PATCH: Raspberry Pi BSP version 2
Alan Cudmore alan.cudmore at gmail.com
Sat Mar 23 16:30:38 UTC 2013
Hi,
The following patch is for the Raspberry Pi BSP. I cleaned up a number
of issues including:
- fixed file header info
- renamed from raspberry_pi to raspberrypi
- converted console driver to the shared mode
- using the higher level interrupt calls in the clock driver
The BSP is still very basic and has a number of limitations:
- console is polled and hard coded at 115k
- benchmark timer code is present but does not seem to work properly
- support for many devices is still missing ( SD card, USB, Network,
Graphics console, etc ) But that leaves plenty of room for improvement
for GSOC students!
The BSP builds on the latest Git head, and all of the examples and tests
I have tried work. ( ticker, unlimited, hello, paranoia, a selection of
the sptests etc )
Please let me know if there are any more changes needed.
Thanks,
Alan
diff --git a/c/src/lib/libbsp/arm/acinclude.m4
b/c/src/lib/libbsp/arm/acinclude.m4
index 6214bb7..9512b26 100644
--- a/c/src/lib/libbsp/arm/acinclude.m4
+++ b/c/src/lib/libbsp/arm/acinclude.m4
@@ -24,8 +24,6 @@ AC_DEFUN([RTEMS_CHECK_BSPDIR],
      AC_CONFIG_SUBDIRS([lpc32xx]);;
    nds )
      AC_CONFIG_SUBDIRS([nds]);;
-  raspberrypi )
-    AC_CONFIG_SUBDIRS([raspberrypi]);;
    rtl22xx )
      AC_CONFIG_SUBDIRS([rtl22xx]);;
    smdk2410 )
diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
deleted file mode 100644
index b999562..0000000
--- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
+++ /dev/null
@@ -1,154 +0,0 @@
-# @file
-# @brief Makefile of LibBSP for the raspberrypi board.
-ACLOCAL_AMFLAGS = -I ../../../../aclocal
-include $(top_srcdir)/../../../../automake/compile.am
-include_bspdir = $(includedir)/bsp
-include_libcpudir = $(includedir)/libcpu
-dist_project_lib_DATA = bsp_specs
-# Header                                                     #
-include_HEADERS = include/bsp.h
-include_HEADERS += ../../shared/include/tm27.h
-nodist_include_HEADERS = ../../shared/include/coverhd.h \
-    include/bspopts.h
-nodist_include_bsp_HEADERS = ../../shared/include/bootcard.h
-include_bsp_HEADERS =
-include_bsp_HEADERS += ../../shared/include/utility.h
-include_bsp_HEADERS += ../../shared/include/irq-generic.h
-include_bsp_HEADERS += ../../shared/include/irq-info.h
-include_bsp_HEADERS += ../../shared/include/stackalloc.h
-include_bsp_HEADERS += ../../shared/include/uart-output-char.h
-include_bsp_HEADERS += ../../shared/tod.h
-include_bsp_HEADERS += ../shared/include/linker-symbols.h
-include_bsp_HEADERS += ../shared/include/start.h
-include_bsp_HEADERS += ../shared/lpc/include/lpc-timer.h
-include_bsp_HEADERS += ../shared/lpc/include/lpc-dma.h
-include_bsp_HEADERS += include/irq.h
-include_bsp_HEADERS += include/mmu.h
-include_bsp_HEADERS += include/usart.h
-include_bsp_HEADERS += include/raspberrypi.h
-include_libcpu_HEADERS = ../../../libcpu/arm/shared/include/cache_.h \
-    ../../../libcpu/arm/shared/include/arm-cp15.h
-# Data                                                       #
-noinst_LIBRARIES = libbspstart.a
-libbspstart_a_SOURCES = ../shared/start/start.S
-project_lib_DATA = start.$(OBJEXT)
-project_lib_DATA += startup/linkcmds
-project_lib_DATA += ../shared/startup/linkcmds.base
-EXTRA_DIST = startup/linkcmds
-# LibBSP                                                     #
-noinst_LIBRARIES += libbsp.a
-libbsp_a_SOURCES =
-libbsp_a_CPPFLAGS =
-libbsp_a_LIBADD =
-# Shared
-libbsp_a_SOURCES += ../../shared/bootcard.c
-libbsp_a_SOURCES += ../../shared/bspclean.c
-libbsp_a_SOURCES += ../../shared/bspgetworkarea.c
-libbsp_a_SOURCES += ../../shared/bsplibc.c
-libbsp_a_SOURCES += ../../shared/bsppost.c
-libbsp_a_SOURCES += ../../shared/bsppredriverhook.c
-libbsp_a_SOURCES += ../../shared/bsppretaskinghook.c
-libbsp_a_SOURCES += ../../shared/gnatinstallhandler.c
-libbsp_a_SOURCES += ../../shared/sbrk.c
-libbsp_a_SOURCES += ../../shared/src/stackalloc.c
-libbsp_a_SOURCES += ../shared/abort/simple_abort.c
-libbsp_a_SOURCES += ../shared/startup/bsp-start-memcpy.S
-# Startup
-libbsp_a_SOURCES += startup/bspreset.c
-libbsp_a_SOURCES += startup/bspstart.c
-# IRQ
-libbsp_a_SOURCES += ../../shared/src/irq-default-handler.c
-libbsp_a_SOURCES += ../../shared/src/irq-generic.c
-libbsp_a_SOURCES += ../../shared/src/irq-info.c
-libbsp_a_SOURCES += ../../shared/src/irq-legacy.c
-libbsp_a_SOURCES += ../../shared/src/irq-server.c
-libbsp_a_SOURCES += ../../shared/src/irq-shell.c
-libbsp_a_SOURCES += irq/irq.c
-# Console
-libbsp_a_SOURCES += ../../shared/console.c
-libbsp_a_SOURCES += ../../shared/console_control.c
-libbsp_a_SOURCES += ../../shared/console_read.c
-libbsp_a_SOURCES += ../../shared/console_select.c
-libbsp_a_SOURCES += ../../shared/console_write.c
-libbsp_a_SOURCES += console/console-config.c
-libbsp_a_SOURCES += console/usart.c
-# clock
-libbsp_a_SOURCES += clock/clockdrv.c ../../../shared/clockdrv_shell.h
-# Timer
-libbsp_a_SOURCES += misc/timer.c
-# RTC
-# SSP
-# I2C
-# Cache
-libbsp_a_SOURCES += ../../../libcpu/shared/src/cache_manager.c
-libbsp_a_SOURCES += ../../../libcpu/arm/shared/include/cache_.h
-libbsp_a_CPPFLAGS += -I$(srcdir)/../../../libcpu/arm/shared/include
-# Start hooks
-libbsp_a_SOURCES += startup/bspstarthooks.c
-# Network                                                    #
-#if HAS_NETWORKING
-#noinst_PROGRAMS = network.rel
-#network_rel_SOURCES = ../shared/lpc/network/lpc-ethernet.c
-#network_rel_CPPFLAGS = $(AM_CPPFLAGS)
-D__INSIDE_RTEMS_BSD_TCPIP_STACK__ -D__BSD_VISIBLE
-#network_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
-#libbsp_a_LIBADD += network.rel
-#endif
-#                  Special
Rules                                              #
-DISTCLEANFILES = include/bspopts.h
-include $(srcdir)/preinstall.am
-include $(top_srcdir)/../../../../automake/local.am
diff --git a/c/src/lib/libbsp/arm/raspberrypi/README
b/c/src/lib/libbsp/arm/raspberrypi/README
index 7c92d55..0000000
--- a/c/src/lib/libbsp/arm/raspberrypi/README
+++ /dev/null
@@ -1,65 +0,0 @@
-BSP for the Raspberry Pi ARM board
-This is a basic port that should work on either Model A or Model B.
