[PATCH 2/4] score: Add CPU context validation
Wed May 8 13:54:09 UTC 2013
On 5/8/2013 8:32 AM, Gedare Bloom wrote:
> This change needs some explanation and documentation in the CPU
> Porting Guide. What are the two new CPU functions supposed to do?
And why would an infinite loop be a valid implementation?
> On Wed, May 8, 2013 at 5:48 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>>   cpukit/score/cpu/arm/Makefile.am                   |    2 +
>>   cpukit/score/cpu/arm/arm-context-validate.S        |  139 +++++++++++
>>   .../score/cpu/arm/arm-context-volatile-clobber.S   |   37 +++
>>   cpukit/score/cpu/arm/rtems/score/cpu.h             |    4 +
>>   cpukit/score/cpu/avr/rtems/score/cpu.h             |   12 +
>>   cpukit/score/cpu/bfin/rtems/score/cpu.h            |   12 +
>>   cpukit/score/cpu/h8300/rtems/score/cpu.h           |   12 +
>>   cpukit/score/cpu/i386/rtems/score/cpu.h            |   12 +
>>   cpukit/score/cpu/lm32/rtems/score/cpu.h            |   12 +
>>   cpukit/score/cpu/m32c/rtems/score/cpu.h            |   12 +
>>   cpukit/score/cpu/m32r/rtems/score/cpu.h            |   12 +
>>   cpukit/score/cpu/m68k/rtems/score/cpu.h            |   12 +
>>   cpukit/score/cpu/mips/rtems/score/cpu.h            |   12 +
>>   cpukit/score/cpu/moxie/rtems/score/cpu.h           |   12 +
>>   cpukit/score/cpu/nios2/Makefile.am                 |    2 +
>>   cpukit/score/cpu/nios2/nios2-context-validate.S    |  146 +++++++++++
>>   .../cpu/nios2/nios2-context-volatile-clobber.S     |   42 +++
>>   cpukit/score/cpu/nios2/rtems/score/cpu.h           |    4 +
>>   cpukit/score/cpu/no_cpu/rtems/score/cpu.h          |   27 ++
>>   cpukit/score/cpu/powerpc/Makefile.am               |    2 +
>>   cpukit/score/cpu/powerpc/ppc-context-validate.S    |  263 ++++++++++++++++++++
>>   .../cpu/powerpc/ppc-context-volatile-clobber.S     |   45 ++++
>>   cpukit/score/cpu/powerpc/rtems/score/cpu.h         |    4 +
>>   cpukit/score/cpu/sh/rtems/score/cpu.h              |   12 +
>>   cpukit/score/cpu/sparc/rtems/score/cpu.h           |   12 +
>>   cpukit/score/cpu/sparc64/rtems/score/cpu.h         |   12 +
>>   cpukit/score/cpu/v850/rtems/score/cpu.h            |   12 +
>>   testsuites/sptests/Makefile.am                     |    1 +
>>   testsuites/sptests/configure.ac                    |    1 +
>>   testsuites/sptests/spcontext01/Makefile.am         |   19 ++
>>   testsuites/sptests/spcontext01/init.c              |  188 ++++++++++++++
>>   testsuites/sptests/spcontext01/spcontext01.doc     |   11 +
>>   testsuites/sptests/spcontext01/spcontext01.scn     |    2 +
>>   33 files changed, 1107 insertions(+), 0 deletions(-)
>>   create mode 100644 cpukit/score/cpu/arm/arm-context-validate.S
>>   create mode 100644 cpukit/score/cpu/arm/arm-context-volatile-clobber.S
>>   create mode 100644 cpukit/score/cpu/nios2/nios2-context-validate.S
>>   create mode 100644 cpukit/score/cpu/nios2/nios2-context-volatile-clobber.S
>>   create mode 100644 cpukit/score/cpu/powerpc/ppc-context-validate.S
>>   create mode 100644 cpukit/score/cpu/powerpc/ppc-context-volatile-clobber.S
