[rtems commit] Using the generic atomic ops to implement UP mode atomic for all architectures . SMP atomic port will be later.
Wed May 1 15:30:55 UTC 2013
On Wed, May 1, 2013 at 11:19 AM, Ralf Corsepius
<ralf.corsepius at rtems.org> wrote:
> On 05/01/2013 05:00 PM, Joel Sherrill wrote:
>> On 5/1/2013 9:44 AM, Ralf Corsepius wrote:
>>> On 05/01/2013 04:23 PM, Gedare Bloom wrote:
>>>> Module:    rtems
>>>> Branch:    master
>>>> Commit:    9b605b28b497f398682a8ffd673f6860340957f8
>>>> Changeset:
>>>> http://git.rtems.org/rtems/commit/?id=9b605b28b497f398682a8ffd673f6860340957f8
>>>> Author:    WeiY <wei.a.yang at gmail.com>
>>>> Date:      Wed Apr 24 00:34:16 2013 +0800
>>>> architectures. SMP atomic port will be later.
>>>> +++ b/cpukit/score/cpu/arm/rtems/score/cpuatomic.h
>>>> @@ -0,0 +1,40 @@
>>>> + * @file  rtems/score/cpuatomic.h
>>>> + * This include file implements the atomic operations for arm and
>>>> defines
>>>> + * atomic data types which are used by the atomic operations API file.
>>>> This
>>>> + * file should use fixed name cpuatomic.h and should be included in
>>>> atomic
>>>> + * operations API file atomic.h. If the architecture works at the UP
>>>> mode it
>>>> + * will use a generic atomic ops using disable/enable-IRQ simulated. If
>>>> the
>>>> + * the architecture works at SMP mode, most of the parts of
>>>> implementations
>>>> + * are imported from FreeBSD kernel.
>>>> +#ifndef _RTEMS_SCORE_ATOMIC_CPU_H
>>>> +#define _RTEMS_SCORE_ATOMIC_CPU_H
>>>> +#include <rtems/score/genericcpuatomic.h>
>>>> +#ifdef __cplusplus
>>>> +extern "C" {
>>>> +#endif
>>>> + * @defgroup RTEMS atomic implementation
>>>> +#if !defined(RTEMS_SMP)
>>>> +#include <rtems/score/genericatomicops.h>
>>>> +#else
>>>> +#endif
>>>> +#ifdef __cplusplus
>>>> +#endif
>>>> +#endif
>>>> +/*  end of include file */
>>> Would somebody please explain the code above?
>>> The #ifdef __cplusplus as well as the #if !defined(RTEMS_SMP)
>>> should be completely superflous. If not, they'd indicate bugs elsewhere.
>> AFAIK The !defined(RTEMS_SMP) just says use the generic uniprocessor
>> implementation when not SMP. What's the specific issue?
> The code includes
> twice. Once unconditionally and once conditionally.
> This is redundant.
No, it includes genericcpuatomic.h unconditionally, and
genericatomicops.h conditionally.
>> And I also don't see what the issue is with the C++ check.
> The c++ guard is entirely superfluous in this case, because the file does
> not define any symbol.
OK. I will have the contributor clean up these guards. I agree with
Thomas' interpretation (and repeated below by Ralf) about the layering
of guards, although since we do not permit C++ anywhere inside of
score then from a technical perspective it should not matter. But we
should keep our source clean. :)
>> A quick
>> grep of score shows 122 files or 333 .h files have the C++ guard.
>> Do you have a rationale for when one should be present or not?
> The guards are required when files defines/declares C symbols. Files which
> don't, don't have to.
> Finally, files should set c++ guards in ways they are self-contained. The
> construct above guards an included file, which means this guard is either
> redundant (in case the other file is self-guarded) or the included file
> isn't self-guarded (which would mean the include file is poorly implemented
> == broken).
> Ralf
> rtems-devel mailing list
> rtems-devel at rtems.org