-It currently supports the following devices:
-    o Console using the PL011 UART0
-       The console driver only works with polled mode right now,
-       the interrupt code is there, but it does not work yet.
-       The console driver is currently hardcoded at 115k 8N1
-    o Clock uses the internal ARM timer
-       The Raspberry Pi can be overclocked through the config.txt file,
this
-       would affect the duration of the clock tick.
-    o Benchmark timer reads the lower 32 bit GPU timer register
-To run an RTEMS binary, it must be stripped and loaded on the SD card
along with
-the following files:
-  bootcode.bin
-  config.txt
-  loader.bin
-  start.elf
-  kernel.img ( the RTEMS binary, you can change the name in config.txt )
-These files can be obtained from a Linux installation image, or from here:
-https://github.com/raspberrypi/firmware
-I used an old 256MB SD card to boot RTEMS.
-Much more information about the SD card file and bootloader can be
found here:
-http://elinux.org/RPi_Hub
-http://www.raspberrypi.org
-The linker script is set up for 128MB, so it can be used with a GPU/ARM
split
-of 128/128.
-The bootloader that is used on the SD card determines the split of RAM
between the
-ARM and the GPU. It might make sense to adjust the GPU/ARM memory split
to give
-more memory to RTEMS, especially on a 512MB board.
-To do:
-    It would be nice to get support in the BSP for the following:
-    o SD card
-    o USB and USB 10/100 network chip on Model B
-    o SPI
-    o GPIO
-    o ARM MMU
-    o Graphics console
-    o Sound
-Credits and links:
-  There is a wealth of code and information to reference on the
raspberrypi.org bare metal forums:
-  http://www.raspberrypi.org/phpBB3/viewforum.php?f=72
-  I found information about how to program the timers, interrupts, and
UART 0
-  from the examples provided by:
-  David Welch:
-  https://github.com/dwelch67/raspberrypi
-  The readme file at his github repository has valuable information
about connecting a UART cable, JTAG etc.
-  Steve Bate:
-  http://www.stevebate.net/chibios-rpi/GettingStarted.html
-  Steve provided a port of the Chibios RTOS to the raspberry Pi
-  James Walmsley:
-  http://www.raspberrypi.org/phpBB3/viewtopic.php?f=72&t=22423
-  James ported FreeRTOS to the raspberry Pi.
diff --git a/c/src/lib/libbsp/arm/raspberrypi/bsp_specs
b/c/src/lib/libbsp/arm/raspberrypi/bsp_specs
index 082653a..0000000
--- a/c/src/lib/libbsp/arm/raspberrypi/bsp_specs
+++ /dev/null
@@ -1,13 +0,0 @@
-%rename endfile old_endfile
-%rename startfile old_startfile
-%rename link old_link
-*startfile:
-%{!qrtems: %(old_startfile)} \
-%{!nostdlib: %{qrtems: start.o%s crti.o%s crtbegin.o%s -e _start}}
-*link:
-%{!qrtems: %(old_link)} %{qrtems: -dc -dp -N}
-*endfile:
-%{!qrtems: *(old_endfiles)} %{qrtems: crtend.o%s crtn.o%s }
diff --git a/c/src/lib/libbsp/arm/raspberrypi/clock/clockdrv.c
b/c/src/lib/libbsp/arm/raspberrypi/clock/clockdrv.c
index af27c50..0000000
--- a/c/src/lib/libbsp/arm/raspberrypi/clock/clockdrv.c
+++ /dev/null
@@ -1,91 +0,0 @@
- * BCM2835 Clock driver
- * Copyright (c) 2013 Alan Cudmore
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.com/license/LICENSE
-#include <rtems.h>
-#include <bsp.h>
-#include <bsp/irq.h>
-#include <bsp/raspberrypi.h>
-/* This is defined in ../../../shared/clockdrv_shell.h */
-void Clock_isr(rtems_irq_hdl_param arg);
-static void raspberrypi_clock_at_tick(void)
-   BCM2835_REG(BCM2835_TIMER_CLI) = 0;
-static void raspberrypi_clock_handler_install(void)
-  rtems_status_code sc = RTEMS_SUCCESSFUL;
-  sc = rtems_interrupt_handler_install(
-    BCM2835_IRQ_ID_TIMER_0,
-    "Clock",
-    RTEMS_INTERRUPT_UNIQUE,
-    (rtems_interrupt_handler) Clock_isr,
-    NULL
-  if (sc != RTEMS_SUCCESSFUL) {
-    rtems_fatal_error_occurred(0xdeadbeef);
-static void raspberrypi_clock_initialize(void)
-   BCM2835_REG(BCM2835_TIMER_CTL) = 0x003E0000;
-   BCM2835_REG(BCM2835_TIMER_LOD) = 10000 - 1;
-   BCM2835_REG(BCM2835_TIMER_RLD) = 10000 - 1;
-   BCM2835_REG(BCM2835_TIMER_DIV) = BCM2835_TIMER_PRESCALE;
-   BCM2835_REG(BCM2835_TIMER_CTL) = 0x003E00A2;
-static void raspberrypi_clock_cleanup(void)
-  /* Remove interrupt handler */
-  sc = rtems_interrupt_handler_remove(
-    NULL
- *  Return the nanoseconds since last tick
-static uint32_t raspberrypi_clock_nanoseconds_since_last_tick(void)
-  return 0;
-#define Clock_driver_support_at_tick() raspberrypi_clock_at_tick()
-#define Clock_driver_support_initialize_hardware()
raspberrypi_clock_initialize()
-#define Clock_driver_support_install_isr(isr, old_isr) \
-  do {                                                 \
-    raspberrypi_clock_handler_install();               \
-    old_isr = NULL;                                    \
-  } while (0)
-#define Clock_driver_support_shutdown_hardware()
raspberrypi_clock_cleanup()
-#define Clock_driver_nanoseconds_since_last_tick \
-  raspberrypi_clock_nanoseconds_since_last_tick
-#include "../../../shared/clockdrv_shell.h"
diff --git a/c/src/lib/libbsp/arm/raspberrypi/configure.ac
b/c/src/lib/libbsp/arm/raspberrypi/configure.ac
index 9bd6883..0000000
--- a/c/src/lib/libbsp/arm/raspberrypi/configure.ac
+++ /dev/null
@@ -1,31 +0,0 @@
-# @file
-# @brief Configure script of LibBSP for the Raspberry Pi boards.
