Building and Testing a Canadian Cross-Compiler
Wed Mar 27 23:11:23 UTC 2013
Rempel, Cynthia wrote:
>> From: Chris Johns [chrisj at rtems.org]
>> Shell support is needed to run 'configure' to build RTEMS.
> For an open project related to native Windows support would using a configure.bat be useful? I found this online.
> http://www.opensource.apple.com/source/emacs/emacs-59/emacs/nt/configure.bat
It does not help. The configure script is generated by autoconf and can
vary as configure.ac changes. None of this is coded by hand. Also there
are many configure scripts spread across a number of directories.
