[PATCH 2/2] [cpukit/POSIX] Renamed POSIX signal functions to match style of the other POSIX related functions
Tue Mar 19 16:47:09 UTC 2013
On Tue, Mar 19, 2013 at 10:21 AM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> I am about to travel to an Open Group meeting but I
> spotted a couple of things and wanted to understand
> what you thought was wrong and changed.
> + Your tree is NOT up to date. It has ChangeLog files in it.
> + You did a blind search and replace since it changed ChangeLog
> entries before your change was made.
> Now to see if I can understand what you were trying to
> do specifically. Can you give a very simple summary with
> details. Like "renamed X to Y". "Changed include from X to
> Y after renaming file." etc.  The patch appears to be the
> result of a global search and replace and it would be
> easier to review if we knew what that was.
> The naming convention is Package_Member. The _ followed
> by a word with leading capital letter indicates that separation.
> Read this as Package::Member for C++ or Package.Member in Ada.
> If a Package or Method has multiple words in its name, then
> the first word is leading caps. UNLESS there is an acronym which
> should be honored.  So _POSIX_message_queue_Initialize_buffers
> should be an example (I hope correct) of the naming convention.
I think there are a few counter-examples and we should try to settle
on a proper convention. For example we have
_POSIX_Message_queue_Priority_from_core() but also
_CORE_message_queue_Seize().
In fact, I think the POSIX_signals is the only POSIX package that
adheres to the convention. I think that including the API in the
Package name is confusing, because there is no "POSIX" package, there
is a "POSIX" interface, and the same goes for "CORE". It would be more
consistent to prepend an API to the Package and Member, like what is
done with POSIX already (except the signals). Then we should also drop
_CORE from the handful of packages in score that use it. This makes
the supercore interface "silent" so to speak. My $0.02
-Gedare
> FYI that is likely not a real method. I made the name up. :)
> I don't doubt there are inconsistencies. It is just easier to review
> if we know what you were renaming.
> --joel
> On 3/19/2013 8:48 AM, Andreas Heinig wrote:
>>   cpukit/ChangeLog                                |    8 +--
>>   cpukit/posix/include/rtems/posix/psignalimpl.h  |   46 ++++++++---------
>>   cpukit/posix/src/alarm.c                        |    8 +--
>>   cpukit/posix/src/killinfo.c                     |   22 ++++-----
>>   cpukit/posix/src/psignal.c                      |   60
>>   cpukit/posix/src/psignalchecksignal.c           |   18 +++----
>>   cpukit/posix/src/psignalclearprocesssignals.c   |   10 ++--
>>   cpukit/posix/src/psignalclearsignals.c          |   16 +++---
>>   cpukit/posix/src/psignalsetprocesssignals.c     |    4 +-
>>   cpukit/posix/src/psignalunblockthread.c         |    2 +-
>>   cpukit/posix/src/pthreadkill.c                  |    6 +--
>>   cpukit/posix/src/pthreadsigmask.c               |    2 +-
>>   cpukit/posix/src/sigaction.c                    |    8 +--
>>   cpukit/posix/src/sigpending.c                   |    2 +-
>>   cpukit/posix/src/sigtimedwait.c                 |   20 ++++----
>>   cpukit/posix/src/ualarm.c                       |   10 ++--
>>   cpukit/sapi/src/posixapi.c                      |    2 +-
>>   testsuites/psxtests/ChangeLog                   |    2 +-
>>   testsuites/psxtests/psx15/init.c                |    2 +-
>>   testsuites/psxtests/psxsignal01/init.c          |    4 +-
>>   testsuites/psxtests/psxsignal05/init.c          |    6 +--
>>   testsuites/psxtests/psxsignal05/psxsignal05.doc |    2 +-
>>   testsuites/psxtests/psxsignal05/psxsignal05.scn |    2 +-
>>   testsuites/psxtests/psxualarm/init.c            |    2 +-
>>   24 files changed, 132 insertions(+), 132 deletions(-)
>> diff --git a/cpukit/ChangeLog b/cpukit/ChangeLog
>> index 5c8e2b1..358b42d 100644
>> --- a/cpukit/ChangeLog
>> +++ b/cpukit/ChangeLog
>> @@ -101,7 +101,7 @@
>>   2011-12-10     Ralf Corsépius <ralf.corsepius at rtems.org>
>> -       * posix/src/sigtimedwait.c: Make _POSIX_signals_Get_lowest static.
>> +       * posix/src/sigtimedwait.c: Make _POSIX_Signals_Get_lowest static.
>>   2011-12-09     Joel Sherrill <joel.sherrill at oarcorp.com>
>> @@ -744,10 +744,10 @@
>>          Comment out unused vars "group", "group_base".
>>          * libmisc/monitor/mon-editor.c (rtems_monitor_task):
>>          Comment out unused vars "debugee", "rp", "fp".
>> -       * posix/src/alarm.c: Make _POSIX_signals_Alarm_TSR static.
>> +       * posix/src/alarm.c: Make _POSIX_Signals_Alarm_TSR static.
>>          Remove unused var "status".
>>          * libmisc/shell/main_ls.c: Comment out unused var kflag.
>> -       * posix/src/ualarm.c: Make _POSIX_signals_Ualarm_TSR static.
>> +       * posix/src/ualarm.c: Make _POSIX_Signals_Ualarm_TSR static.
>>   2011-10-12     Ralf Corsépius <ralf.corsepius at rtems.org>
>> @@ -7393,7 +7393,7 @@
>>   2009-08-05     Joel Sherrill <joel.sherrill at oarcorp.com>
>> -       * posix/src/sigaction.c: _POSIX_signals_Clear_process_signals now
>> takes
>> +       * posix/src/sigaction.c: _POSIX_Signals_Clear_process_signals now
>> takes
>>          signal number not mask.