-AC_PREREQ([2.68])
-AC_INIT([rtems-c-src-lib-libbsp-arm-raspberrypi],[_RTEMS_VERSION],[http://www.rtems.org/bugzilla])
-AC_CONFIG_SRCDIR([bsp_specs])
-RTEMS_TOP(../../../../../..)
-RTEMS_CANONICAL_TARGET_CPU
-AM_INIT_AUTOMAKE([no-define nostdinc foreign 1.12.2])
-RTEMS_BSP_CONFIGURE
-RTEMS_PROG_CC_FOR_TARGET
-RTEMS_CANONICALIZE_TOOLS
-RTEMS_PROG_CCAS
-RTEMS_CHECK_NETWORKING
-AM_CONDITIONAL(HAS_NETWORKING,test "$HAS_NETWORKING" = "yes")
-RTEMS_BSPOPTS_SET([BSP_START_RESET_VECTOR],[*],[])
-RTEMS_BSPOPTS_HELP([BSP_START_RESET_VECTOR],[reset vector address for
BSP start])
-RTEMS_BSP_CLEANUP_OPTIONS(0, 0)
-RTEMS_BSP_LINKCMDS
-AC_CONFIG_FILES([Makefile])
-AC_OUTPUT
diff --git a/c/src/lib/libbsp/arm/raspberrypi/console/console-config.c
b/c/src/lib/libbsp/arm/raspberrypi/console/console-config.c
index 8b2ff0c..0000000
--- a/c/src/lib/libbsp/arm/raspberrypi/console/console-config.c
+++ /dev/null
@@ -1,53 +0,0 @@
-#include <rtems/bspIo.h>
-#include <libchip/serial.h>
-#include <bspopts.h>
-#include <bsp/usart.h>
-console_tbl Console_Configuration_Ports [] = {
-      .sDeviceName = "/dev/ttyS0",
-      .deviceType = SERIAL_CUSTOM,
-      .pDeviceFns = &bcm2835_usart_fns,
-      .deviceProbe = NULL,
-      .pDeviceFlow = NULL,
-      .ulCtrlPort1 = BCM2835_UART0_BASE,
-      .ulCtrlPort2 = 0,
-      .ulClock = USART0_DEFAULT_BAUD,
-      .ulIntVector = BCM2835_IRQ_ID_UART
-#define PORT_COUNT \
-  (sizeof(Console_Configuration_Ports) \
-    / sizeof(Console_Configuration_Ports [0]))
-unsigned long Console_Configuration_Count = PORT_COUNT;
-static void output_char(char c)
-  const console_fns *con =
-    Console_Configuration_Ports [Console_Port_Minor].pDeviceFns;
-  if (c == '\n') {
-    con->deviceWritePolled((int) Console_Port_Minor, '\r');
-  con->deviceWritePolled((int) Console_Port_Minor, c);
-BSP_output_char_function_type BSP_output_char = output_char;
-BSP_polling_getchar_function_type BSP_poll_char = NULL;
diff --git a/c/src/lib/libbsp/arm/raspberrypi/console/usart.c
b/c/src/lib/libbsp/arm/raspberrypi/console/usart.c
index 75b2078..0000000
--- a/c/src/lib/libbsp/arm/raspberrypi/console/usart.c
+++ /dev/null
@@ -1,160 +0,0 @@
-#include <libchip/sersupp.h>
-#include <bsp.h>
-static void usart_delay(uint32_t n)
-   volatile uint32_t i = 0;
-   for(i = 0; i < n; i++);
-static rtems_vector_number usart_get_irq_number(const console_tbl *ct)
-   return ct->ulIntVector;
-static uint32_t usart_get_baud(const console_tbl *ct)
-   return ct->ulClock;
-static void usart_set_baud(int minor, int baud)
-   ** Nothing for now
-   return;
-static void usart_initialize(int minor)
-   unsigned int gpio_reg;
-   ** Program GPIO pins for UART 0
-   gpio_reg = BCM2835_REG(BCM2835_GPIO_GPFSEL1);
-   gpio_reg &= ~(7<<12);    /* gpio14 */
-   gpio_reg |=  (4<<12);    /* alt0   */
-   gpio_reg &= ~(7<<15);    /* gpio15 */
-   gpio_reg |=  (4<<15);    /* alt0   */
-   BCM2835_REG(BCM2835_GPIO_GPFSEL1) = gpio_reg;
-   BCM2835_REG(BCM2835_GPIO_GPPUD) = 0;
-   usart_delay(150);
-   BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = (1<<14)|(1<<15);
-   usart_delay(150);
-   BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = 0;
-   ** Init the PL011 UART
-   BCM2835_REG(BCM2835_UART0_CR)   = 0;
-   BCM2835_REG(BCM2835_UART0_ICR)  = 0x7FF;
-   BCM2835_REG(BCM2835_UART0_IMSC) = 0;
-   BCM2835_REG(BCM2835_UART0_IBRD) = 1;
-   BCM2835_REG(BCM2835_UART0_FBRD) = 40;
-   BCM2835_REG(BCM2835_UART0_LCRH) = 0x70;
-   BCM2835_REG(BCM2835_UART0_RSRECR) =  0;
-   BCM2835_REG(BCM2835_UART0_CR)   = 0x301;
-   BCM2835_REG(BCM2835_UART0_IMSC) = BCM2835_UART0_IMSC_RX;
-   usart_set_baud(minor, 115000);
-static int usart_first_open(int major, int minor, void *arg)
-  rtems_libio_open_close_args_t *oc = (rtems_libio_open_close_args_t *)
arg;
-  struct rtems_termios_tty *tty = (struct rtems_termios_tty *)
oc->iop->data1;
-  const console_tbl *ct = Console_Port_Tbl [minor];
-  console_data *cd = &Console_Port_Data [minor];
-  cd->termios_data = tty;
-  rtems_termios_set_initial_baud(tty, ct->ulClock);
-  return 0;
-static int usart_last_close(int major, int minor, void *arg)
-  return 0;
-static int usart_read_polled(int minor)
-   if (minor == 0)
-      if(((BCM2835_REG(BCM2835_UART0_FR)) & BCM2835_UART0_FR_RXFE) == 0)
-         return((BCM2835_REG(BCM2835_UART0_DR)) & 0xFF );
-      else
-         return -1;
-   else
-      printk("Unknown console minor number: %d\n", minor);
-      return -1;
-static void usart_write_polled(int minor, char c)
-   while (1)
-      if ((BCM2835_REG(BCM2835_UART0_FR) & BCM2835_UART0_FR_TXFF) == 0)
break;
-   BCM2835_REG(BCM2835_UART0_DR) = c;
-static ssize_t usart_write_support_polled(
-  int minor,
-  const char *s,
-  size_t n
-  ssize_t i = 0;
-  for (i = 0; i < n; ++i)
-    usart_write_polled(minor, s [i]);
-  return n;
-static int usart_set_attributes(int minor, const struct termios *term)
-  return -1;
-const console_fns bcm2835_usart_fns = {
-  .deviceProbe = libchip_serial_default_probe,
-  .deviceFirstOpen = usart_first_open,
-  .deviceLastClose = usart_last_close,
-  .deviceRead = usart_read_polled,
-  .deviceWrite = usart_write_support_polled,
-  .deviceInitialize = usart_initialize,
-  .deviceWritePolled = usart_write_polled,
-  .deviceSetAttributes = usart_set_attributes,
-  .deviceOutputUsesInterrupts = false
diff --git a/c/src/lib/libbsp/arm/raspberrypi/include/bsp.h
b/c/src/lib/libbsp/arm/raspberrypi/include/bsp.h
index cb34bd3..0000000
--- a/c/src/lib/libbsp/arm/raspberrypi/include/bsp.h
+++ /dev/null
@@ -1,38 +0,0 @@
- * @file
- * @ingroup raspberrypi
- * @brief Global BSP definitions.
