[GSOC 2013] - Raspberry Pi BSP Patch
Cudmore, Alan P. (GSFC-5820)
alan.p.cudmore at nasa.gov
Mon Mar 4 14:51:01 UTC 2013
I generated that diff file, but I did not actually try to merge it into an unmodified rems-4.11 tree.
I hope to re-submit the BSP this week with the changes that were suggested. Once it's in the repository, it will be easy to use.
Alan
On Mar 4, 2013, at 9:25 AM, Sagara Paranagama <sagara89dev at gmail.com<mailto:sagara89dev at gmail.com>> wrote:
Hi all,
I found the RPi BSP patch on the mailing list[1]. I copied and pasted the text to a .diff file and typed this to check the patch
git apply --stat /home/sagara/workspaces/patches/rtems/rpibsp.diff
However, I got an error
fatal: corrupt patch at line 1897
1897 is the last line. Is there any place I can get the patch directly? I searched in Bugzilla for "raspberry" but no hits.
[1] - http://www.rtems.org/pipermail/rtems-devel/2013-February/002462.html
Thanks
Sagara Paranagama
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130304/c8d05ca2/attachment-0001.html>