>>   2009-08-05     Joel Sherrill <joel.sherrill at OARcorp.com>
>> diff --git a/cpukit/posix/include/rtems/posix/psignalimpl.h
>> b/cpukit/posix/include/rtems/posix/psignalimpl.h
>> index 481a7ea..334c2fa 100644
>> --- a/cpukit/posix/include/rtems/posix/psignalimpl.h
>> +++ b/cpukit/posix/include/rtems/posix/psignalimpl.h
>> @@ -39,13 +39,13 @@
>>         (STATES_WAITING_FOR_SIGNAL|STATES_INTERRUPTIBLE_BY_SIGNAL))
>>   #define SIGACTION_TERMINATE \
>> -  { 0, SIGNAL_ALL_MASK, {_POSIX_signals_Abnormal_termination_handler} }
>> +  { 0, SIGNAL_ALL_MASK, {_POSIX_Signals_Abnormal_termination_handler} }
>>   #define SIGACTION_IGNORE \
>>     { 0, SIGNAL_ALL_MASK, {SIG_IGN} }
>>   #define SIGACTION_STOP \
>> -  { 0, SIGNAL_ALL_MASK, {_POSIX_signals_Stop_handler} }
>> +  { 0, SIGNAL_ALL_MASK, {_POSIX_Signals_Stop_handler} }
>>   #define SIGACTION_CONTINUE \
>> -  { 0, SIGNAL_ALL_MASK, {_POSIX_signals_Continue_handler} }
>> +  { 0, SIGNAL_ALL_MASK, {_POSIX_Signals_Continue_handler} }
>>   #define SIG_ARRAY_MAX  (SIGRTMAX + 1)
>> @@ -53,23 +53,23 @@
>>    *  Variables
>> -extern sigset_t  _POSIX_signals_Pending;
>> +extern sigset_t  _POSIX_Signals_Pending;
>> -extern const struct sigaction _POSIX_signals_Default_vectors[
>> SIG_ARRAY_MAX ];
>> +extern const struct sigaction _POSIX_Signals_Default_vectors[
>> SIG_ARRAY_MAX ];
>> -extern struct sigaction _POSIX_signals_Vectors[ SIG_ARRAY_MAX ];
>> +extern struct sigaction _POSIX_Signals_Vectors[ SIG_ARRAY_MAX ];
>> -extern Watchdog_Control _POSIX_signals_Alarm_timer;
>> +extern Watchdog_Control _POSIX_Signals_Alarm_timer;
>> -extern Watchdog_Control _POSIX_signals_Ualarm_timer;
>> +extern Watchdog_Control _POSIX_Signals_Ualarm_timer;
>> -extern Thread_queue_Control _POSIX_signals_Wait_queue;
>> +extern Thread_queue_Control _POSIX_Signals_Wait_queue;
>> -extern Chain_Control _POSIX_signals_Inactive_siginfo;
>> +extern Chain_Control _POSIX_Signals_Inactive_siginfo;
>> -extern Chain_Control _POSIX_signals_Siginfo[ SIG_ARRAY_MAX ];
>> +extern Chain_Control _POSIX_Signals_Siginfo[ SIG_ARRAY_MAX ];
>> -extern API_extensions_Post_switch_control _POSIX_signals_Post_switch;
>> +extern API_extensions_Post_switch_control _POSIX_Signals_Post_switch;
>>    *  Internal routines
>> @@ -78,11 +78,11 @@ extern API_extensions_Post_switch_control
>>    * @brief POSIX signals manager initialization.
>> -void _POSIX_signals_Manager_Initialization(void);
>> +void _POSIX_Signals_Manager_initialization(void);
>> -static inline void _POSIX_signals_Add_post_switch_extension(void)
>> +static inline void _POSIX_Signals_Add_post_switch_extension(void)
>> -  _API_extensions_Add_post_switch( &_POSIX_signals_Post_switch );
>> +  _API_extensions_Add_post_switch( &_POSIX_Signals_Post_switch );
>> @@ -90,7 +90,7 @@ static inline void
>>    * XXX this routine could probably be cleaned up
>> -bool _POSIX_signals_Unblock_thread(
>> +bool _POSIX_Signals_Unblock_thread(
>>     Thread_Control  *the_thread,
>>     int              signo,
>>     siginfo_t       *info
>> @@ -99,7 +99,7 @@ bool _POSIX_signals_Unblock_thread(
>>    *  @brief Check POSIX signal.
>> -bool _POSIX_signals_Check_signal(
>> +bool _POSIX_Signals_Check_signal(
>>     POSIX_API_Control  *api,
>>     int                 signo,
>>     bool                is_global
>> @@ -108,7 +108,7 @@ bool _POSIX_signals_Check_signal(
>>    * @brief Clear POSIX signals.
>> -bool _POSIX_signals_Clear_signals(
>> +bool _POSIX_Signals_Clear_signals(
>>     int                 signo,
>>     siginfo_t          *info,
>> @@ -125,11 +125,11 @@ int killinfo(
>>    *  @brief Set POSIX process signals.