-#ifndef LIBBSP_ARM_RASPBERRYPI_BSP_H
-#define LIBBSP_ARM_RASPBERRYPI_BSP_H
-#include <rtems.h>
-#include <rtems/console.h>
-#include <rtems/clockdrv.h>
-#ifdef __cplusplus
-extern "C" {
-#endif /* __cplusplus */
-#define BSP_FEATURE_IRQ_EXTENSION
-#ifdef __cplusplus
-#endif /* LIBBSP_ARM_RASPBERRYPI_BSP_H */
diff --git a/c/src/lib/libbsp/arm/raspberrypi/include/irq.h
b/c/src/lib/libbsp/arm/raspberrypi/include/irq.h
index 0e3769c..0000000
--- a/c/src/lib/libbsp/arm/raspberrypi/include/irq.h
+++ /dev/null
@@ -1,62 +0,0 @@
- * @file
- * @ingroup bsp_interrupt
- * @brief Interrupt definitions.
-#ifndef LIBBSP_ARM_RASBPERRYPI_IRQ_H
-#define LIBBSP_ARM_RASPBERRYPI_IRQ_H
-#ifndef ASM
-#include <rtems.h>
-#include <rtems/irq.h>
-#include <rtems/irq-extension.h>
-#define BCM2835_INTC_TOTAL_IRQ       64 + 8
-#define BCM2835_IRQ_ID_AUX           29
-#define BCM2835_IRQ_ID_SPI_SLAVE     43
-#define BCM2835_IRQ_ID_PWA0          45
-#define BCM2835_IRQ_ID_PWA1          46
-#define BCM2835_IRQ_ID_SMI           48
-#define BCM2835_IRQ_ID_GPIO_0        49
-#define BCM2835_IRQ_ID_GPIO_1        50
-#define BCM2835_IRQ_ID_GPIO_2        51
-#define BCM2835_IRQ_ID_GPIO_3        52
-#define BCM2835_IRQ_ID_I2C           53
-#define BCM2835_IRQ_ID_SPI           54
-#define BCM2835_IRQ_ID_PCM           55
-#define BCM2835_IRQ_ID_UART          57
-#define BCM2835_IRQ_ID_TIMER_0       64
-#define BCM2835_IRQ_ID_MAILBOX_0     65
-#define BCM2835_IRQ_ID_DOORBELL_0    66
-#define BCM2835_IRQ_ID_DOORBELL_1    67
-#define BCM2835_IRQ_ID_GPU0_HALTED   68
-#define BSP_INTERRUPT_VECTOR_MIN    (0)
-#define BSP_INTERRUPT_VECTOR_MAX    (BCM2835_INTC_TOTAL_IRQ - 1)
-#define BSP_IRQ_COUNT               (BCM2835_INTC_TOTAL_IRQ)
-void raspberrypi_set_exception_handler(Arm_symbolic_exception_name
exception,
-                                         void (*handler)(void));
-#endif /* ASM */
-#endif /* LIBBSP_ARM_RASPBERRYPI_IRQ_H */
diff --git a/c/src/lib/libbsp/arm/raspberrypi/include/mmu.h
b/c/src/lib/libbsp/arm/raspberrypi/include/mmu.h
index 50e9180..0000000
--- a/c/src/lib/libbsp/arm/raspberrypi/include/mmu.h
+++ /dev/null
@@ -1,68 +0,0 @@
- * @file
- * @ingroup rapberrypi_mmu
- * @brief MMU API.
- * Copyright (c) 2013 Alan Cudmore.
- * based on work by:
- * Copyright (c) 2009
- * embedded brains GmbH
- * Obere Lagerstr. 30
- * D-82178 Puchheim
- * Germany
- * <rtems at embedded-brains.de>
-#ifndef LIBBSP_ARM_RASPBERRYPI_MMU_H
-#define LIBBSP_ARM_RASPBERRYPI_MMU_H
-#include <libcpu/arm-cp15.h>
-#ifdef __cplusplus
-extern "C" {
- * @defgroup raspberrypi_mmu MMU Support
- * @brief MMU support.
