Building and Testing a Canadian Cross-Compiler
Rempel, Cynthia cynt6007 at vandals.uidaho.edu
Sat Mar 23 18:12:43 UTC 2013
Thanks Sebastian Huber for finding that tutorial for a building a Canadian cross-compiler.
http://sourceforge.net/apps/trac/mingw-w64/wiki/Cross%20Win32%20and%20Win64%20compiler
I found a rather out-dated tutorial for testing Canadian cross-compilers
http://kegel.com/crosstool/current/doc/crosstest-howto.html
It's possible that there might be additional testing resources in
http://git.rtems.org/rtems-testing
I found gcc/do_one rather interesting...
I am curious now, if neither minGW nor Cygwin are needed for RTEMS except for the auto-tools, would it be feasible to automatically generate daily (or weekly) snap-shots that are already boot-strapped? And if so, what else would be required to get the RTEMS tool-set working for Windows users without Cygwin or minGW?
Thanks,
Cynthia Rempel
________________________________________
From: rtems-devel-bounces at rtems.org [rtems-devel-bounces at rtems.org] on behalf of Sebastian Huber [sebastian.huber at embedded-brains.de]
Sent: Saturday, March 23, 2013 1:26 AM
To: rtems-devel at rtems.org
Subject: Re: Autoconf 2.69 and mingw
On 22/03/13 22:50, Chris Johns wrote:
> I am looking for a suitable solution to my delete problem. There are
> also other problems, namely the -j option with make when Python
> threads are running cause problems in MSYS so parallel building is
> currently disabled.
> The solutions I have in mind, is to use Python or something other than
> 'rm' to delete the source tree or look at using a minimal Cygwin shell
> set up and to support cross-compiling the RTEMS tools. I am not
> interested in Cygwin specific RTEMS tool sets only native Windows tool
> sets. Cygwin is a long path to take because I need to create and test
> it, how-ever it fixes the parallel build issue and will make building
> faster.
The fastest way to build the MinGW tools is a Linux -> MinGW cross
compiler (Canadian Cross).
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
rtems-devel mailing list
http://www.rtems.org/mailman/listinfo/rtems-devel
