[PATCH] [libbsp/shared] Fixed compiler warning - no previous prototype for 'bsp_fatal_extension'
Sebastian Huber
Tue Mar 19 14:05:30 UTC 2013
On 03/19/2013 01:17 PM, Andreas Heinig wrote:
> I see this warning for my own BSP's.
In this case your BSPs should include <bsp/default-initial-extension.h> in
<bsp.h>. This <bsp/default-initial-extension.h> defines also
BSP_INITIAL_EXTENSION which is used by <rtems/confdefs.h>
> Is it really intended that every BSP defines the prototype of the function on
> its own?
No, it is intended that <bsp.h> includes <bsp/default-initial-extension.h> if
this BSP uses the shared bspclean.c.
> Btw.: This is also the case for the function: rtems_exception_init_mngt().
Yes, this stuff is improvable.
> In my opinion, it is much better to have a system-wide deceleration of common
> interface functions. This would be extremely helpful, especially if somebody
> wants to change an interface. In that case, the compiler can easily detect code
> which was not ported.
Yes, global functions without exactly one declaration in a header file per
architecture are broken.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
