[PATCH] psxtests/psxtime: Reduce test time
Sebastian Huber
Fri May 3 14:46:48 UTC 2013
testsuites/psxtests/psxtime/psxtime.scn | 338 +++++++++++--------------------
testsuites/psxtests/psxtime/test.c | 4 +-
2 files changed, 123 insertions(+), 219 deletions(-)
diff --git a/testsuites/psxtests/psxtime/psxtime.scn b/testsuites/psxtests/psxtime/psxtime.scn
index d41082d..174f9d7 100644
--- a/testsuites/psxtests/psxtime/psxtime.scn
+++ b/testsuites/psxtests/psxtime/psxtime.scn
@@ -11,7 +11,7 @@ adjtime - delta of one second forward, olddelta=NULL
adjtime - delta of almost two seconds forward
adjtime - delta of almost one second forward which bumps second
-rtems_clock_get_tod 12:45:05 01/01/1988
+rtems_clock_get_tod 12:44:48 01/01/1988
rtems_clock_set 12:45:00 01/01/1988
rtems_clock_get_tod 12:45:00 01/01/1988
gettimeofday: Fri Jan 1 12:45:00 1988
@@ -19,35 +19,23 @@ time: Fri Jan 1 12:45:00 1988
localtime: Fri Jan 1 12:45:00 1988
gmtime: Fri Jan 1 12:45:00 1988
-gettimeofday: Fri Jan 1 12:45:05 1988
-time: Fri Jan 1 12:45:05 1988
-localtime: Fri Jan 1 12:45:05 1988
-gmtime: Fri Jan 1 12:45:05 1988
+rtems_clock_get_tod 12:45:01 01/01/1988
+gettimeofday: Fri Jan 1 12:45:01 1988
+time: Fri Jan 1 12:45:01 1988
+localtime: Fri Jan 1 12:45:01 1988
+gmtime: Fri Jan 1 12:45:01 1988
-rtems_clock_get_tod 12:45:10 01/01/1988
-gettimeofday: Fri Jan 1 12:45:10 1988
-time: Fri Jan 1 12:45:10 1988
-localtime: Fri Jan 1 12:45:10 1988
-gmtime: Fri Jan 1 12:45:10 1988
+rtems_clock_get_tod 12:45:02 01/01/1988
+gettimeofday: Fri Jan 1 12:45:02 1988
+time: Fri Jan 1 12:45:02 1988
+localtime: Fri Jan 1 12:45:02 1988
+gmtime: Fri Jan 1 12:45:02 1988
-rtems_clock_get_tod 12:45:15 01/01/1988
-gettimeofday: Fri Jan 1 12:45:15 1988
-time: Fri Jan 1 12:45:15 1988
-localtime: Fri Jan 1 12:45:15 1988
-gmtime: Fri Jan 1 12:45:15 1988
-rtems_clock_get_tod 12:45:20 01/01/1988
-gettimeofday: Fri Jan 1 12:45:20 1988
-time: Fri Jan 1 12:45:20 1988
-localtime: Fri Jan 1 12:45:20 1988
-gmtime: Fri Jan 1 12:45:20 1988
-rtems_clock_get_tod 12:45:25 01/01/1988
-gettimeofday: Fri Jan 1 12:45:25 1988
-time: Fri Jan 1 12:45:25 1988
-localtime: Fri Jan 1 12:45:25 1988
-gmtime: Fri Jan 1 12:45:25 1988
+rtems_clock_get_tod 12:45:03 01/01/1988
+gettimeofday: Fri Jan 1 12:45:03 1988
+time: Fri Jan 1 12:45:03 1988
+localtime: Fri Jan 1 12:45:03 1988
+gmtime: Fri Jan 1 12:45:03 1988
rtems_clock_set 09:00:00 12/31/1988