-#define RASPBERRYPI_MMU_CLIENT_DOMAIN 15U
-#define RASPBERRYPI_MMU_READ_ONLY \
-  ((RASPBERRYPI_MMU_CLIENT_DOMAIN << ARM_MMU_SECT_DOMAIN_SHIFT) \
-    | ARM_MMU_SECT_DEFAULT)
-#define RASPBERRYPI_MMU_READ_ONLY_CACHED \
-  (RASPBERRYPI_MMU_READ_ONLY | ARM_MMU_SECT_C | ARM_MMU_SECT_B)
-#define RASPBERRYPI_MMU_READ_WRITE \
-    | ARM_MMU_SECT_AP_0 \
-#define RASPBERRYPI_MMU_READ_WRITE_CACHED \
-  (RASPBERRYPI_MMU_READ_WRITE | ARM_MMU_SECT_C | ARM_MMU_SECT_B)
-#ifdef __cplusplus
-#endif /* LIBBSP_ARM_RASPBERRYPI_MMU_H */
diff --git a/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h
b/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h
index 7d5b351..0000000
--- a/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h
+++ /dev/null
@@ -1,194 +0,0 @@
- * raspberrypi.h
-#ifndef LIBBSP_ARM_RASPBERRYPI_RASPBERRYPI_H
-#define LIBBSP_ARM_RASPBERRYPI_RASPBERRYPI_H
-#include <stdint.h>
-#include <bsp/utility.h>
- * @defgroup raspberrypi_reg Register Definitions
- * @brief Register definitions.
- * @name Register Macros
-#define BCM2835_REG(x)           (*(volatile uint32_t *)(x))
-#define BCM2835_BIT(n)           (1 << (n))
- * @name Internal ARM Timer Registers
-#define BCM2835_CLOCK_FREQ       250000000
-#define BCM2835_TIMER_BASE       (0x2000B400)
-#define BCM2835_TIMER_LOD        (BCM2835_TIMER_BASE+0x00)
-#define BCM2835_TIMER_VAL        (BCM2835_TIMER_BASE+0x04)
-#define BCM2835_TIMER_CTL        (BCM2835_TIMER_BASE+0x08)
-#define BCM2835_TIMER_CLI        (BCM2835_TIMER_BASE+0x0C)
-#define BCM2835_TIMER_RIS        (BCM2835_TIMER_BASE+0x10)
-#define BCM2835_TIMER_MIS        (BCM2835_TIMER_BASE+0x14)
-#define BCM2835_TIMER_RLD        (BCM2835_TIMER_BASE+0x18)
-#define BCM2835_TIMER_DIV        (BCM2835_TIMER_BASE+0x1C)
-#define BCM2835_TIMER_CNT        (BCM2835_TIMER_BASE+0x20)
-#define BCM2835_TIMER_PRESCALE    0xF9
- * @name GPIO Registers
-#define BCM2835_GPIO_REGS_BASE   (0x20200000)
-#define BCM2835_GPIO_GPFSEL1     (BCM2835_GPIO_REGS_BASE+0x04)
-#define BCM2835_GPIO_GPSET0      (BCM2835_GPIO_REGS_BASE+0x1C)
-#define BCM2835_GPIO_GPCLR0      (BCM2835_GPIO_REGS_BASE+0x28)
-#define BCM2835_GPIO_GPPUD       (BCM2835_GPIO_REGS_BASE+0x94)
-#define BCM2835_GPIO_GPPUDCLK0   (BCM2835_GPIO_REGS_BASE+0x98)
- * @name AUX Registers
-#define BCM2835_AUX_BASE         (0x20215000)
-#define AUX_ENABLES              (BCM2835_AUX_BASE+0x04)
-#define AUX_MU_IO_REG            (BCM2835_AUX_BASE+0x40)
-#define AUX_MU_IER_REG           (BCM2835_AUX_BASE+0x44)
-#define AUX_MU_IIR_REG           (BCM2835_AUX_BASE+0x48)
-#define AUX_MU_LCR_REG           (BCM2835_AUX_BASE+0x4C)
-#define AUX_MU_MCR_REG           (BCM2835_AUX_BASE+0x50)
-#define AUX_MU_LSR_REG           (BCM2835_AUX_BASE+0x54)
-#define AUX_MU_MSR_REG           (BCM2835_AUX_BASE+0x58)
-#define AUX_MU_SCRATCH           (BCM2835_AUX_BASE+0x5C)
-#define AUX_MU_CNTL_REG          (BCM2835_AUX_BASE+0x60)
-#define AUX_MU_STAT_REG          (BCM2835_AUX_BASE+0x64)
-#define AUX_MU_BAUD_REG          (BCM2835_AUX_BASE+0x68)
- * @name UART 0 (PL011) Registers
-#define BCM2835_UART0_BASE       (0x20201000)
-#define BCM2835_UART0_DR         (BCM2835_UART0_BASE+0x00)
-#define BCM2835_UART0_RSRECR     (BCM2835_UART0_BASE+0x04)
-#define BCM2835_UART0_FR         (BCM2835_UART0_BASE+0x18)
-#define BCM2835_UART0_ILPR       (BCM2835_UART0_BASE+0x20)
-#define BCM2835_UART0_IBRD       (BCM2835_UART0_BASE+0x24)
-#define BCM2835_UART0_FBRD       (BCM2835_UART0_BASE+0x28)
-#define BCM2835_UART0_LCRH       (BCM2835_UART0_BASE+0x2C)
-#define BCM2835_UART0_CR         (BCM2835_UART0_BASE+0x30)
-#define BCM2835_UART0_IFLS       (BCM2835_UART0_BASE+0x34)
-#define BCM2835_UART0_IMSC       (BCM2835_UART0_BASE+0x38)
-#define BCM2835_UART0_RIS        (BCM2835_UART0_BASE+0x3C)
-#define BCM2835_UART0_MIS        (BCM2835_UART0_BASE+0x40)
-#define BCM2835_UART0_ICR        (BCM2835_UART0_BASE+0x44)
-#define BCM2835_UART0_DMACR      (BCM2835_UART0_BASE+0x48)
-#define BCM2835_UART0_ITCR       (BCM2835_UART0_BASE+0x80)
-#define BCM2835_UART0_ITIP       (BCM2835_UART0_BASE+0x84)
-#define BCM2835_UART0_ITOP       (BCM2835_UART0_BASE+0x88)
-#define BCM2835_UART0_TDR        (BCM2835_UART0_BASE+0x8C)
-#define BCM2835_UART0_MIS_RX    0x10
-#define BCM2835_UART0_MIS_TX    0x20
-#define BCM2835_UART0_IMSC_RX   0x10
-#define BCM2835_UART0_IMSC_TX   0x20
-#define BCM2835_UART0_FR_RXFE   0x10
-#define BCM2835_UART0_FR_TXFF   0x20
-#define BCM2835_UART0_ICR_RX    0x10
-#define BCM2835_UART0_ICR_TX    0x20
- * @name IRQ Registers
-#define BCM2835_BASE_INTC         (0x2000B200)
-#define BCM2835_IRQ_BASIC         (BCM2835_BASE_INTC + 0x00)
-#define BCM2835_IRQ_PENDING1      (BCM2835_BASE_INTC + 0x04)
-#define BCM2835_IRQ_PENDING2      (BCM2835_BASE_INTC + 0x08)
-#define BCM2835_IRQ_FIQ_CTRL      (BCM2835_BASE_INTC + 0x0C)
-#define BCM2835_IRQ_ENABLE1       (BCM2835_BASE_INTC + 0x10)
-#define BCM2835_IRQ_ENABLE2       (BCM2835_BASE_INTC + 0x14)
-#define BCM2835_IRQ_ENABLE_BASIC  (BCM2835_BASE_INTC + 0x18)
-#define BCM2835_IRQ_DISABLE1      (BCM2835_BASE_INTC + 0x1C)
-#define BCM2835_IRQ_DISABLE2      (BCM2835_BASE_INTC + 0x20)
-#define BCM2835_IRQ_DISABLE_BASIC (BCM2835_BASE_INTC + 0x24)
- * @name GPU Timer Registers
- * NOTE: The GPU uses Compare registers 0 and 2 for
- *       it's own RTOS. 1 and 3 are available for use in
- *       RTEMS.