>> -void _POSIX_signals_Set_process_signals(
>> +void _POSIX_Signals_Set_process_signals(
>>     sigset_t   mask
>> -void _POSIX_signals_Clear_process_signals(
>> +void _POSIX_Signals_Clear_process_signals(
>>     int        signo
>> @@ -137,10 +137,10 @@ void _POSIX_signals_Clear_process_signals(
>>    *  Default signal handlers
>> -#define _POSIX_signals_Stop_handler NULL
>> -#define _POSIX_signals_Continue_handler NULL
>> +#define _POSIX_Signals_Stop_handler NULL
>> +#define _POSIX_Signals_Continue_handler NULL
>> -void _POSIX_signals_Abnormal_termination_handler( int signo );
>> +void _POSIX_Signals_Abnormal_termination_handler( int signo );
>> diff --git a/cpukit/posix/src/alarm.c b/cpukit/posix/src/alarm.c
>> index 5130b01..bbe45cb 100644
>> --- a/cpukit/posix/src/alarm.c
>> +++ b/cpukit/posix/src/alarm.c
>> @@ -28,10 +28,10 @@
>>   #include <rtems/posix/psignalimpl.h>
>> - *  _POSIX_signals_Alarm_TSR
>> + *  _POSIX_Signals_Alarm_TSR
>> -static void _POSIX_signals_Alarm_TSR(
>> +static void _POSIX_Signals_Alarm_TSR(
>>     Objects_Id      id __attribute__((unused)),
>>     void           *argument __attribute__((unused))
>> @@ -47,14 +47,14 @@ unsigned int alarm(
>>     unsigned int      remaining = 0;
>>     Watchdog_Control *the_timer;
>> -  the_timer = &_POSIX_signals_Alarm_timer;
>> +  the_timer = &_POSIX_Signals_Alarm_timer;
>>      *  Initialize the timer used to implement alarm().
>>     if ( !the_timer->routine ) {
>> -    _Watchdog_Initialize( the_timer, _POSIX_signals_Alarm_TSR, 0, NULL );
>> +    _Watchdog_Initialize( the_timer, _POSIX_Signals_Alarm_TSR, 0, NULL );
>>     } else {
>>       Watchdog_States state;
>> diff --git a/cpukit/posix/src/killinfo.c b/cpukit/posix/src/killinfo.c
>> index f386757..c2b1967 100644
>> --- a/cpukit/posix/src/killinfo.c
>> +++ b/cpukit/posix/src/killinfo.c
>> @@ -51,7 +51,7 @@
>>    *  NOTE: Behavior of kill() depends on _POSIX_SAVED_IDS.
>> -#define _POSIX_signals_Is_interested( _api, _mask ) \
>> +#define _POSIX_Signals_Is_interested( _api, _mask ) \
>>     ( ~(_api)->signals_blocked & (_mask) )
>>   int killinfo(
>> @@ -94,7 +94,7 @@ int killinfo(
>>      *  If the signal is being ignored, then we are out of here.
>> -  if ( _POSIX_signals_Vectors[ sig ].sa_handler == SIG_IGN )
>> +  if ( _POSIX_Signals_Vectors[ sig ].sa_handler == SIG_IGN )
>>       return 0;
>> @@ -121,7 +121,7 @@ int killinfo(
>>     _Thread_Disable_dispatch();
>> -  _POSIX_signals_Add_post_switch_extension();
>> +  _POSIX_Signals_Add_post_switch_extension();
>>      *  Is the currently executing thread interested?  If so then it will
>> @@ -130,7 +130,7 @@ int killinfo(
>>     the_thread = _Thread_Executing;
>>     api = the_thread->API_Extensions[ THREAD_API_POSIX ];
>> -  if ( _POSIX_signals_Is_interested( api, mask ) ) {
>> +  if ( _POSIX_Signals_Is_interested( api, mask ) ) {
>>       goto process_it;
>> @@ -142,7 +142,7 @@ int killinfo(
>>     /* XXX violation of visibility -- need to define thread queue support
>> -  the_chain = &_POSIX_signals_Wait_queue.Queues.Fifo;
>> +  the_chain = &_POSIX_Signals_Wait_queue.Queues.Fifo;
>>     for ( the_node = _Chain_First( the_chain );
>>           !_Chain_Is_tail( the_chain, the_node ) ;
>> @@ -244,7 +244,7 @@ int killinfo(
>>             continue;
>>         #endif
>> -      if ( !_POSIX_signals_Is_interested( api, mask ) )
>> +      if ( !_POSIX_Signals_Is_interested( api, mask ) )
>>           continue;
>>         DEBUG_STEP("3");
>> @@ -325,7 +325,7 @@ process_it:
>>      *  Returns true if the signal was synchronously given to a thread
>>      *  blocked waiting for the signal.
>> -  if ( _POSIX_signals_Unblock_thread( the_thread, sig, siginfo ) ) {
>> +  if ( _POSIX_Signals_Unblock_thread( the_thread, sig, siginfo ) ) {
>>       _Thread_Enable_dispatch();
>>       return 0;
>> @@ -336,12 +336,12 @@ post_process_signal:
>>      *  We may have woken up a thread but we definitely need to post the
>>      *  signal to the process wide information set.