>>   create mode 100644 testsuites/sptests/spcontext01/Makefile.am
>>   create mode 100644 testsuites/sptests/spcontext01/init.c
>>   create mode 100644 testsuites/sptests/spcontext01/spcontext01.doc
>>   create mode 100644 testsuites/sptests/spcontext01/spcontext01.scn
>> diff --git a/cpukit/score/cpu/arm/Makefile.am b/cpukit/score/cpu/arm/Makefile.am
>> index 61a278b..37ab901 100644
>> --- a/cpukit/score/cpu/arm/Makefile.am
>> +++ b/cpukit/score/cpu/arm/Makefile.am
>> @@ -16,6 +16,8 @@ libscorecpu_a_CPPFLAGS = $(AM_CPPFLAGS)
>>   libscorecpu_a_SOURCES =
>>   libscorecpu_a_SOURCES += cpu.c
>>   libscorecpu_a_SOURCES += cpu_asm.S
>> +libscorecpu_a_SOURCES += arm-context-validate.S
>> +libscorecpu_a_SOURCES += arm-context-volatile-clobber.S
>>   libscorecpu_a_SOURCES += arm_exc_abort.S
>>   libscorecpu_a_SOURCES += arm_exc_interrupt.S
>>   libscorecpu_a_SOURCES += arm_exc_handler_low.S
>> diff --git a/cpukit/score/cpu/arm/arm-context-validate.S b/cpukit/score/cpu/arm/arm-context-validate.S
>> new file mode 100644
>> index 0000000..4591d20
>> --- /dev/null
>> +++ b/cpukit/score/cpu/arm/arm-context-validate.S
>> @@ -0,0 +1,139 @@
>> + * Copyright (c) 2013 embedded brains GmbH.  All rights reserved.
>> + *  embedded brains GmbH
>> + *  Dornierstr. 4
>> + *  82178 Puchheim
>> + *  Germany
>> + *  <rtems at embedded-brains.de>
>> + * The license and distribution terms for this file may be
>> + * found in the file LICENSE in this distribution or at
>> + * http://www.rtems.com/license/LICENSE.
>> +#ifdef HAVE_CONFIG_H
>> +  #include "config.h"
>> +#endif
>> +#include <rtems/asm.h>
>> +#define FRAME_OFFSET_R4 0
>> +#define FRAME_OFFSET_R5 4
>> +#define FRAME_OFFSET_R6 8
>> +#define FRAME_OFFSET_R7 12
>> +#define FRAME_OFFSET_R8 16
>> +#define FRAME_OFFSET_R9 20
>> +#define FRAME_OFFSET_R10 24
>> +#define FRAME_OFFSET_R11 28
>> +#define FRAME_OFFSET_LR 32
>> +#define FRAME_SIZE (FRAME_OFFSET_LR + 4)
>> +       .section        .text
>> +FUNCTION_THUMB_ENTRY(_CPU_Context_validate)
>> +       /* Save */
>> +       sub     sp, sp, #FRAME_SIZE
>> +       mov     r1, r4
>> +       str     r1, [sp, #FRAME_OFFSET_R4]
>> +       mov     r1, r5
>> +       str     r1, [sp, #FRAME_OFFSET_R5]
>> +       mov     r1, r6
>> +       str     r1, [sp, #FRAME_OFFSET_R6]
>> +       mov     r1, r7
>> +       str     r1, [sp, #FRAME_OFFSET_R7]
>> +       mov     r1, r8
>> +       str     r1, [sp, #FRAME_OFFSET_R8]
>> +       mov     r1, r9
>> +       str     r1, [sp, #FRAME_OFFSET_R9]
>> +       mov     r1, r10
>> +       str     r1, [sp, #FRAME_OFFSET_R10]
>> +       mov     r1, r11
>> +       str     r1, [sp, #FRAME_OFFSET_R11]
>> +       mov     r1, lr
>> +       str     r1, [sp, #FRAME_OFFSET_LR]
>> +       /* Fill */
>> +       /* R1 is used for temporary values */
>> +       mov     r1, r0
>> +       /* R2 contains the stack pointer */
>> +       mov     r2, sp
>> +.macro fill_register reg
>> +       add     r1, r1, #1
>> +       mov     \reg, r1
>> +.endm
>> +       fill_register   r3
>> +       fill_register   r4
>> +       fill_register   r5
>> +       fill_register   r6
