Fixed compiler warning in irq-generic.h
Andreas Heinig
andreas.heinig at cs.tu-dortmund.de
Thu May 2 10:54:01 UTC 2013
Hello,
The following two patches remove one compiler warning in irq-genric.h.
Patch 1/2:
- removes the initial warning where the compiler complains about
different signs while comparing the vector number
Patch 2/2:
- removes the new compiler warning generated after applying patch 1/2 if
BSP_INTERRUPT_VECTOR_MIN is set to 0. In this case we compare an
unsigned integer for being lower than 0, which is obviously always true.
Regards,
Andreas