>> -  _POSIX_signals_Set_process_signals( mask );
>> +  _POSIX_Signals_Set_process_signals( mask );
>> -  if ( _POSIX_signals_Vectors[ sig ].sa_flags == SA_SIGINFO ) {
>> +  if ( _POSIX_Signals_Vectors[ sig ].sa_flags == SA_SIGINFO ) {
>>       psiginfo = (POSIX_signals_Siginfo_node *)
>> -               _Chain_Get( &_POSIX_signals_Inactive_siginfo );
>> +               _Chain_Get( &_POSIX_Signals_Inactive_siginfo );
>>       if ( !psiginfo ) {
>>         rtems_set_errno_and_return_minus_one( EAGAIN );
>> @@ -349,7 +349,7 @@ post_process_signal:
>>       psiginfo->Info = *siginfo;
>> -    _Chain_Append( &_POSIX_signals_Siginfo[ sig ], &psiginfo->Node );
>> +    _Chain_Append( &_POSIX_Signals_Siginfo[ sig ], &psiginfo->Node );
>>     DEBUG_STEP("\n");
>> diff --git a/cpukit/posix/src/psignal.c b/cpukit/posix/src/psignal.c
>> index e490877..fbd0dd9 100644
>> --- a/cpukit/posix/src/psignal.c
>> +++ b/cpukit/posix/src/psignal.c
>> @@ -42,16 +42,16 @@
>>   /*** PROCESS WIDE STUFF ****/
>> -sigset_t  _POSIX_signals_Pending;
>> +sigset_t  _POSIX_Signals_Pending;
>>     int signo __attribute__((unused)) )
>>     exit( 1 );
>> -const struct sigaction _POSIX_signals_Default_vectors[ SIG_ARRAY_MAX ] =
>> +const struct sigaction _POSIX_Signals_Default_vectors[ SIG_ARRAY_MAX ] =
>>     /* NO SIGNAL 0 */  SIGACTION_IGNORE,
>>     /* SIGHUP    1 */  SIGACTION_TERMINATE,
>>     /* SIGINT    2 */  SIGACTION_TERMINATE,
>> @@ -87,15 +87,15 @@ const struct sigaction _POSIX_signals_Default_vectors[
>> SIG_ARRAY_MAX ] = {
>>     /* SIGRTMAX 31 */  SIGACTION_TERMINATE
>> -struct sigaction _POSIX_signals_Vectors[ SIG_ARRAY_MAX ];
>> +struct sigaction _POSIX_Signals_Vectors[ SIG_ARRAY_MAX ];
>> -Thread_queue_Control _POSIX_signals_Wait_queue;
>> +Thread_queue_Control _POSIX_Signals_Wait_queue;
>> -Chain_Control _POSIX_signals_Inactive_siginfo;
>> -Chain_Control _POSIX_signals_Siginfo[ SIG_ARRAY_MAX ];
>> +Chain_Control _POSIX_Signals_Inactive_siginfo;
>> +Chain_Control _POSIX_Signals_Siginfo[ SIG_ARRAY_MAX ];
>> -Watchdog_Control _POSIX_signals_Alarm_timer;
>> -Watchdog_Control _POSIX_signals_Ualarm_timer;
>> +Watchdog_Control _POSIX_Signals_Alarm_timer;
>> +Watchdog_Control _POSIX_Signals_Ualarm_timer;
>>    *  XXX - move these
>> @@ -107,10 +107,10 @@ Watchdog_Control _POSIX_signals_Ualarm_timer;
>> - *  _POSIX_signals_Post_switch_extension
>> + *  _POSIX_Signals_Post_switch_extension
>> -static void _POSIX_signals_Post_switch_hook(
>> +static void _POSIX_Signals_Post_switch_hook(
>> @@ -144,32 +144,32 @@ static void _POSIX_signals_Post_switch_hook(
>>     while (1) {
>>       _ISR_Disable( level );
>>         if ( !(~api->signals_blocked &
>> -            (api->signals_pending | _POSIX_signals_Pending)) ) {
>> +            (api->signals_pending | _POSIX_Signals_Pending)) ) {
>>          _ISR_Enable( level );
>>          break;
>>       for ( signo = SIGRTMIN ; signo <= SIGRTMAX ; signo++ ) {
>> -      _POSIX_signals_Check_signal( api, signo, false );
>> -      _POSIX_signals_Check_signal( api, signo, true );
>> +      _POSIX_Signals_Check_signal( api, signo, false );
>> +      _POSIX_Signals_Check_signal( api, signo, true );
>>       /* Unfortunately - nothing like __SIGFIRSTNOTRT in newlib signal .h
>>       for ( signo = SIGHUP ; signo <= __SIGLASTNOTRT ; signo++ ) {
>>     _Thread_Executing->Wait.return_code = hold_errno;
>> -API_extensions_Post_switch_control _POSIX_signals_Post_switch = {
>> -  .hook = _POSIX_signals_Post_switch_hook
>> +API_extensions_Post_switch_control _POSIX_Signals_Post_switch = {
>> +  .hook = _POSIX_Signals_Post_switch_hook
>>     uint32_t   signo;
>>     uint32_t   maximum_queued_signals;
>> @@ -182,26 +182,26 @@ void _POSIX_signals_Manager_Initialization(void)
>>     #if defined(RTEMS_DEBUG)
>>       assert(
>> -     sizeof(_POSIX_signals_Vectors) ==
>> sizeof(_POSIX_signals_Default_vectors)
>> +     sizeof(_POSIX_Signals_Vectors) ==
>> sizeof(_POSIX_Signals_Default_vectors)
>>     #endif
>>     memcpy(
>> -    _POSIX_signals_Vectors,
>> -    _POSIX_signals_Default_vectors,
>> -    sizeof( _POSIX_signals_Vectors )
>> +    _POSIX_Signals_Vectors,
>> +    _POSIX_Signals_Default_vectors,
>> +    sizeof( _POSIX_Signals_Vectors )
>>      *  Initialize the set of pending signals for the entire process
>> -  sigemptyset( &_POSIX_signals_Pending );
>> +  sigemptyset( &_POSIX_Signals_Pending );
>>      *  Initialize the queue we use to block for signals
>>     _Thread_queue_Initialize(
>> -    &_POSIX_signals_Wait_queue,
>> +    &_POSIX_Signals_Wait_queue,
>>       THREAD_QUEUE_DISCIPLINE_FIFO,
>>       STATES_WAITING_FOR_SIGNAL | STATES_INTERRUPTIBLE_BY_SIGNAL,
>>       EAGAIN
>> @@ -213,11 +213,11 @@ void _POSIX_signals_Manager_Initialization(void)
>>      *  Allocate the siginfo pools.
