Dynamic Object File Loading
Chris Johns
chrisj at rtems.org
Wed Mar 6 07:04:22 UTC 2013
Hesham Moustafa wrote:
> It would be great if there are references to your ARM RTL code.
http://git.rtems.org/chrisj/rtl.git/tree/rtl-mdreloc-arm.c
This is some back ground ....
http://www.rtems.org/ftp/pub/rtems/people/chrisj/rtl/rtems-linker/index.html
> Also it
> would be great if you can tell me what ARM simulator do you use with
> RTEMS (and which BSP). I had a lot of troubles finding ARM simulators to
> work last year. Any further info/references will be great.
I do not have an ARM simulator so I hope others will answer.
