[gdb-7.5.91] mips sim fails to build on mingw32
Ralf Corsepius ralf.corsepius at rtems.org
Fri Mar 15 12:48:36 UTC 2013
Hi,
The mips sim fails to build on mingw:
x86_64-w64-mingw32-gcc -DHAVE_CONFIG_H     -DPROFILE=1 -DWITH_PROFILE=-1
   -DWITH_ALIGNMENT=NONSTRICT_ALIGNMENT -DWITH_TARGET_WORD_BITSIZE=32
-DWITH_TARGET_WORD_MSB=31 -DWITH_DEFAULT_TARGET_BYTE_ORDER=BIG_ENDIAN
-DWITH_FLOATING_POINT=HARD_FLOATING_POINT
-DWITH_TARGET_FLOATING_POINT_BITSIZE=32 -DWITH_HW=0
-DWITH_HOST_BYTE_ORDER=0 -DDEFAULT_INLINE=0   -DWITH_RESERVED_BITS=1
-DWITH_SMP=0  -Wall -Wdeclaration-after-statement -Wpointer-arith
-Wformat-nonliteral -Wno-pointer-sign -Wno-unused -Wunused-value
-Wunused-function -Wno-switch -Wno-char-subscripts -Wmissing-prototypes
-Wno-format    -DMIPS_MACH_DEFAULT=bfd_mach_mips8000   -I.
-I../../../gdb-7.5.91/sim/mips -I../common
-I../../../gdb-7.5.91/sim/mips/../common -I../../include
-I../../../gdb-7.5.91/sim/mips/../..//include -I../../bfd
-I../../../gdb-7.5.91/sim/mips/../..//bfd -I../../opcodes
-I../../../gdb-7.5.91/sim/mips/../..//opcodes  -O2 -g -pipe -Wall
-Wp,-D_FORTIFY_SOURCE=2 -fexceptions --param=ssp-buffer-size=4
-mms-bitfields -D__USE_MINGW_ACCESS -c -o interp.o -MT interp.o -MMD -MP
-MF .deps/interp.Tpo ../../../gdb-7.5.91/sim/mips/interp.c
../../../gdb-7.5.91/sim/mips/../common/dv-sockser.c:44:24: fatal error:
netinet/in.h: No such file or directory
ATM, I assume this patch to be the cause (sim/mips):
2012-09-03 Joel Sherrill <joel.sherrill at oarcorp.com>
         * configure.ac: Always link against dv-sockser.o.
         * configure: Regenerate.
 From what I can gather from comparing sim/mips/configure.ac to other
sim/*/configure.ac (e.g. bfin/configure.ac),
dv-sockser.o needs to be suppressed for mingw32-* targets?
Ralf