>>     for ( signo=1 ; signo<= SIGRTMAX ; signo++ )
>> -    _Chain_Initialize_empty( &_POSIX_signals_Siginfo[ signo ] );
>> +    _Chain_Initialize_empty( &_POSIX_Signals_Siginfo[ signo ] );
>>     if ( maximum_queued_signals ) {
>>       _Chain_Initialize(
>> -      &_POSIX_signals_Inactive_siginfo,
>> +      &_POSIX_Signals_Inactive_siginfo,
>>         _Workspace_Allocate_or_fatal_error(
>>           maximum_queued_signals * sizeof( POSIX_signals_Siginfo_node )
>> @@ -225,12 +225,12 @@ void _POSIX_signals_Manager_Initialization(void)
>>     } else {
>> -    _Chain_Initialize_empty( &_POSIX_signals_Inactive_siginfo );
>> +    _Chain_Initialize_empty( &_POSIX_Signals_Inactive_siginfo );
>>      *  Initialize the Alarm Timer
>> -  _Watchdog_Initialize( &_POSIX_signals_Alarm_timer, NULL, 0, NULL );
>> -  _Watchdog_Initialize( &_POSIX_signals_Ualarm_timer, NULL, 0, NULL );
>> +  _Watchdog_Initialize( &_POSIX_Signals_Alarm_timer, NULL, 0, NULL );
>> +  _Watchdog_Initialize( &_POSIX_Signals_Ualarm_timer, NULL, 0, NULL );
>> diff --git a/cpukit/posix/src/psignalchecksignal.c
>> b/cpukit/posix/src/psignalchecksignal.c
>> index 57237d3..f2c0e1b 100644
>> --- a/cpukit/posix/src/psignalchecksignal.c
>> +++ b/cpukit/posix/src/psignalchecksignal.c
>> @@ -38,7 +38,7 @@
>>   #include <rtems/posix/time.h>
>>   #include <stdio.h>
>>     int                 signo,
>>     bool                is_global
>> @@ -48,7 +48,7 @@ bool    _POSIX_signals_Check_signal(
>>     sigset_t                    saved_signals_blocked;
>>     Thread_Wait_information     stored_thread_wait_information;
>> -  if ( ! _POSIX_signals_Clear_signals( api, signo, &siginfo_struct,
>> +  if ( ! _POSIX_Signals_Clear_signals( api, signo, &siginfo_struct,
>>                                          is_global, true ) )
>>       return false;
>> @@ -57,21 +57,21 @@ bool    _POSIX_signals_Check_signal(
>>      *  safer.
>> -    assert( _POSIX_signals_Vectors[ signo ].sa_handler ||
>> -            _POSIX_signals_Vectors[ signo ].sa_sigaction );
>> +    assert( _POSIX_Signals_Vectors[ signo ].sa_handler ||
>> +            _POSIX_Signals_Vectors[ signo ].sa_sigaction );
>>     #endif
>>      *  Just to prevent sending a signal which is currently being ignored.
>> -  if ( _POSIX_signals_Vectors[ signo ].sa_handler == SIG_IGN )
>> +  if ( _POSIX_Signals_Vectors[ signo ].sa_handler == SIG_IGN )
>>       return false;
>>      *  Block the signals requested in sa_mask
>>     saved_signals_blocked = api->signals_blocked;
>> -  api->signals_blocked |= _POSIX_signals_Vectors[ signo ].sa_mask;
>> +  api->signals_blocked |= _POSIX_Signals_Vectors[ signo ].sa_mask;
>>      *  We have to save the blocking information of the current wait queue
>> @@ -84,16 +84,16 @@ bool    _POSIX_signals_Check_signal(
>>      *  Here, the signal handler function executes
>> -  switch ( _POSIX_signals_Vectors[ signo ].sa_flags ) {
>> +  switch ( _POSIX_Signals_Vectors[ signo ].sa_flags ) {
>>       case SA_SIGINFO:
>> -      (*_POSIX_signals_Vectors[ signo ].sa_sigaction)(
>> +      (*_POSIX_Signals_Vectors[ signo ].sa_sigaction)(
>>           signo,
>>           &siginfo_struct,
>>           NULL        /* context is undefined per 1003.1b-1993, p. 66 */
>>         break;
>>       default:
>> -      (*_POSIX_signals_Vectors[ signo ].sa_handler)( signo );
>> +      (*_POSIX_Signals_Vectors[ signo ].sa_handler)( signo );
>>         break;
>> diff --git a/cpukit/posix/src/psignalclearprocesssignals.c
>> b/cpukit/posix/src/psignalclearprocesssignals.c
>> index b16398c..c8336cd 100644
>> --- a/cpukit/posix/src/psignalclearprocesssignals.c
>> +++ b/cpukit/posix/src/psignalclearprocesssignals.c
>> @@ -35,10 +35,10 @@
>>   #include <stdio.h>
>> - *  _POSIX_signals_Clear_process_signals
>> + *  _POSIX_Signals_Clear_process_signals
>>     int signo
>> @@ -51,12 +51,12 @@ void _POSIX_signals_Clear_process_signals(
>>     ISR_Level  level;
>> -    if ( _POSIX_signals_Vectors[ signo ].sa_flags == SA_SIGINFO ) {
>> -      if ( !_Chain_Is_empty( &_POSIX_signals_Siginfo[ signo ] ) )
>> +    if ( _POSIX_Signals_Vectors[ signo ].sa_flags == SA_SIGINFO ) {
>> +      if ( !_Chain_Is_empty( &_POSIX_Signals_Siginfo[ signo ] ) )
>>          clear_signal = false;
>>       if ( clear_signal ) {
>> -      _POSIX_signals_Pending &= ~mask;
>> +      _POSIX_Signals_Pending &= ~mask;
>> diff --git a/cpukit/posix/src/psignalclearsignals.c
>> b/cpukit/posix/src/psignalclearsignals.c
