[rtems commit] sparc/cpu.h: Add comments
Tue Mar 19 16:35:11 UTC 2013
On 03/19/2013 05:31 PM, Gedare Bloom wrote:
> On Tue, Mar 19, 2013 at 4:39 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de>  wrote:
>> >On 03/18/2013 07:14 PM, Joel Sherrill wrote:
>>> >>On 3/18/2013 1:05 PM, Gedare Bloom wrote:
>>>> >>>Why is your comment a question?
>>> >>Most of the CPU port comment blocks are questions about the parameter
>>> >>and a description of that parameter. This is followed by a port specific
>>> >>answer.
>>> >>I didn't know the best way to phrase the answer.  [And I wanted to get
>>> >>this patch off my microblaze branch.]
>>> >>I think Sebastian added this definition to every port with no comment
>>> >>block.
>> >The no_cpu file has a comment:
>> >  * Size of a pointer.
>> >  * This must be an integer literal that can be used by the assembler.  This
>> >  * value will be used to calculate offsets of structure members.  These
>> >  * offsets will be used in assembler code.
>> >#define CPU_SIZEOF_POINTER         4
>>> >>If you like, I can propagate the question to all ports with an
>>> >>answer like:
>>> >>The size of a pointer (e.g. void *) is always XXX bytes.
>>> >>OR
>>> >>The size of a pointer (e.g. void *) is varies based upon the multilib
>>> >>variant. For X and Y, it is NNN bytes. For all others, it is MMM bytes.
>>> >>Are those viable options?
>> >I don't think we should comment the obvious.  A useful comment would be a
>> >reference to the corresponding ABI document and section.
> Obviousness is subjective. Just looking at a definition like this
> would not tell me anything if there is a multilib.
If this is defined unconditionally, then there is no multilib involved.  If you
see something like this
#ifdef __m32cm_cpu__
#else
   #define CPU_SIZEOF_POINTER 2
#endif
a multilib is involved.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