-#define BCM2835_GPU_TIMER_BASE    (0x20003000)
-#define BCM2835_GPU_TIMER_CS      (BCM2835_TIMER_BASE+0x00)
-#define BCM2835_GPU_TIMER_CLO     (BCM2835_TIMER_BASE+0x04)
-#define BCM2835_GPU_TIMER_CHI     (BCM2835_TIMER_BASE+0x08)
-#define BCM2835_GPU_TIMER_C0      (BCM2835_TIMER_BASE+0x0C)
-#define BCM2835_GPU_TIMER_C1      (BCM2835_TIMER_BASE+0x10)
-#define BCM2835_GPU_TIMER_C2      (BCM2835_TIMER_BASE+0x14)
-#define BCM2835_GPU_TIMER_C3      (BCM2835_TIMER_BASE+0x18)
-#endif /* LIBBSP_ARM_RASPBERRYPI_RASPBERRYPI_H */
diff --git a/c/src/lib/libbsp/arm/raspberrypi/include/usart.h
b/c/src/lib/libbsp/arm/raspberrypi/include/usart.h
index 26b4416..0000000
--- a/c/src/lib/libbsp/arm/raspberrypi/include/usart.h
+++ /dev/null
@@ -1,26 +0,0 @@
-#ifndef LIBBSP_ARM_RASPBERRYPI_USART_H
-#define LIBBSP_ARM_RASPBERRYPI_USART_H
-#ifdef __cplusplus
-extern "C" {
-#define USART0_DEFAULT_BAUD 115000
-extern const console_fns bcm2835_usart_fns;
-#ifdef __cplusplus
-#endif /* LIBBSP_ARM_RASPBERRYPI_USART_H */
diff --git a/c/src/lib/libbsp/arm/raspberrypi/irq/irq.c
b/c/src/lib/libbsp/arm/raspberrypi/irq/irq.c
index f0bd14b..0000000
--- a/c/src/lib/libbsp/arm/raspberrypi/irq/irq.c
+++ /dev/null
@@ -1,124 +0,0 @@
- * @file
- * @brief Interrupt support.
- * Germany
- * http://www.rtems.com/license/LICENSE.
-#include <rtems/score/armv4.h>
-#include <bsp.h>
-#include <bsp/irq-generic.h>
-#include <bsp/linker-symbols.h>
-#include <bsp/mmu.h>
-** This sets the main exception vectors
-                        Arm_symbolic_exception_name exception,
-    if ((unsigned) exception < MAX_EXCEPTIONS)
-        uint32_t *table = (uint32_t *) bsp_section_vector_begin +
MAX_EXCEPTIONS;
-        table [exception] = (uint32_t) handler;
-** Determine the source of the interrupt and dispatch the correct handler.
-void bsp_interrupt_dispatch(void)
-  rtems_vector_number vector = 255;
-  /* ARM timer */
-  if (BCM2835_REG(BCM2835_IRQ_BASIC) && 0x1)
-      vector = BCM2835_IRQ_ID_TIMER_0;
-  /* UART 0 */
-  else if ( BCM2835_REG(BCM2835_IRQ_BASIC) && BCM2835_BIT(19))
-      vector = BCM2835_IRQ_ID_UART;
-  if ( vector < 255 )
-      bsp_interrupt_handler_dispatch(vector);
-rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
-  rtems_interrupt_level  level;
-  rtems_interrupt_disable(level);
-   /* ARM Timer */
-  if ( vector == BCM2835_IRQ_ID_TIMER_0 )
-      BCM2835_REG(BCM2835_IRQ_ENABLE_BASIC) = 0x1;
-  /* UART 0 */
-  else if ( vector == BCM2835_IRQ_ID_UART )
-      BCM2835_REG(BCM2835_IRQ_ENABLE2) =  BCM2835_BIT(25);
-  rtems_interrupt_enable(level);
-  return RTEMS_SUCCESSFUL;
-rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
-      BCM2835_REG(BCM2835_IRQ_DISABLE_BASIC) = 0x1;
-      BCM2835_REG(BCM2835_IRQ_DISABLE2) = BCM2835_BIT(25);
-void bsp_interrupt_handler_default(rtems_vector_number vector)
-    printk("spurious interrupt: %u\n", vector);
-rtems_status_code bsp_interrupt_facility_initialize(void)
-   raspberrypi_set_exception_handler(ARM_EXCEPTION_IRQ,
_ARMV4_Exception_interrupt);
diff --git
a/c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.cfg
b/c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.cfg
index 189118c..0000000
--- a/c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.cfg
+++ /dev/null
@@ -1,24 +0,0 @@
-#  Config file for RASPBERRYPI
-#  $Id: $
-include $(RTEMS_ROOT)/make/custom/default.cfg
-RTEMS_CPU = arm
-CPU_CFLAGS =  -mcpu=arm1176jzf-s \
-             -fomit-frame-pointer -mfpu=vfp -mfloat-abi=soft \
-             -mabi=apcs-gnu -ffreestanding
-CFLAGS_OPTIMIZE_V = -O2 -g
-# This defines the operations performed on the linked executable.
-# is currently required.
-define bsp-post-link
-    $(OBJCOPY) -O binary --strip-all \
-        $(basename $@).exe $(basename $@)$(DOWNEXT)
-    $(SIZE) $(basename $@).exe
-endef
diff --git a/c/src/lib/libbsp/arm/raspberrypi/misc/timer.c
b/c/src/lib/libbsp/arm/raspberrypi/misc/timer.c
index c7ae27b..0000000
--- a/c/src/lib/libbsp/arm/raspberrypi/misc/timer.c
+++ /dev/null
@@ -1,49 +0,0 @@
- * @file
- * @brief Benchmark timer support.