>> index e71f2fa..4f9e54e 100644
>> --- a/cpukit/posix/src/psignalclearsignals.c
>> +++ b/cpukit/posix/src/psignalclearsignals.c
>> @@ -35,10 +35,10 @@
>>   #include <stdio.h>
>> - *  _POSIX_signals_Clear_signals
>> + *  _POSIX_Signals_Clear_signals
>>     int                 signo,
>>     siginfo_t          *info,
>> @@ -70,11 +70,11 @@ bool _POSIX_signals_Clear_signals(
>>       if ( is_global ) {
>> -       if ( mask & (_POSIX_signals_Pending & signals_blocked) ) {
>> +       if ( mask & (_POSIX_Signals_Pending & signals_blocked) ) {
>> -             _Chain_Get_unprotected( &_POSIX_signals_Siginfo[ signo ] );
>> -           _POSIX_signals_Clear_process_signals( signo );
>> +             _Chain_Get_unprotected( &_POSIX_Signals_Siginfo[ signo ] );
>> +           _POSIX_Signals_Clear_process_signals( signo );
>>               *  It may be impossible to get here with an empty chain
>>               *  BUT until that is proven we need to be defensive and
>> @@ -83,13 +83,13 @@ bool _POSIX_signals_Clear_signals(
>>              if ( psiginfo ) {
>>                *info = psiginfo->Info;
>>                _Chain_Append_unprotected(
>>                  &psiginfo->Node
>>              } else
>>                do_callout = false;
>>            do_callout = true;
>>       } else {
>> diff --git a/cpukit/posix/src/psignalsetprocesssignals.c
>> b/cpukit/posix/src/psignalsetprocesssignals.c
>> index 92c1d81..7ecb8e6 100644
>> --- a/cpukit/posix/src/psignalsetprocesssignals.c
>> +++ b/cpukit/posix/src/psignalsetprocesssignals.c
>> @@ -34,13 +34,13 @@
>>   #include <stdio.h>
>>     sigset_t   mask
>>     ISR_Level  level;
>> -    _POSIX_signals_Pending |= mask;
>> +    _POSIX_Signals_Pending |= mask;
>> diff --git a/cpukit/posix/src/psignalunblockthread.c
>> b/cpukit/posix/src/psignalunblockthread.c
>> index 0603a7f..29316bd 100644
>> --- a/cpukit/posix/src/psignalunblockthread.c
>> +++ b/cpukit/posix/src/psignalunblockthread.c
>> @@ -34,7 +34,7 @@
>>   #include <stdio.h>
>>     int              signo,
>>     siginfo_t       *info
>> diff --git a/cpukit/posix/src/pthreadkill.c
>> b/cpukit/posix/src/pthreadkill.c
>> index e0f3950..18cf36c 100644
>> --- a/cpukit/posix/src/pthreadkill.c
>> +++ b/cpukit/posix/src/pthreadkill.c
>> @@ -53,13 +53,13 @@ int pthread_kill(
>>          *  If sig == 0 then just validate arguments
>>         if ( sig ) {
>> -        if ( _POSIX_signals_Vectors[ sig ].sa_handler == SIG_IGN ) {
>> +        if ( _POSIX_Signals_Vectors[ sig ].sa_handler == SIG_IGN ) {
>>             return 0;
>> @@ -68,7 +68,7 @@ int pthread_kill(
>>           api->signals_pending |= signo_to_mask( sig );
>> -        (void) _POSIX_signals_Unblock_thread( the_thread, sig, NULL );
>> +        (void) _POSIX_Signals_Unblock_thread( the_thread, sig, NULL );
>>           if ( _ISR_Is_in_progress() && _Thread_Is_executing( the_thread )
>>            _Thread_Dispatch_necessary = true;
>> diff --git a/cpukit/posix/src/pthreadsigmask.c
>> b/cpukit/posix/src/pthreadsigmask.c
>> index 3f985bf..6b340ca 100644
>> --- a/cpukit/posix/src/pthreadsigmask.c
>> +++ b/cpukit/posix/src/pthreadsigmask.c
>> @@ -69,7 +69,7 @@ int pthread_sigmask(
>>     /* XXX evaluate the new set */
>>     if ( ~api->signals_blocked &
>> -       (api->signals_pending | _POSIX_signals_Pending) ) {
>> +       (api->signals_pending | _POSIX_Signals_Pending) ) {
>>       _Thread_Dispatch();
>> diff --git a/cpukit/posix/src/sigaction.c b/cpukit/posix/src/sigaction.c
>> index cfcc65c..ac2b4c9 100644
>> --- a/cpukit/posix/src/sigaction.c
>> +++ b/cpukit/posix/src/sigaction.c
>> @@ -45,7 +45,7 @@ int sigaction(
>>     ISR_Level     level;
>>     if ( oact )
>> -    *oact = _POSIX_signals_Vectors[ sig ];
>> +    *oact = _POSIX_Signals_Vectors[ sig ];
>>     if ( !sig )
>>       rtems_set_errno_and_return_minus_one( EINVAL );
>> @@ -77,10 +77,10 @@ int sigaction(
>>         if ( act->sa_handler == SIG_DFL ) {
>> -        _POSIX_signals_Vectors[ sig ] = _POSIX_signals_Default_vectors[
>> sig ];
>> +        _POSIX_Signals_Vectors[ sig ] = _POSIX_Signals_Default_vectors[
>> sig ];
>>         } else {
>> -         _POSIX_signals_Clear_process_signals( sig );
>> -         _POSIX_signals_Vectors[ sig ] = *act;
>> +         _POSIX_Signals_Clear_process_signals( sig );
>> +         _POSIX_Signals_Vectors[ sig ] = *act;
>> diff --git a/cpukit/posix/src/sigpending.c b/cpukit/posix/src/sigpending.c
>> index 44dbe93..dbd6329 100644
>> --- a/cpukit/posix/src/sigpending.c
