[PATCH 1/2] posix: Reimplement POSIX Key manager to use a red-black tree.
Ashi ashi08104 at gmail.com
Mon Mar 18 14:08:16 UTC 2013
Hi, Gedare, I think Joel has mentioned this about unlimited problem. I
remember Joel has suggested a way to deal with this when use the
pre-allocation approach. But I haven't got that idea... However, I only
find my problem description mail, haven't found Joel's solution... Joel, do
you remember there is such a mail?
>Joel wrote:
>>9/12/2012 5:08 AM, Ashi wrote:
>>Hi, Joel.
>>My work stops at the problem of how to support unlimited mode when we pre-allocate
all memory at key manager >>initialization, and I still haven't got time to
learn the object extend code sample as Chris mentioned in last mail. And I
>>also haven't figured out how to write right Configuration in confdef.h,
my last post in dev-list is about this.
>>I really have a busy time these days, and really sorry for my slow
progress. Anyway I'll try my best!
>I think it should be merged as it is. When in unlimited mode, we can
document the
>recommendation that you use a unified work space.  We can leave this as a
>future enhancement.
>But what you did is a BIG improvement. This next step is an integration
clean up
>that can occur separately.
>let's move to review and merge what you have, update the project page,
check coverage
>on what's there, etc.
On Fri, Mar 15, 2013 at 6:53 AM, Gedare Bloom <gedare at rtems.org> wrote:
> On Tue, Mar 12, 2013 at 8:34 PM, Gedare Bloom <gedare at rtems.org> wrote:
> > From: Zhongwei Yao <ashi08104 at gmail.com>
> > diff --git a/cpukit/posix/include/rtems/posix/key.h
> b/cpukit/posix/include/rtems/posix/key.h
> > index 0bb1dbe..16aea78 100644
> > --- a/cpukit/posix/include/rtems/posix/key.h
> > +++ b/cpukit/posix/include/rtems/posix/key.h
> > @@ -34,27 +37,53 @@ extern "C" {
> >  #endif
> > - * This is the data Structure used to manage a POSIX key.
> > - * NOTE: The Values is a table indexed by the index portion of the
> > - *       ID of the currently executing thread.
> > + * @brief The rbtree node used to manage a POSIX key and value.
> > +typedef struct {
> > +  /** This field is the chain node structure. */
> > +  Chain_Node ch_node;
> > +   * This field is the chain node, which is
> > +   * used in pre-allocated key node chain.
> > +  Chain_Node pre_ch_node;
> Is a POSIX_Keys_Rbtree_node ever on two chains (one with ch_node and
> one with pre_ch_node) at the same time?
> If not, then they can share the same Chain_Control. This would also
> eliminate the need below to use offsetof.
> > diff --git a/cpukit/posix/src/keysetspecific.c
> b/cpukit/posix/src/keysetspecific.c
> > index b25e44c..de96964 100644
> > --- a/cpukit/posix/src/keysetspecific.c
> > +++ b/cpukit/posix/src/keysetspecific.c
> > @@ -37,18 +41,41 @@ int pthread_setspecific(
> >    const void    *value
> > -  register POSIX_Keys_Control *the_key;
> > -  uint32_t                     api;
> > -  uint32_t                     index;
> >    Objects_Locations            location;
> > +  POSIX_Keys_Rbtree_node      *rb_node;
> > +  Chain_Node                  *ch_node;
> > +  POSIX_API_Control           *api;
> > -  the_key = _POSIX_Keys_Get( key, &location );
> > +  _POSIX_Keys_Get( key, &location );
> >    switch ( location ) {
> >      case OBJECTS_LOCAL:
> > -      api   = _Objects_Get_API( _Thread_Executing->Object.id );
> > -      index = _Objects_Get_index( _Thread_Executing->Object.id );
> > -      the_key->Values[ api ][ index ] = (void *) value;
> > +      ch_node = _Chain_Get_unprotected(
> &_POSIX_Keys_Preallocation_chain );
> What if the Preallocation chain is empty?
> > +      /* there is no _Chain_Container_of in RTEMS Chain API */
> > +      rb_node = ( POSIX_Keys_Rbtree_node * ) \
> > +        ( ( uintptr_t )( ch_node ) \
> > +          - offsetof( POSIX_Keys_Rbtree_node, pre_ch_node ) );
> Might not need this if you share the chain node for the two chains. If
> you do need to, maybe we should implement _Chain_Container_of().
> > diff --git a/cpukit/sapi/include/confdefs.h
> b/cpukit/sapi/include/confdefs.h
> > index cc55e92..2aaf30e 100644
> > --- a/cpukit/sapi/include/confdefs.h
> > +++ b/cpukit/sapi/include/confdefs.h
> > @@ -1709,11 +1709,18 @@ rtems_fs_init_functions_t
>  rtems_fs_init_helper =
> >    #ifndef CONFIGURE_MAXIMUM_POSIX_KEYS
> >      #define CONFIGURE_MAXIMUM_POSIX_KEYS           0
> > -    #define CONFIGURE_MEMORY_FOR_POSIX_KEYS(_keys) 0
> > +    #define CONFIGURE_MAXIMUM_POSIX_KEY_PAIRS      0
> > +    #define CONFIGURE_MEMORY_FOR_POSIX_KEYS(_keys, _key_pairs) 0
> >    #else
> > -    #define CONFIGURE_MEMORY_FOR_POSIX_KEYS(_keys) \
> > +    #ifndef CONFIGURE_MAXIMUM_POSIX_KEY_PAIRS
> > +      #define CONFIGURE_MAXIMUM_POSIX_KEY_PAIRS \
> > +        CONFIGURE_MAXIMUM_POSIX_KEYS \
> > +        * (CONFIGURE_MAXIMUM_POSIX_THREADS + CONFIGURE_MAXIMUM_TASKS)
> > +    #endif
> > +  #define CONFIGURE_MEMORY_FOR_POSIX_KEYS(_keys, _key_pairs)       \
> >        (_Configure_Object_RAM(_keys, sizeof(POSIX_Keys_Control) ) \
> > -        + (_keys) * 3 * _Configure_From_workspace(sizeof(void *) * 2))
> > +      + _key_pairs                        \
> > +      * _Configure_From_workspace(sizeof(POSIX_Keys_Rbtree_node)))
> >    #endif
> Both CONFIGURE_MAXIMUM_POSIX_KEY_PAIRS and
> CONFIGURE_MAXIMUM_POSIX_KEYS should ignore the unlimited bit. Well,
> the first should probably inherit it from either unlimited keys or
> unlimited threads. The second should mask it off from _key_pairs by
> _Configure_Max_Objects(_key_pairs).
> We need to discuss the case of unlimited posix key pairs a little
> further, because the pre-allocation strategy does not handle it
> properly I think. The problem here is that a "key_pair" is not an
> Object, and so it is not managed by the Object Manager, so it does not
> make use of the pre-allocation support that Objects get. One approach
> could be to wrap the pre-allocation of "key_pair" with the allocation
> of keys themselves. This could easily handle limited and unlimited
> keys with limited threads: allocate the number of keys * number of
> threads every time Object allocation for keys occurs. The tricky case
> is when threads is unlimited, in which case the Object allocation also
> needs to allocate additional key_pairs when it allocates additional
> threads.
> -Gedare
Cheers,
Zhongwei
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130318/7b72234f/attachment-0001.html>