rtems_clock_get_tod 09:00:00 12/31/1988
@@ -56,35 +44,23 @@ time: Sat Dec 31 09:00:00 1988
localtime: Sat Dec 31 09:00:00 1988
gmtime: Sat Dec 31 09:00:00 1988
-rtems_clock_get_tod 09:00:05 12/31/1988
-gettimeofday: Sat Dec 31 09:00:05 1988
-time: Sat Dec 31 09:00:05 1988
-localtime: Sat Dec 31 09:00:05 1988
-gmtime: Sat Dec 31 09:00:05 1988
-rtems_clock_get_tod 09:00:10 12/31/1988
-gettimeofday: Sat Dec 31 09:00:10 1988
-time: Sat Dec 31 09:00:10 1988
-localtime: Sat Dec 31 09:00:10 1988
-gmtime: Sat Dec 31 09:00:10 1988
-rtems_clock_get_tod 09:00:15 12/31/1988
-gettimeofday: Sat Dec 31 09:00:15 1988
-time: Sat Dec 31 09:00:15 1988
-localtime: Sat Dec 31 09:00:15 1988
-gmtime: Sat Dec 31 09:00:15 1988
+rtems_clock_get_tod 09:00:01 12/31/1988
+gettimeofday: Sat Dec 31 09:00:01 1988
+time: Sat Dec 31 09:00:01 1988
+localtime: Sat Dec 31 09:00:01 1988
+gmtime: Sat Dec 31 09:00:01 1988
-rtems_clock_get_tod 09:00:20 12/31/1988
-gettimeofday: Sat Dec 31 09:00:20 1988
-time: Sat Dec 31 09:00:20 1988
-localtime: Sat Dec 31 09:00:20 1988
-gmtime: Sat Dec 31 09:00:20 1988
+rtems_clock_get_tod 09:00:02 12/31/1988
+gettimeofday: Sat Dec 31 09:00:02 1988
+time: Sat Dec 31 09:00:02 1988
+localtime: Sat Dec 31 09:00:02 1988
+gmtime: Sat Dec 31 09:00:02 1988
-rtems_clock_get_tod 09:00:25 12/31/1988
-gettimeofday: Sat Dec 31 09:00:25 1988
-time: Sat Dec 31 09:00:25 1988
-localtime: Sat Dec 31 09:00:25 1988
-gmtime: Sat Dec 31 09:00:25 1988
+rtems_clock_get_tod 09:00:03 12/31/1988
+gettimeofday: Sat Dec 31 09:00:03 1988
+time: Sat Dec 31 09:00:03 1988
+localtime: Sat Dec 31 09:00:03 1988
+gmtime: Sat Dec 31 09:00:03 1988
rtems_clock_set 23:55:59 12/31/1999
rtems_clock_get_tod 23:55:59 12/31/1999
@@ -93,35 +69,23 @@ time: Fri Dec 31 23:55:59 1999
localtime: Fri Dec 31 23:55:59 1999
gmtime: Fri Dec 31 23:55:59 1999
-rtems_clock_get_tod 23:56:04 12/31/1999
-gettimeofday: Fri Dec 31 23:56:04 1999
-time: Fri Dec 31 23:56:04 1999
-localtime: Fri Dec 31 23:56:04 1999
-gmtime: Fri Dec 31 23:56:04 1999
+rtems_clock_get_tod 23:56:00 12/31/1999
+gettimeofday: Fri Dec 31 23:56:00 1999
+time: Fri Dec 31 23:56:00 1999
+localtime: Fri Dec 31 23:56:00 1999
+gmtime: Fri Dec 31 23:56:00 1999
-rtems_clock_get_tod 23:56:09 12/31/1999
-gettimeofday: Fri Dec 31 23:56:09 1999
-time: Fri Dec 31 23:56:09 1999
-localtime: Fri Dec 31 23:56:09 1999
-gmtime: Fri Dec 31 23:56:09 1999
+rtems_clock_get_tod 23:56:01 12/31/1999
