX_Signals_Ualarm_timer );
 useconds_t ualarm(
@@ -57,14 +57,14 @@ useconds_t ualarm(
   Watchdog_Interval ticks;
   struct timespec   tp;
-  the_timer = &_POSIX_signals_Ualarm_timer;
+  the_timer = &_POSIX_Signals_Ualarm_timer;
-    _Watchdog_Initialize( the_timer, _POSIX_signals_Ualarm_TSR, 0, NULL );
+    _Watchdog_Initialize( the_timer, _POSIX_Signals_Ualarm_TSR, 0, NULL );
   } else {
diff --git a/cpukit/sapi/src/posixapi.c b/cpukit/sapi/src/posixapi.c
index bd7aabd..c960692 100644
--- a/cpukit/sapi/src/posixapi.c
+++ b/cpukit/sapi/src/posixapi.c
@@ -61,7 +61,7 @@ void _POSIX_API_Initialize(void)
   _Objects_Information_table[OBJECTS_POSIX_API] = _POSIX_Objects;
-  _POSIX_signals_Manager_Initialization();
+  _POSIX_Signals_Manager_initialization();
   _POSIX_Threads_Manager_initialization();
   _POSIX_Condition_variables_Manager_initialization();
   _POSIX_Key_Manager_initialization();
diff --git a/testsuites/psxtests/ChangeLog b/testsuites/psxtests/ChangeLog
index 3cde243..9ed3df1 100644
--- a/testsuites/psxtests/ChangeLog
+++ b/testsuites/psxtests/ChangeLog
@@ -1281,7 +1281,7 @@
 	* Makefile.am, configure.ac: Add a test to exercise an odd case in
-	_POSIX_signals_Clear_signals.
+	_POSIX_Signals_Clear_signals.
 	* psxsignal05/.cvsignore, psxsignal05/Makefile.am, psxsignal05/init.c,
 	psxsignal05/psxsignal05.doc, psxsignal05/psxsignal05.scn: New files.
diff --git a/testsuites/psxtests/psx15/init.c b/testsuites/psxtests/psx15/init.c
index cc1f01c..14093d7 100644
--- a/testsuites/psxtests/psx15/init.c
+++ b/testsuites/psxtests/psx15/init.c
@@ -28,7 +28,7 @@ rtems_task Init(rtems_task_argument argument);
  * This test case shows that post switch extension handlers must cope with
- * already deleted resources (e.g. _POSIX_signals_Post_switch_extension()).
+ * already deleted resources (e.g. _POSIX_Signals_Post_switch_extension()).
  * The thread delete extensions run with thread dispatching enabled.  Only the
  * allocation mutex is locked.
diff --git a/testsuites/psxtests/psxsignal01/init.c b/testsuites/psxtests/psxsignal01/init.c
index 8a85bef..a1dfef8 100644
--- a/testsuites/psxtests/psxsignal01/init.c
+++ b/testsuites/psxtests/psxsignal01/init.c
@@ -28,7 +28,7 @@ rtems_timer_service_routine Signal_duringISR_TSR(
 typedef void (*sighandler_t)(int);
 sighandler_t signal(int signum, sighandler_t handler);
-extern void _POSIX_signals_Abnormal_termination_handler( int signo );
+extern void _POSIX_Signals_Abnormal_termination_handler( int signo );
 volatile int Signal_occurred;
 volatile int Signal_count;
@@ -233,7 +233,7 @@ void *POSIX_Init(
   puts("*** Validate unexpected program termination ***");
   puts( "*** END OF POSIX TEST SIGNAL ***" );
-  _POSIX_signals_Abnormal_termination_handler( SIGUSR1 );
+  _POSIX_Signals_Abnormal_termination_handler( SIGUSR1 );
   status = sleep( 1 );
   puts( "ERROR==> Expected program termination");
diff --git a/testsuites/psxtests/psxsignal05/init.c b/testsuites/psxtests/psxsignal05/init.c
index 04c7879..47ddf99 100644
--- a/testsuites/psxtests/psxsignal05/init.c
+++ b/testsuites/psxtests/psxsignal05/init.c
@@ -69,14 +69,14 @@ void *POSIX_Init(
   sigaction( SIGNAL_TWO, &act, NULL );
   printf(
-   "Init - _POSIX_signals_Clear_signals when signals pending but\n"
+   "Init - _POSIX_Signals_Clear_signals when signals pending but\n"
    "Init -    not queued on SA_SIGINFO configured signal.\n"
   /* cheat and put signal directly in */
-  _POSIX_signals_Pending |= signo_to_mask( SIGUSR1 );
+  _POSIX_Signals_Pending |= signo_to_mask( SIGUSR1 );
-  bc = _POSIX_signals_Clear_signals(
+  bc = _POSIX_Signals_Clear_signals(
     _Thread_Executing->API_Extensions[ THREAD_API_POSIX ],
     SIGNAL_ONE,
     &info,
diff --git a/testsuites/psxtests/psxsignal05/psxsignal05.doc b/testsuites/psxtests/psxsignal05/psxsignal05.doc
index b09b978..74285fd 100644
--- a/testsuites/psxtests/psxsignal05/psxsignal05.doc
+++ b/testsuites/psxtests/psxsignal05/psxsignal05.doc
@@ -19,7 +19,7 @@ directives:
 concepts:
-+ Ensure if _POSIX_signals_Clear_signals is called to clear a process wide
++ Ensure if _POSIX_Signals_Clear_signals is called to clear a process wide
   SA_SIGINFO signal which is pending but there is not a queued SA_SIGINFO
   structure, then things happen correctly.
diff --git a/testsuites/psxtests/psxsignal05/psxsignal05.scn b/testsuites/psxtests/psxsignal05/psxsignal05.scn
index 210c515..20509e4 100644
--- a/testsuites/psxtests/psxsignal05/psxsignal05.scn
+++ b/testsuites/psxtests/psxsignal05/psxsignal05.scn
@@ -1,4 +1,4 @@
 *** POSIX TEST SIGNAL 05 ***
-Init - _POSIX_signals_Clear_signals when signals pending but
+Init - _POSIX_Signals_Clear_signals when signals pending but
 *** END OF POSIX TEST SIGNAL 05 ***
diff --git a/testsuites/psxtests/psxualarm/init.c b/testsuites/psxtests/psxualarm/init.c
index 19c9e44..24ff82d 100644
--- a/testsuites/psxtests/psxualarm/init.c
+++ b/testsuites/psxtests/psxualarm/init.c
@@ -26,7 +26,7 @@ rtems_timer_service_routine Signal_duringISR_TSR(
1.7.10.4