- * Copyright (c) 2013 by Alan Cudmore
-#include <rtems.h>
-#include <rtems/timerdrv.h>
-static bool benchmark_timer_find_average_overhead = false;
-static uint64_t benchmark_timer_base;
-void benchmark_timer_initialize(void)
-  benchmark_timer_base = BCM2835_REG(BCM2835_GPU_TIMER_CLO);
-uint32_t benchmark_timer_read(void)
-  uint32_t delta = BCM2835_REG(BCM2835_GPU_TIMER_CLO) -
-  if (benchmark_timer_find_average_overhead)
-    return delta;
-  else
-    return BCM2835_REG(BCM2835_GPU_TIMER_CLO);
-void benchmark_timer_disable_subtracting_average_overhead(bool
-  benchmark_timer_find_average_overhead = find_average_overhead;
diff --git a/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
b/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
index 31c17b4..0000000
--- a/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
+++ /dev/null
@@ -1,136 +0,0 @@
-## Automatically generated by ampolish3 - Do not edit
-if AMPOLISH3
-$(srcdir)/preinstall.am: Makefile.am
-    $(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
-endif
-PREINSTALL_DIRS =
-DISTCLEANFILES += $(PREINSTALL_DIRS)
-all-local: $(TMPINSTALL_FILES)
-TMPINSTALL_FILES =
-CLEANFILES = $(TMPINSTALL_FILES)
-all-am: $(PREINSTALL_FILES)
-PREINSTALL_FILES =
-CLEANFILES += $(PREINSTALL_FILES)
-$(PROJECT_LIB)/$(dirstamp):
-    @$(MKDIR_P) $(PROJECT_LIB)
-    @: > $(PROJECT_LIB)/$(dirstamp)
-PREINSTALL_DIRS += $(PROJECT_LIB)/$(dirstamp)
-$(PROJECT_INCLUDE)/$(dirstamp):
-    @$(MKDIR_P) $(PROJECT_INCLUDE)
-    @: > $(PROJECT_INCLUDE)/$(dirstamp)
-PREINSTALL_DIRS += $(PROJECT_INCLUDE)/$(dirstamp)
-$(PROJECT_INCLUDE)/bsp/$(dirstamp):
-    @$(MKDIR_P) $(PROJECT_INCLUDE)/bsp
-    @: > $(PROJECT_INCLUDE)/bsp/$(dirstamp)
-PREINSTALL_DIRS += $(PROJECT_INCLUDE)/bsp/$(dirstamp)
-$(PROJECT_INCLUDE)/libcpu/$(dirstamp):
-    @$(MKDIR_P) $(PROJECT_INCLUDE)/libcpu
-    @: > $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
-PREINSTALL_DIRS += $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
-$(PROJECT_LIB)/bsp_specs: bsp_specs $(PROJECT_LIB)/$(dirstamp)
-    $(INSTALL_DATA) $< $(PROJECT_LIB)/bsp_specs
-PREINSTALL_FILES += $(PROJECT_LIB)/bsp_specs
-$(PROJECT_INCLUDE)/bsp.h: include/bsp.h $(PROJECT_INCLUDE)/$(dirstamp)
-    $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp.h
-$(PROJECT_INCLUDE)/tm27.h: ../../shared/include/tm27.h
-    $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/tm27.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/tm27.h
-$(PROJECT_INCLUDE)/coverhd.h: ../../shared/include/coverhd.h
-    $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/coverhd.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/coverhd.h
-$(PROJECT_INCLUDE)/bspopts.h: include/bspopts.h
-    $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bspopts.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bspopts.h
-$(PROJECT_INCLUDE)/bsp/bootcard.h: ../../shared/include/bootcard.h
-    $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/bootcard.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/bootcard.h
-$(PROJECT_INCLUDE)/bsp/utility.h: ../../shared/include/utility.h
-    $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/utility.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/utility.h
-$(PROJECT_INCLUDE)/bsp/irq-generic.h:
../../shared/include/irq-generic.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
-    $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-generic.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-generic.h
-$(PROJECT_INCLUDE)/bsp/irq-info.h: ../../shared/include/irq-info.h
-    $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-info.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-info.h
-$(PROJECT_INCLUDE)/bsp/stackalloc.h: ../../shared/include/stackalloc.h
-    $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/stackalloc.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/stackalloc.h
-$(PROJECT_INCLUDE)/bsp/uart-output-char.h:
../../shared/include/uart-output-char.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
-    $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/uart-output-char.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/uart-output-char.h
-$(PROJECT_INCLUDE)/bsp/tod.h: ../../shared/tod.h
-    $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/tod.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/tod.h
-$(PROJECT_INCLUDE)/bsp/linker-symbols.h:
../shared/include/linker-symbols.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
-    $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/linker-symbols.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/linker-symbols.h
-$(PROJECT_INCLUDE)/bsp/start.h: ../shared/include/start.h
-    $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/start.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/start.h
-$(PROJECT_INCLUDE)/bsp/lpc-timer.h: ../shared/lpc/include/lpc-timer.h
-    $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/lpc-timer.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/lpc-timer.h
-$(PROJECT_INCLUDE)/bsp/lpc-dma.h: ../shared/lpc/include/lpc-dma.h
-    $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/lpc-dma.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/lpc-dma.h
-$(PROJECT_INCLUDE)/bsp/irq.h: include/irq.h
-    $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq.h
-$(PROJECT_INCLUDE)/bsp/mmu.h: include/mmu.h
-    $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/mmu.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/mmu.h
-$(PROJECT_INCLUDE)/bsp/usart.h: include/usart.h
-    $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/usart.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/usart.h
-$(PROJECT_INCLUDE)/bsp/raspberrypi.h: include/raspberrypi.h
-    $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/raspberrypi.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/raspberrypi.h
-$(PROJECT_INCLUDE)/libcpu/arm-cp15.h:
-    $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/arm-cp15.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/arm-cp15.h
-$(PROJECT_LIB)/start.$(OBJEXT): start.$(OBJEXT) $(PROJECT_LIB)/$(dirstamp)
-    $(INSTALL_DATA) $< $(PROJECT_LIB)/start.$(OBJEXT)
-TMPINSTALL_FILES += $(PROJECT_LIB)/start.$(OBJEXT)
-$(PROJECT_LIB)/linkcmds: startup/linkcmds $(PROJECT_LIB)/$(dirstamp)
-    $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds
-TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds
-$(PROJECT_LIB)/linkcmds.base: ../shared/startup/linkcmds.base
-    $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.base
-TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.base
diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/bspreset.c
b/c/src/lib/libbsp/arm/raspberrypi/startup/bspreset.c
index 588a33e..0000000
--- a/c/src/lib/libbsp/arm/raspberrypi/startup/bspreset.c
+++ /dev/null
@@ -1,35 +0,0 @@
- * @file
- * @brief Reset code.
