libtests/malloc04
Sebastian Huber
Fri May 3 14:32:04 UTC 2013
Hello,
the libtests/malloc04 test has this function:
void * sbrk(ptrdiff_t incr)
void *p = (void *) -1;
printf( "sbrk(%td)\n", incr );
if ( sbrk_count == -1 ) {
p = (void *) (NULL - 2);
} else if ( offset + incr < sizeof(Malloc_Heap) ) {
p = &Malloc_Heap[ offset ];
offset += incr;
} else {
if ( sbrk_count == 0 )
p = (void *) rtems_task_create;
sbrk_count++;
sbrk_count++;
return p;
What is the purpose of the "p = (void *) rtems_task_create;"? This test fails
on a BSP with a write protected code space, because malloc() tries to extend
its space with the area covered by the rtems_test_create() function.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