>> +       fill_register   r7
>> +       fill_register   r8
>> +       fill_register   r9
>> +       fill_register   r10
>> +       fill_register   r11
>> +       fill_register   r12
>> +       fill_register   lr
>> +       /* Check */
>> +check:
>> +.macro check_register reg
>> +       add     r1, r1, #1
>> +       cmp     \reg, r1
>> +       bne     restore
>> +.endm
>> +       cmp     r2, sp
>> +       bne     restore
>> +       mov     r1, r0
>> +       check_register  r3
>> +       check_register  r4
>> +       check_register  r5
>> +       check_register  r6
>> +       check_register  r7
>> +       check_register  r8
>> +       check_register  r9
>> +       check_register  r10
>> +       check_register  r11
>> +       check_register  r12
>> +       check_register  lr
>> +       b       check
>> +       /* Restore */
>> +restore:
>> +       ldr     r1, [sp, #FRAME_OFFSET_R4]
>> +       mov     r4, r1
>> +       ldr     r1, [sp, #FRAME_OFFSET_R5]
>> +       mov     r5, r1
>> +       ldr     r1, [sp, #FRAME_OFFSET_R6]
>> +       mov     r6, r1
>> +       ldr     r1, [sp, #FRAME_OFFSET_R7]
>> +       mov     r7, r1
>> +       ldr     r1, [sp, #FRAME_OFFSET_R8]
>> +       mov     r8, r1
>> +       ldr     r1, [sp, #FRAME_OFFSET_R9]
>> +       mov     r9, r1
>> +       ldr     r1, [sp, #FRAME_OFFSET_R10]
>> +       mov     r10, r1
>> +       ldr     r1, [sp, #FRAME_OFFSET_R11]
>> +       mov     r11, r1
>> +       ldr     r1, [sp, #FRAME_OFFSET_LR]
>> +       mov     lr, r1
>> +       add     sp, sp, #FRAME_SIZE
>> +       bx      lr
>> +FUNCTION_END(_CPU_Context_validate)
>> diff --git a/cpukit/score/cpu/arm/arm-context-volatile-clobber.S b/cpukit/score/cpu/arm/arm-context-volatile-clobber.S
>> index 0000000..b79e570
>> --- /dev/null
>> +++ b/cpukit/score/cpu/arm/arm-context-volatile-clobber.S
>> @@ -0,0 +1,37 @@
>> + *  Dornierstr. 4
>> + *  82178 Puchheim
>> + *  Germany
>> +#endif
>> +       .section        .text
>> +FUNCTION_THUMB_ENTRY(_CPU_Context_volatile_clobber)
>> +.macro clobber_register reg
>> +       sub     r0, r0, #1
>> +       mov     \reg, r0
>> +.endm
>> +       clobber_register        r1
>> +       clobber_register        r2
>> +       clobber_register        r3
>> +       clobber_register        r12
>> +       bx      lr
>> +FUNCTION_END(_CPU_Context_volatile_clobber)
>> diff --git a/cpukit/score/cpu/arm/rtems/score/cpu.h b/cpukit/score/cpu/arm/rtems/score/cpu.h
>> index 5ed6b9b..b6f39ac 100644
>> --- a/cpukit/score/cpu/arm/rtems/score/cpu.h
>> +++ b/cpukit/score/cpu/arm/rtems/score/cpu.h
>> @@ -423,6 +423,10 @@ void _CPU_Context_save_fp( Context_Control_fp **fp_context_ptr );
>>   void _CPU_Context_restore_fp( Context_Control_fp **fp_context_ptr );
>> +void _CPU_Context_volatile_clobber( uintptr_t pattern );
>> +void _CPU_Context_validate( uintptr_t pattern );
>>   static inline uint32_t CPU_swap_u32( uint32_t value )
>>   #if defined(__thumb2__)
>> diff --git a/cpukit/score/cpu/avr/rtems/score/cpu.h b/cpukit/score/cpu/avr/rtems/score/cpu.h
>> index 5f1577a..080f387 100644
>> --- a/cpukit/score/cpu/avr/rtems/score/cpu.h