+gettimeofday: Fri Dec 31 23:56:01 1999
+time: Fri Dec 31 23:56:01 1999
+localtime: Fri Dec 31 23:56:01 1999
+gmtime: Fri Dec 31 23:56:01 1999
-rtems_clock_get_tod 23:56:14 12/31/1999
-gettimeofday: Fri Dec 31 23:56:14 1999
-time: Fri Dec 31 23:56:14 1999
-localtime: Fri Dec 31 23:56:14 1999
-gmtime: Fri Dec 31 23:56:14 1999
-rtems_clock_get_tod 23:56:19 12/31/1999
-gettimeofday: Fri Dec 31 23:56:19 1999
-time: Fri Dec 31 23:56:19 1999
-localtime: Fri Dec 31 23:56:19 1999
-gmtime: Fri Dec 31 23:56:19 1999
-rtems_clock_get_tod 23:56:24 12/31/1999
-gettimeofday: Fri Dec 31 23:56:24 1999
-time: Fri Dec 31 23:56:24 1999
-localtime: Fri Dec 31 23:56:24 1999
-gmtime: Fri Dec 31 23:56:24 1999
+rtems_clock_get_tod 23:56:02 12/31/1999
+gettimeofday: Fri Dec 31 23:56:02 1999
+time: Fri Dec 31 23:56:02 1999
+localtime: Fri Dec 31 23:56:02 1999
+gmtime: Fri Dec 31 23:56:02 1999
rtems_clock_set 00:01:30 06/30/1999
rtems_clock_get_tod 00:01:30 06/30/1999
@@ -130,35 +94,23 @@ time: Wed Jun 30 00:01:30 1999
localtime: Wed Jun 30 00:01:30 1999
gmtime: Wed Jun 30 00:01:30 1999
-rtems_clock_get_tod 00:01:35 06/30/1999
-gettimeofday: Wed Jun 30 00:01:35 1999
-time: Wed Jun 30 00:01:35 1999
-localtime: Wed Jun 30 00:01:35 1999
-gmtime: Wed Jun 30 00:01:35 1999
-rtems_clock_get_tod 00:01:40 06/30/1999
-gettimeofday: Wed Jun 30 00:01:40 1999
-time: Wed Jun 30 00:01:40 1999
-localtime: Wed Jun 30 00:01:40 1999
-gmtime: Wed Jun 30 00:01:40 1999
-rtems_clock_get_tod 00:01:45 06/30/1999
-gettimeofday: Wed Jun 30 00:01:45 1999
-time: Wed Jun 30 00:01:45 1999
-localtime: Wed Jun 30 00:01:45 1999
-gmtime: Wed Jun 30 00:01:45 1999
+rtems_clock_get_tod 00:01:31 06/30/1999
+gettimeofday: Wed Jun 30 00:01:31 1999
+time: Wed Jun 30 00:01:31 1999
+localtime: Wed Jun 30 00:01:31 1999
+gmtime: Wed Jun 30 00:01:31 1999
-rtems_clock_get_tod 00:01:50 06/30/1999
-gettimeofday: Wed Jun 30 00:01:50 1999
-time: Wed Jun 30 00:01:50 1999
-localtime: Wed Jun 30 00:01:50 1999
-gmtime: Wed Jun 30 00:01:50 1999
+rtems_clock_get_tod 00:01:32 06/30/1999
+gettimeofday: Wed Jun 30 00:01:32 1999
+time: Wed Jun 30 00:01:32 1999
+localtime: Wed Jun 30 00:01:32 1999
+gmtime: Wed Jun 30 00:01:32 1999
-rtems_clock_get_tod 00:01:55 06/30/1999
-gettimeofday: Wed Jun 30 00:01:55 1999
-time: Wed Jun 30 00:01:55 1999
-localtime: Wed Jun 30 00:01:55 1999
-gmtime: Wed Jun 30 00:01:55 1999
+rtems_clock_get_tod 00:01:33 06/30/1999
