Autoconf 2.69 and mingw
Sat Mar 23 08:26:21 UTC 2013
On 22/03/13 22:50, Chris Johns wrote:
> I am looking for a suitable solution to my delete problem. There are
> also other problems, namely the -j option with make when Python
> threads are running cause problems in MSYS so parallel building is
> currently disabled.
> The solutions I have in mind, is to use Python or something other than
> 'rm' to delete the source tree or look at using a minimal Cygwin shell
> set up and to support cross-compiling the RTEMS tools. I am not
> interested in Cygwin specific RTEMS tool sets only native Windows tool
> sets. Cygwin is a long path to take because I need to create and test
> it, how-ever it fixes the parallel build issue and will make building
> faster.
The fastest way to build the MinGW tools is a Linux -> MinGW cross
compiler (Canadian Cross).
http://sourceforge.net/apps/trac/mingw-w64/wiki/Cross%20Win32%20and%20Win64%20compiler
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