>> +++ b/cpukit/score/cpu/avr/rtems/score/cpu.h
>> @@ -1114,6 +1114,18 @@ void _CPU_Context_restore_fp(
>> +static inline void _CPU_Context_volatile_clobber( uintptr_t pattern )
>> +  /* TODO */
>> +static inline void _CPU_Context_validate( uintptr_t pattern )
>> +  while (1) {
>> +    /* TODO */
>>   /* FIXME */
>>   typedef CPU_Interrupt_frame CPU_Exception_frame;
>> diff --git a/cpukit/score/cpu/bfin/rtems/score/cpu.h b/cpukit/score/cpu/bfin/rtems/score/cpu.h
>> index 1b26527..aba01e9 100644
>> --- a/cpukit/score/cpu/bfin/rtems/score/cpu.h
>> +++ b/cpukit/score/cpu/bfin/rtems/score/cpu.h
>> @@ -1213,6 +1213,18 @@ void _CPU_Context_restore_fp(
>> +  /* TODO */
>> +  while (1) {
>> +    /* TODO */
>>   /* FIXME */
>> diff --git a/cpukit/score/cpu/h8300/rtems/score/cpu.h b/cpukit/score/cpu/h8300/rtems/score/cpu.h
>> index 6031f96..ea0ee7c 100644
>> --- a/cpukit/score/cpu/h8300/rtems/score/cpu.h
>> +++ b/cpukit/score/cpu/h8300/rtems/score/cpu.h
>> @@ -1097,6 +1097,18 @@ void _CPU_Context_restore_fp(
>> +  /* TODO */
>> +  while (1) {
>> +    /* TODO */
>>   /* FIXME */
>> diff --git a/cpukit/score/cpu/i386/rtems/score/cpu.h b/cpukit/score/cpu/i386/rtems/score/cpu.h
>> index 6667604..6a19fb1 100644
>> --- a/cpukit/score/cpu/i386/rtems/score/cpu.h
>> +++ b/cpukit/score/cpu/i386/rtems/score/cpu.h
>> @@ -667,6 +667,18 @@ void _CPU_Context_restore_fp(
>>     } while (0)
>>   #endif
>> +  /* TODO */
>> +  while (1) {
>> +    /* TODO */
>>   void _CPU_Exception_frame_print( const CPU_Exception_frame *frame );
>>   #endif /* ASM */
>> diff --git a/cpukit/score/cpu/lm32/rtems/score/cpu.h b/cpukit/score/cpu/lm32/rtems/score/cpu.h
>> index 1f8a370..eef9ac8 100644
>> --- a/cpukit/score/cpu/lm32/rtems/score/cpu.h
>> +++ b/cpukit/score/cpu/lm32/rtems/score/cpu.h
>> @@ -1202,6 +1202,18 @@ void _CPU_Context_restore_fp(
>> +  /* TODO */
>> +  while (1) {
>> +    /* TODO */
>>   /* FIXME */
>> diff --git a/cpukit/score/cpu/m32c/rtems/score/cpu.h b/cpukit/score/cpu/m32c/rtems/score/cpu.h
>> index 8d9acc3..ccb9e38 100644
>> --- a/cpukit/score/cpu/m32c/rtems/score/cpu.h
>> +++ b/cpukit/score/cpu/m32c/rtems/score/cpu.h
>> @@ -1153,6 +1153,18 @@ void _CPU_Context_restore(
>>     Context_Control *new_context
>>   ) RTEMS_COMPILER_NO_RETURN_ATTRIBUTE;
>> +  /* TODO */
>> +  while (1) {
>> +    /* TODO */
>>   /* FIXME */
>> diff --git a/cpukit/score/cpu/m32r/rtems/score/cpu.h b/cpukit/score/cpu/m32r/rtems/score/cpu.h
>> index 8c8a9c1..2c97ddb 100644
>> --- a/cpukit/score/cpu/m32r/rtems/score/cpu.h
>> +++ b/cpukit/score/cpu/m32r/rtems/score/cpu.h
>> @@ -1194,6 +1194,18 @@ void _CPU_Context_restore_fp(
>> +  /* TODO */
>> +  while (1) {
>> +    /* TODO */
>>   /* FIXME */
>> diff --git a/cpukit/score/cpu/m68k/rtems/score/cpu.h b/cpukit/score/cpu/m68k/rtems/score/cpu.h
>> index 0f244e1..2af5be8 100644
>> --- a/cpukit/score/cpu/m68k/rtems/score/cpu.h
>> +++ b/cpukit/score/cpu/m68k/rtems/score/cpu.h
>> @@ -711,6 +711,18 @@ void _CPU_Context_restore_fp(
>> +  /* TODO */
>> +  while (1) {
>> +    /* TODO */
>>    *  This method prints the CPU exception frame.
