[PATCH] ZYNQ BSP
Fri May 3 18:22:12 UTC 2013
On 5/3/2013 12:55 PM, Michal Simek wrote:
> Hi Sebastian,
> Do you use mainline qemu (target realview-pbx-a9)?
> What's your qemu command line for running it?
And do you have sim-script support? :)
> Thanks,
> Michal
> On 05/03/2013 05:44 PM, Sebastian Huber wrote:
>> Hello Claus,
>> I added a new BSP with Cortex-A9 MPCore support:
>> http://git.rtems.org/rtems/commit/?id=a91dc98b5ad5ee9bc8d592c62753a467daf4e711
>> It should be possible to use the MMU, cache, GIC and PT (Cortex-A9 MPCore Private Timer) support also for the Zync BSP.
>> With that we only have to add a console driver to get a basic BSP.
>> There is Qemu support for the Zync.  It is desirable that this BSP runs on the simulator to test it.