+gettimeofday: Wed Jun 30 00:01:33 1999
+time: Wed Jun 30 00:01:33 1999
+localtime: Wed Jun 30 00:01:33 1999
+gmtime: Wed Jun 30 00:01:33 1999
rtems_clock_set 00:15:59 01/01/2000
rtems_clock_get_tod 00:15:59 01/01/2000
@@ -167,35 +119,23 @@ time: Sat Jan 1 00:15:59 2000
localtime: Sat Jan 1 00:15:59 2000
gmtime: Sat Jan 1 00:15:59 2000
-rtems_clock_get_tod 00:16:04 01/01/2000
-gettimeofday: Sat Jan 1 00:16:04 2000
-time: Sat Jan 1 00:16:04 2000
-localtime: Sat Jan 1 00:16:04 2000
-gmtime: Sat Jan 1 00:16:04 2000
+rtems_clock_get_tod 00:16:00 01/01/2000
+gettimeofday: Sat Jan 1 00:16:00 2000
+time: Sat Jan 1 00:16:00 2000
+localtime: Sat Jan 1 00:16:00 2000
+gmtime: Sat Jan 1 00:16:00 2000
-rtems_clock_get_tod 00:16:09 01/01/2000
-gettimeofday: Sat Jan 1 00:16:09 2000
-time: Sat Jan 1 00:16:09 2000
-localtime: Sat Jan 1 00:16:09 2000
-gmtime: Sat Jan 1 00:16:09 2000
+rtems_clock_get_tod 00:16:01 01/01/2000
+gettimeofday: Sat Jan 1 00:16:01 2000
+time: Sat Jan 1 00:16:01 2000
+localtime: Sat Jan 1 00:16:01 2000
+gmtime: Sat Jan 1 00:16:01 2000
-rtems_clock_get_tod 00:16:14 01/01/2000
-gettimeofday: Sat Jan 1 00:16:14 2000
-time: Sat Jan 1 00:16:14 2000
-localtime: Sat Jan 1 00:16:14 2000
-gmtime: Sat Jan 1 00:16:14 2000
-rtems_clock_get_tod 00:16:19 01/01/2000
-gettimeofday: Sat Jan 1 00:16:19 2000
-time: Sat Jan 1 00:16:19 2000
-localtime: Sat Jan 1 00:16:19 2000
-gmtime: Sat Jan 1 00:16:19 2000
-rtems_clock_get_tod 00:16:24 01/01/2000
-gettimeofday: Sat Jan 1 00:16:24 2000
-time: Sat Jan 1 00:16:24 2000
-localtime: Sat Jan 1 00:16:24 2000
-gmtime: Sat Jan 1 00:16:24 2000
+rtems_clock_get_tod 00:16:02 01/01/2000
+gettimeofday: Sat Jan 1 00:16:02 2000
+time: Sat Jan 1 00:16:02 2000
+localtime: Sat Jan 1 00:16:02 2000
+gmtime: Sat Jan 1 00:16:02 2000
rtems_clock_set 05:10:59 02/02/2005
rtems_clock_get_tod 05:10:59 02/02/2005
@@ -204,35 +144,23 @@ time: Wed Feb 2 05:10:59 2005
localtime: Wed Feb 2 05:10:59 2005
gmtime: Wed Feb 2 05:10:59 2005
-rtems_clock_get_tod 05:11:04 02/02/2005
-gettimeofday: Wed Feb 2 05:11:04 2005
-time: Wed Feb 2 05:11:04 2005
-localtime: Wed Feb 2 05:11:04 2005
-gmtime: Wed Feb 2 05:11:04 2005
-rtems_clock_get_tod 05:11:09 02/02/2005
-gettimeofday: Wed Feb 2 05:11:09 2005
-time: Wed Feb 2 05:11:09 2005
-localtime: Wed Feb 2 05:11:09 2005
-gmtime: Wed Feb 2 05:11:09 2005
-rtems_clock_get_tod 05:11:14 02/02/2005
-gettimeofday: Wed Feb 2 05:11:14 2005