>> diff --git a/cpukit/score/cpu/mips/rtems/score/cpu.h b/cpukit/score/cpu/mips/rtems/score/cpu.h
>> index 130c960..229490b 100644
>> --- a/cpukit/score/cpu/mips/rtems/score/cpu.h
>> +++ b/cpukit/score/cpu/mips/rtems/score/cpu.h
>> @@ -1125,6 +1125,18 @@ void _CPU_Context_restore_fp(
>> +  /* TODO */
>> +  while (1) {
>> +    /* TODO */
>>   void _BSP_Exception_frame_print( const CPU_Exception_frame *frame );
>>   static inline void _CPU_Exception_frame_print(
>> diff --git a/cpukit/score/cpu/moxie/rtems/score/cpu.h b/cpukit/score/cpu/moxie/rtems/score/cpu.h
>> index e51798b..7c48d7b 100644
>> --- a/cpukit/score/cpu/moxie/rtems/score/cpu.h
>> +++ b/cpukit/score/cpu/moxie/rtems/score/cpu.h
>> @@ -970,6 +970,18 @@ void _CPU_Context_restore_fp(
>> +  /* TODO */
>> +  while (1) {
>> +    /* TODO */
>>    * @brief The set of registers that specifies the complete processor state.
>> diff --git a/cpukit/score/cpu/nios2/Makefile.am b/cpukit/score/cpu/nios2/Makefile.am
>> index 27bfb30..6fdc786 100644
>> --- a/cpukit/score/cpu/nios2/Makefile.am
>> +++ b/cpukit/score/cpu/nios2/Makefile.am
>> @@ -23,6 +23,8 @@ noinst_LIBRARIES = libscorecpu.a
>>   libscorecpu_a_SOURCES += nios2-context-initialize.c
>>   libscorecpu_a_SOURCES += nios2-context-switch.S
>> +libscorecpu_a_SOURCES += nios2-context-validate.S
>> +libscorecpu_a_SOURCES += nios2-context-volatile-clobber.S
>>   libscorecpu_a_SOURCES += nios2-eic-il-low-level.S
>>   libscorecpu_a_SOURCES += nios2-eic-rsie-low-level.S
>>   libscorecpu_a_SOURCES += nios2-exception-frame-print.c
>> diff --git a/cpukit/score/cpu/nios2/nios2-context-validate.S b/cpukit/score/cpu/nios2/nios2-context-validate.S
>> index 0000000..9a5f5e1
>> --- /dev/null
>> +++ b/cpukit/score/cpu/nios2/nios2-context-validate.S
>> @@ -0,0 +1,146 @@
>> + *  Dornierstr. 4
>> + *  82178 Puchheim
>> + *  Germany
>> +#endif
>> +#define FRAME_OFFSET_R16 0
>> +#define FRAME_OFFSET_R17 4
>> +#define FRAME_OFFSET_R18 8
>> +#define FRAME_OFFSET_R19 12
>> +#define FRAME_OFFSET_R20 16
>> +#define FRAME_OFFSET_R21 20
>> +#define FRAME_OFFSET_R22 24
>> +#define FRAME_OFFSET_R23 28
>> +#define FRAME_OFFSET_FP 32
>> +#define FRAME_OFFSET_RA 36
>> +#define FRAME_SIZE (FRAME_OFFSET_RA + 4)
>> +       .set    noat
>> +       .section        .text
>> +       .global _CPU_Context_validate
>> +_CPU_Context_validate:
>> +       /* Save */
>> +       subi    sp, sp, FRAME_SIZE
>> +       stw     r16, FRAME_OFFSET_R16(sp)
>> +       stw     r17, FRAME_OFFSET_R17(sp)
>> +       stw     r18, FRAME_OFFSET_R18(sp)
>> +       stw     r19, FRAME_OFFSET_R19(sp)
>> +       stw     r20, FRAME_OFFSET_R20(sp)
>> +       stw     r21, FRAME_OFFSET_R21(sp)
>> +       stw     r22, FRAME_OFFSET_R22(sp)
>> +       stw     r23, FRAME_OFFSET_R23(sp)
