RTEMS Scheduler Simulator Status Update
Joel Sherrill
joel.sherrill at OARcorp.com
Sun May 5 15:55:05 UTC 2013
On 5/5/2013 8:30 AM, wei.a.yang wrote:
> 在 2013-5-4,22:01,Joel Sherrill <joel.sherrill at oarcorp.com
> <mailto:joel.sherrill at oarcorp.com>> 写道:
>> On 5/3/2013 9:18 PM, yangwei weiyang wrote:
>>> Hi
>>> When i build the scheduler-sim it encountered some error:
>>> weiy at WeiY-host:/project/weiy/gsoc2013/rtems-schedsim$ autoconf
>>> configure.ac:18 <http://configure.ac:18>: error: possibly undefined
>>> macro: AM_INIT_AUTOMAKE
>>> If this token and others are legitimate, please use
>>> m4_pattern_allow.
>>> See the Autoconf documentation.
>>> configure.ac:19 <http://configure.ac:19>: error: possibly undefined
>>> macro: AM_MAINTAINER_MODE
>> You need to run the bootstrap script found at the top of the main
>> RTEMS source tree.
>> rtems-schedsim avoids duplicating files from the main source tree.
>> Can you build the RTEMS head? rtems-schedsim uses the same version
>> of autoconf and automake.
> Thank you Joel, I have built the sim successfully and run all the
> scenarios. So next step I will look deep into its source code and
> learn how to write test scenarios.
Great! I didn't think it was hard to build. :)
I have attached two Open Office Documents which I wrote when the simulator
was created. There is a README in rtems-schedsim/schedsim which
unfortunately
looked to be corrupted by the cvs->git transition. It should be a subset
of what
is in these documents.
I think I will convert at least the Using document to asciidoc and
replace the
README. :)
>>> Is there any reference about how to configure and build the schedsim.
>> There is a readme at the top of the source tree.
>>> 2013/5/2 Joel Sherrill <joel.sherrill at oarcorp.com
>>> Hi
>>> I just wanted to pass along that the RTEMS Scheduler
>>> Simulator is now updated and appears to be working
>>> great with the current RTEMS source. The git is:
>>> git://git.rtems.org/rtems-schedsim.git
>>> <http://git.rtems.org/rtems-schedsim.git>
>>> I also updated the wiki page:
>>> http://wiki.rtems.org/wiki/index.php/SuperCore_Scheduler#Scheduler_Simulator
>>> This should be of use to at least two GSOC proposals.
>>> Joel Sherrill, Ph.D. Director of Research & Development
>>> joel.sherrill at OARcorp.com On-Line Applications Research
>>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>>> Support Available (256) 722-9985
>>> rtems-devel mailing list
>>> rtems-devel at rtems.org <mailto:rtems-devel at rtems.org>
>>> http://www.rtems.org/mailman/listinfo/rtems-devel
>>> Wei Yang
>>> Best Regards
>>> wei.a.yang at gmail.com <http://gmail.com>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130505/62078154/attachment.html>
Type: application/vnd.oasis.opendocument.text
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130505/62078154/attachment.bin>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130505/62078154/attachment-0001.bin>