-time: Wed Feb 2 05:11:14 2005
-localtime: Wed Feb 2 05:11:14 2005
-gmtime: Wed Feb 2 05:11:14 2005
+rtems_clock_get_tod 05:11:00 02/02/2005
+gettimeofday: Wed Feb 2 05:11:00 2005
+time: Wed Feb 2 05:11:00 2005
+localtime: Wed Feb 2 05:11:00 2005
+gmtime: Wed Feb 2 05:11:00 2005
-rtems_clock_get_tod 05:11:19 02/02/2005
-gettimeofday: Wed Feb 2 05:11:19 2005
-time: Wed Feb 2 05:11:19 2005
-localtime: Wed Feb 2 05:11:19 2005
-gmtime: Wed Feb 2 05:11:19 2005
+rtems_clock_get_tod 05:11:01 02/02/2005
+gettimeofday: Wed Feb 2 05:11:01 2005
+time: Wed Feb 2 05:11:01 2005
+localtime: Wed Feb 2 05:11:01 2005
+gmtime: Wed Feb 2 05:11:01 2005
-rtems_clock_get_tod 05:11:24 02/02/2005
-gettimeofday: Wed Feb 2 05:11:24 2005
-time: Wed Feb 2 05:11:24 2005
-localtime: Wed Feb 2 05:11:24 2005
-gmtime: Wed Feb 2 05:11:24 2005
+rtems_clock_get_tod 05:11:02 02/02/2005
+gettimeofday: Wed Feb 2 05:11:02 2005
+time: Wed Feb 2 05:11:02 2005
+localtime: Wed Feb 2 05:11:02 2005
+gmtime: Wed Feb 2 05:11:02 2005
rtems_clock_set 10:05:59 03/03/2010
rtems_clock_get_tod 10:05:59 03/03/2010
@@ -241,35 +169,23 @@ time: Wed Mar 3 10:05:59 2010
localtime: Wed Mar 3 10:05:59 2010
gmtime: Wed Mar 3 10:05:59 2010
-rtems_clock_get_tod 10:06:04 03/03/2010
-gettimeofday: Wed Mar 3 10:06:04 2010
-time: Wed Mar 3 10:06:04 2010
-localtime: Wed Mar 3 10:06:04 2010
-gmtime: Wed Mar 3 10:06:04 2010
+rtems_clock_get_tod 10:06:00 03/03/2010
+gettimeofday: Wed Mar 3 10:06:00 2010
+time: Wed Mar 3 10:06:00 2010
+localtime: Wed Mar 3 10:06:00 2010
+gmtime: Wed Mar 3 10:06:00 2010
-rtems_clock_get_tod 10:06:09 03/03/2010
-gettimeofday: Wed Mar 3 10:06:09 2010
-time: Wed Mar 3 10:06:09 2010
-localtime: Wed Mar 3 10:06:09 2010
-gmtime: Wed Mar 3 10:06:09 2010
+rtems_clock_get_tod 10:06:01 03/03/2010
+gettimeofday: Wed Mar 3 10:06:01 2010
+time: Wed Mar 3 10:06:01 2010
+localtime: Wed Mar 3 10:06:01 2010
+gmtime: Wed Mar 3 10:06:01 2010
-rtems_clock_get_tod 10:06:14 03/03/2010
-gettimeofday: Wed Mar 3 10:06:14 2010
-time: Wed Mar 3 10:06:14 2010
-localtime: Wed Mar 3 10:06:14 2010
-gmtime: Wed Mar 3 10:06:14 2010
-rtems_clock_get_tod 10:06:19 03/03/2010
-gettimeofday: Wed Mar 3 10:06:19 2010
-time: Wed Mar 3 10:06:19 2010
-localtime: Wed Mar 3 10:06:19 2010
-gmtime: Wed Mar 3 10:06:19 2010
-rtems_clock_get_tod 10:06:24 03/03/2010
-gettimeofday: Wed Mar 3 10:06:24 2010
-time: Wed Mar 3 10:06:24 2010