- * Based on work by:
- * Germany
-#include <rtems.h>
-#include <bsp/bootcard.h>
-void bsp_reset( void)
-  while (true) {
-    /* Do nothing */
diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/bspstart.c
b/c/src/lib/libbsp/arm/raspberrypi/startup/bspstart.c
index e48dd53..0000000
--- a/c/src/lib/libbsp/arm/raspberrypi/startup/bspstart.c
+++ /dev/null
@@ -1,29 +0,0 @@
- * @file
- * @brief Startup code.
-#include <bsp.h>
-#include <bsp/stackalloc.h>
-void bsp_start(void)
-    bsp_interrupt_initialize();
diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c
b/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c
index c7303bc..0000000
--- a/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c
+++ /dev/null
@@ -1,114 +0,0 @@
- * @file
- * Germany
-#include <stdbool.h>
-#include <bsp/start.h>
-#include <bsp/uart-output-char.h>
-static void BSP_START_TEXT_SECTION clear_bss(void)
-  const int *end = (const int *) bsp_section_bss_end;
-  int *out = (int *) bsp_section_bss_begin;
-  /* Clear BSS */
-  while (out != end) {
-    *out = 0;
-    ++out;
-static void BSP_START_TEXT_SECTION raspberrypi_cache_setup(void)
-  uint32_t ctrl = 0;
-  /* Disable MMU and cache, basic settings */
-  ctrl = arm_cp15_get_control();
-  ctrl &= ~(ARM_CP15_CTRL_I | ARM_CP15_CTRL_R | ARM_CP15_CTRL_C
-    | ARM_CP15_CTRL_V | ARM_CP15_CTRL_M);
-  ctrl |= ARM_CP15_CTRL_S | ARM_CP15_CTRL_A;
-  arm_cp15_set_control(ctrl);
-  arm_cp15_cache_invalidate();
-  arm_cp15_tlb_invalidate();
-void BSP_START_TEXT_SECTION bsp_start_hook_0(void)
-  raspberrypi_cache_setup();
-void BSP_START_TEXT_SECTION bsp_start_hook_1(void)
-    /* Copy .text section */
-    arm_cp15_instruction_cache_invalidate();
-    bsp_start_memcpy(
-                     (int *) bsp_section_text_begin,
-                     (const int *) bsp_section_text_load_begin,
-                     (size_t) bsp_section_text_size
-    /* Copy .rodata section */
-    bsp_start_memcpy(
-                     (int *) bsp_section_rodata_begin,
-                     (const int *) bsp_section_rodata_load_begin,
-                     (size_t) bsp_section_rodata_size
-    /* Copy .data section */
-    bsp_start_memcpy(
-                     (int *) bsp_section_data_begin,
-                     (const int *) bsp_section_data_load_begin,
-                     (size_t) bsp_section_data_size
-    /* Copy .fast_text section */
-    bsp_start_memcpy(
-                     (int *) bsp_section_fast_text_begin,
-                     (const int *) bsp_section_fast_text_load_begin,
-                     (size_t) bsp_section_fast_text_size
-    /* Copy .fast_data section */
-    bsp_start_memcpy(
-                     (int *) bsp_section_fast_data_begin,
-                     (const int *) bsp_section_fast_data_load_begin,
-                     (size_t) bsp_section_fast_data_size
-  /* Clear .bss section */
-  clear_bss();
diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds
b/c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds
index b9e6f02..0000000
--- a/c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds
+++ /dev/null
@@ -1,62 +0,0 @@
- * @file
- * @ingroup raspberry_pi
- * @brief Memory map.
- * @defgroup raspberry_pi Memory Map
- * @ingroup bsp_linker
- * @brief Raspberry Pi memory map.
- * <table>
- *   <tr><th>Region Name</th><th>Region Begin</th><th>Region Size</th></tr>
- * <tr><td>VECTOR_RAM</td><td>0x08000000</td><td>8k</td></tr>
- * <tr><td>RAM</td><td>0x80008000</td><td>128M</td></tr>
- * </table>
- * <table>
- *   <tr><th>Section Name</th><th>Section Runtime
Region</th><th>Section Load Region</th></tr>
- * <tr><td>.start</td><td>RAM</td><td></td></tr>
- * <tr><td>.vector</td><td>VECTOR_RAM</td><td></td></tr>
- * <tr><td>.text</td><td>RAM</td><td>RAM_EXT</td></tr>
- * <tr><td>.rodata</td><td>RAM</td><td>RAM_EXT</td></tr>
- * <tr><td>.data</td><td>RAM</td><td>RAM_EXT</td></tr>
- * <tr><td>.fast</td><td>RAM</td><td>RAM_EXT</td></tr>
- * <tr><td>.bss</td><td>RAM</td><td></td></tr>
- * <tr><td>.work</td><td>RAM</td><td></td></tr>
- * <tr><td>.stack</td><td>RAM</td><td></td></tr>
- * </table>
-MEMORY {
-        VECTOR_RAM     (AIW) : ORIGIN = 0x0       , LENGTH = 0x8000
-        RAM            (AIW) : ORIGIN = 0x00008000, LENGTH = 128M - 0x8000
-REGION_ALIAS ("REGION_START", RAM);
-REGION_ALIAS ("REGION_VECTOR", VECTOR_RAM);
-REGION_ALIAS ("REGION_TEXT", RAM);
-REGION_ALIAS ("REGION_TEXT_LOAD", RAM);
-REGION_ALIAS ("REGION_RODATA", RAM);
-REGION_ALIAS ("REGION_RODATA_LOAD", RAM);
-REGION_ALIAS ("REGION_DATA", RAM);
-REGION_ALIAS ("REGION_DATA_LOAD", RAM);
-REGION_ALIAS ("REGION_FAST_TEXT", RAM);
-REGION_ALIAS ("REGION_FAST_TEXT_LOAD", RAM);
-REGION_ALIAS ("REGION_FAST_DATA", RAM);
-REGION_ALIAS ("REGION_FAST_DATA_LOAD", RAM);
-REGION_ALIAS ("REGION_BSS", RAM);
-REGION_ALIAS ("REGION_WORK", RAM);
-REGION_ALIAS ("REGION_STACK", RAM);
-bsp_stack_irq_size = DEFINED (bsp_stack_irq_size) ? bsp_stack_irq_size
: 4096;
-bsp_stack_abt_size = DEFINED (bsp_stack_abt_size) ? bsp_stack_abt_size
: 1024;
-bsp_section_robarrier_align = DEFINED (bsp_section_robarrier_align) ?
bsp_section_robarrier_align : 1M;
-INCLUDE linkcmds.armv4