>> +++ b/cpukit/posix/src/sigpending.c
>> @@ -37,7 +37,7 @@ int sigpending(
>>     api = _Thread_Executing->API_Extensions[ THREAD_API_POSIX ];
>> -  *set = api->signals_pending | _POSIX_signals_Pending;
>> +  *set = api->signals_pending | _POSIX_Signals_Pending;
>>     return 0;
>> diff --git a/cpukit/posix/src/sigtimedwait.c
>> b/cpukit/posix/src/sigtimedwait.c
>> index ef8bbdf..92ff89d 100644
>> --- a/cpukit/posix/src/sigtimedwait.c
>> +++ b/cpukit/posix/src/sigtimedwait.c
>> @@ -29,7 +29,7 @@
>>   #include <rtems/score/isr.h>
>> -static int _POSIX_signals_Get_lowest(
>> +static int _POSIX_Signals_Get_lowest(
>>     sigset_t   set
>> @@ -121,8 +121,8 @@ int sigtimedwait(
>>     if ( *set & api->signals_pending ) {
>>       /* XXX real info later */
>> -    the_info->si_signo = _POSIX_signals_Get_lowest( api->signals_pending
>> -    _POSIX_signals_Clear_signals(
>> +    the_info->si_signo = _POSIX_Signals_Get_lowest( api->signals_pending
>> +    _POSIX_Signals_Clear_signals(
>>         api,
>>         the_info->si_signo,
>>         the_info,
>> @@ -138,9 +138,9 @@ int sigtimedwait(
>>     /* Process pending signals? */
>> -  if ( *set & _POSIX_signals_Pending ) {
>> -    signo = _POSIX_signals_Get_lowest( _POSIX_signals_Pending );
>> -    _POSIX_signals_Clear_signals( api, signo, the_info, true, false );
>> +  if ( *set & _POSIX_Signals_Pending ) {
>> +    signo = _POSIX_Signals_Get_lowest( _POSIX_Signals_Pending );
>> +    _POSIX_Signals_Clear_signals( api, signo, the_info, true, false );
>>       the_info->si_signo = signo;
>> @@ -152,13 +152,13 @@ int sigtimedwait(
>>     the_info->si_signo = -1;
>> -    the_thread->Wait.queue           = &_POSIX_signals_Wait_queue;
>> +    the_thread->Wait.queue           = &_POSIX_Signals_Wait_queue;
>>       the_thread->Wait.return_code     = EINTR;
>>       the_thread->Wait.option          = *set;
>>       the_thread->Wait.return_argument = the_info;
>> -    _Thread_queue_Enter_critical_section( &_POSIX_signals_Wait_queue );
>> +    _Thread_queue_Enter_critical_section( &_POSIX_Signals_Wait_queue );
>> -    _Thread_queue_Enqueue( &_POSIX_signals_Wait_queue, interval );
>> +    _Thread_queue_Enqueue( &_POSIX_Signals_Wait_queue, interval );
>> @@ -166,7 +166,7 @@ int sigtimedwait(
>>      * the signal.
>> -  _POSIX_signals_Clear_signals( api, the_info->si_signo, the_info, false,
>> false );
>> +  _POSIX_Signals_Clear_signals( api, the_info->si_signo, the_info, false,
>> false );
>>     /* Set errno only if return code is not EINTR or
>>      * if EINTR was caused by a signal being caught, which
>> diff --git a/cpukit/posix/src/ualarm.c b/cpukit/posix/src/ualarm.c
>> index e9a4bb8..4a1b176 100644
>> --- a/cpukit/posix/src/ualarm.c
>> +++ b/cpukit/posix/src/ualarm.c
>> @@ -27,10 +27,10 @@
>> - *  _POSIX_signals_Ualarm_TSR
>> + *  _POSIX_Signals_Ualarm_TSR
>> -static void _POSIX_signals_Ualarm_TSR(
>> +static void _POSIX_Signals_Ualarm_TSR(
>> @@ -44,7 +44,7 @@ static void _POSIX_signals_Ualarm_TSR(
>>      * If the reset interval is non-zero, reschedule ourselves.
>> -  _Watchdog_Reset( &_POSIX_signals_Ualarm_timer );
>> +  _Watchdog_Reset( &_POSIX_Signals_Ualarm_timer );
>>   useconds_t ualarm(
>> @@ -57,14 +57,14 @@ useconds_t ualarm(
>>     Watchdog_Interval ticks;
>>     struct timespec   tp;
>> -  the_timer = &_POSIX_signals_Ualarm_timer;
>> +  the_timer = &_POSIX_Signals_Ualarm_timer;
>> -    _Watchdog_Initialize( the_timer, _POSIX_signals_Ualarm_TSR, 0, NULL
>> +    _Watchdog_Initialize( the_timer, _POSIX_Signals_Ualarm_TSR, 0, NULL
>>     } else {
>> diff --git a/cpukit/sapi/src/posixapi.c b/cpukit/sapi/src/posixapi.c
>> index bd7aabd..c960692 100644
>> --- a/cpukit/sapi/src/posixapi.c
>> +++ b/cpukit/sapi/src/posixapi.c
>> @@ -61,7 +61,7 @@ void _POSIX_API_Initialize(void)
>>     _Objects_Information_table[OBJECTS_POSIX_API] = _POSIX_Objects;
>> -  _POSIX_signals_Manager_Initialization();
>> +  _POSIX_Signals_Manager_initialization();
>>     _POSIX_Threads_Manager_initialization();
>>     _POSIX_Condition_variables_Manager_initialization();
>>     _POSIX_Key_Manager_initialization();
>> diff --git a/testsuites/psxtests/ChangeLog b/testsuites/psxtests/ChangeLog
>> index 3cde243..9ed3df1 100644
>> --- a/testsuites/psxtests/ChangeLog
>> +++ b/testsuites/psxtests/ChangeLog
>> @@ -1281,7 +1281,7 @@
>>          * Makefile.am, configure.ac: Add a test to exercise an odd case
>> in
>> -       _POSIX_signals_Clear_signals.