-localtime: Wed Mar 3 10:06:24 2010
-gmtime: Wed Mar 3 10:06:24 2010
+rtems_clock_get_tod 10:06:02 03/03/2010
+gettimeofday: Wed Mar 3 10:06:02 2010
+time: Wed Mar 3 10:06:02 2010
+localtime: Wed Mar 3 10:06:02 2010
+gmtime: Wed Mar 3 10:06:02 2010
rtems_clock_set 15:00:59 04/04/2020
rtems_clock_get_tod 15:00:59 04/04/2020
@@ -278,35 +194,23 @@ time: Sat Apr 4 15:00:59 2020
localtime: Sat Apr 4 15:00:59 2020
gmtime: Sat Apr 4 15:00:59 2020
-rtems_clock_get_tod 15:01:04 04/04/2020
-gettimeofday: Sat Apr 4 15:01:04 2020
-time: Sat Apr 4 15:01:04 2020
-localtime: Sat Apr 4 15:01:04 2020
-gmtime: Sat Apr 4 15:01:04 2020
-rtems_clock_get_tod 15:01:09 04/04/2020
-gettimeofday: Sat Apr 4 15:01:09 2020
-time: Sat Apr 4 15:01:09 2020
-localtime: Sat Apr 4 15:01:09 2020
-gmtime: Sat Apr 4 15:01:09 2020
-rtems_clock_get_tod 15:01:14 04/04/2020
-gettimeofday: Sat Apr 4 15:01:14 2020
-time: Sat Apr 4 15:01:14 2020
-localtime: Sat Apr 4 15:01:14 2020
-gmtime: Sat Apr 4 15:01:14 2020
+rtems_clock_get_tod 15:01:00 04/04/2020
+gettimeofday: Sat Apr 4 15:01:00 2020
+time: Sat Apr 4 15:01:00 2020
+localtime: Sat Apr 4 15:01:00 2020
+gmtime: Sat Apr 4 15:01:00 2020
-rtems_clock_get_tod 15:01:19 04/04/2020
-gettimeofday: Sat Apr 4 15:01:19 2020
-time: Sat Apr 4 15:01:19 2020
-localtime: Sat Apr 4 15:01:19 2020
-gmtime: Sat Apr 4 15:01:19 2020
+rtems_clock_get_tod 15:01:01 04/04/2020
+gettimeofday: Sat Apr 4 15:01:01 2020
+time: Sat Apr 4 15:01:01 2020
+localtime: Sat Apr 4 15:01:01 2020
+gmtime: Sat Apr 4 15:01:01 2020
-rtems_clock_get_tod 15:01:24 04/04/2020
-gettimeofday: Sat Apr 4 15:01:24 2020
-time: Sat Apr 4 15:01:24 2020
-localtime: Sat Apr 4 15:01:24 2020
-gmtime: Sat Apr 4 15:01:24 2020
+rtems_clock_get_tod 15:01:02 04/04/2020
+gettimeofday: Sat Apr 4 15:01:02 2020
+time: Sat Apr 4 15:01:02 2020
+localtime: Sat Apr 4 15:01:02 2020
+gmtime: Sat Apr 4 15:01:02 2020
diff --git a/testsuites/psxtests/psxtime/test.c b/testsuites/psxtests/psxtime/test.c
index a895273..c8741d8 100644
--- a/testsuites/psxtests/psxtime/test.c
+++ b/testsuites/psxtests/psxtime/test.c
@@ -92,11 +92,11 @@ void check_a_tod(
a_tm = gmtime( &a_time_t );
printf( "gmtime: %s\n", asctime( a_tm ) );
- status = rtems_task_wake_after( 5 * rtems_clock_get_ticks_per_second() );
+ status = rtems_task_wake_after( rtems_clock_get_ticks_per_second() );
i++;
- } while( i < 6 );
+ } while( i <= 3 );
void test_adjtime(void)
1.7.7