>> +       _POSIX_Signals_Clear_signals.
>>          * psxsignal05/.cvsignore, psxsignal05/Makefile.am,
>> psxsignal05/init.c,
>>          psxsignal05/psxsignal05.doc, psxsignal05/psxsignal05.scn: New
>> files.
>> diff --git a/testsuites/psxtests/psx15/init.c
>> b/testsuites/psxtests/psx15/init.c
>> index cc1f01c..14093d7 100644
>> --- a/testsuites/psxtests/psx15/init.c
>> +++ b/testsuites/psxtests/psx15/init.c
>> @@ -28,7 +28,7 @@ rtems_task Init(rtems_task_argument argument);
>>    * This test case shows that post switch extension handlers must cope
>> with
>> - * already deleted resources (e.g.
>> _POSIX_signals_Post_switch_extension()).
>> + * already deleted resources (e.g.
>> _POSIX_Signals_Post_switch_extension()).
>>    * The thread delete extensions run with thread dispatching enabled.
>> Only the
>>    * allocation mutex is locked.
>> diff --git a/testsuites/psxtests/psxsignal01/init.c
>> b/testsuites/psxtests/psxsignal01/init.c
>> index 8a85bef..a1dfef8 100644
>> --- a/testsuites/psxtests/psxsignal01/init.c
>> +++ b/testsuites/psxtests/psxsignal01/init.c
>> @@ -28,7 +28,7 @@ rtems_timer_service_routine Signal_duringISR_TSR(
>>   typedef void (*sighandler_t)(int);
>>   sighandler_t signal(int signum, sighandler_t handler);
>> -extern void _POSIX_signals_Abnormal_termination_handler( int signo );
>> +extern void _POSIX_Signals_Abnormal_termination_handler( int signo );
>>   volatile int Signal_occurred;
>>   volatile int Signal_count;
>> @@ -233,7 +233,7 @@ void *POSIX_Init(
>>     puts("*** Validate unexpected program termination ***");
>>     puts( "*** END OF POSIX TEST SIGNAL ***" );
>> -  _POSIX_signals_Abnormal_termination_handler( SIGUSR1 );
>> +  _POSIX_Signals_Abnormal_termination_handler( SIGUSR1 );
>>     status = sleep( 1 );
>>     puts( "ERROR==> Expected program termination");
>> diff --git a/testsuites/psxtests/psxsignal05/init.c
>> b/testsuites/psxtests/psxsignal05/init.c
>> index 04c7879..47ddf99 100644
>> --- a/testsuites/psxtests/psxsignal05/init.c
>> +++ b/testsuites/psxtests/psxsignal05/init.c
>> @@ -69,14 +69,14 @@ void *POSIX_Init(
>>     sigaction( SIGNAL_TWO, &act, NULL );
>>     printf(
>> -   "Init - _POSIX_signals_Clear_signals when signals pending but\n"
>> +   "Init - _POSIX_Signals_Clear_signals when signals pending but\n"
>>      "Init -    not queued on SA_SIGINFO configured signal.\n"
>>     /* cheat and put signal directly in */
>> -  _POSIX_signals_Pending |= signo_to_mask( SIGUSR1 );
>> +  _POSIX_Signals_Pending |= signo_to_mask( SIGUSR1 );
>> -  bc = _POSIX_signals_Clear_signals(
>> +  bc = _POSIX_Signals_Clear_signals(
>>       _Thread_Executing->API_Extensions[ THREAD_API_POSIX ],
>>       SIGNAL_ONE,
>>       &info,
>> diff --git a/testsuites/psxtests/psxsignal05/psxsignal05.doc
>> b/testsuites/psxtests/psxsignal05/psxsignal05.doc
>> index b09b978..74285fd 100644
>> --- a/testsuites/psxtests/psxsignal05/psxsignal05.doc
>> +++ b/testsuites/psxtests/psxsignal05/psxsignal05.doc
>> @@ -19,7 +19,7 @@ directives:
>>   concepts:
>> -+ Ensure if _POSIX_signals_Clear_signals is called to clear a process
>> wide
>> ++ Ensure if _POSIX_Signals_Clear_signals is called to clear a process
>> wide
>>     SA_SIGINFO signal which is pending but there is not a queued
>> SA_SIGINFO
>>     structure, then things happen correctly.
>> diff --git a/testsuites/psxtests/psxsignal05/psxsignal05.scn
>> b/testsuites/psxtests/psxsignal05/psxsignal05.scn
>> index 210c515..20509e4 100644
>> --- a/testsuites/psxtests/psxsignal05/psxsignal05.scn
>> +++ b/testsuites/psxtests/psxsignal05/psxsignal05.scn
>> @@ -1,4 +1,4 @@
>>   *** POSIX TEST SIGNAL 05 ***
>> -Init - _POSIX_signals_Clear_signals when signals pending but
>> +Init - _POSIX_Signals_Clear_signals when signals pending but
>>   *** END OF POSIX TEST SIGNAL 05 ***
>> diff --git a/testsuites/psxtests/psxualarm/init.c
>> b/testsuites/psxtests/psxualarm/init.c
>> index 19c9e44..24ff82d 100644
>> --- a/testsuites/psxtests/psxualarm/init.c
>> +++ b/testsuites/psxtests/psxualarm/init.c
>> @@ -26,7 +26,7 @@ rtems_timer_service_routine Signal_duringISR_TSR(
>> 1.7.10.4
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