>> +       stw     fp, FRAME_OFFSET_FP(sp)
>> +       stw     ra, FRAME_OFFSET_RA(sp)
>> +       /* Fill */
>> +       /* AT contains the stack pointer */
>> +       mov     at, sp
>> +       /* R2 is used for temporary values */
>> +       subi    r3, r4, 1
>> +       addi    r5, r4, 1
>> +       addi    r6, r4, 2
>> +       addi    r7, r4, 3
>> +       addi    r8, r4, 4
>> +       addi    r9, r4, 5
>> +       addi    r10, r4, 6
>> +       addi    r11, r4, 7
>> +       addi    r12, r4, 8
>> +       addi    r13, r4, 9
>> +       addi    r14, r4, 10
>> +       addi    r15, r4, 11
>> +       addi    r16, r4, 12
>> +       addi    r17, r4, 13
>> +       addi    r18, r4, 14
>> +       addi    r19, r4, 15
>> +       addi    r20, r4, 16
>> +       addi    r21, r4, 17
>> +       addi    r22, r4, 18
>> +       addi    r23, r4, 19
>> +       addi    fp, r4, 20
>> +       addi    ra, r4, 21
>> +       /* Check */
>> +check:
>> +       bne     sp, at, restore
>> +       subi    r2, r4, 1
>> +       bne     r2, r3, restore
>> +       addi    r2, r4, 1
>> +       bne     r2, r5, restore
>> +       addi    r2, r4, 2
>> +       bne     r2, r6, restore
>> +       addi    r2, r4, 3
>> +       bne     r2, r7, restore
>> +       addi    r2, r4, 4
>> +       bne     r2, r8, restore
>> +       addi    r2, r4, 5
>> +       bne     r2, r9, restore
>> +       addi    r2, r4, 6
>> +       bne     r2, r10, restore
>> +       addi    r2, r4, 7
>> +       bne     r2, r11, restore
>> +       addi    r2, r4, 8
>> +       bne     r2, r12, restore
>> +       addi    r2, r4, 9
>> +       bne     r2, r13, restore
>> +       addi    r2, r4, 10
>> +       bne     r2, r14, restore
>> +       addi    r2, r4, 11
>> +       bne     r2, r15, restore
>> +       addi    r2, r4, 12
>> +       bne     r2, r16, restore
>> +       addi    r2, r4, 13
>> +       bne     r2, r17, restore
>> +       addi    r2, r4, 14
>> +       bne     r2, r18, restore
>> +       addi    r2, r4, 15
>> +       bne     r2, r19, restore
>> +       addi    r2, r4, 16
>> +       bne     r2, r20, restore
>> +       addi    r2, r4, 17
>> +       bne     r2, r21, restore
>> +       addi    r2, r4, 18
>> +       bne     r2, r22, restore
>> +       addi    r2, r4, 19
>> +       bne     r2, r23, restore
>> +       addi    r2, r4, 20
>> +       bne     r2, fp, restore
>> +       addi    r2, r4, 21
>> +       bne     r2, ra, restore
>> +       br      check
>> +       /* Restore */
>> +restore:
>> +       ldw     ra, FRAME_OFFSET_RA(sp)
>> +       ldw     fp, FRAME_OFFSET_FP(sp)
>> +       ldw     r23, FRAME_OFFSET_R23(sp)
>> +       ldw     r22, FRAME_OFFSET_R22(sp)
>> +       ldw     r21, FRAME_OFFSET_R21(sp)
>> +       ldw     r20, FRAME_OFFSET_R20(sp)
>> +       ldw     r19, FRAME_OFFSET_R19(sp)
>> +       ldw     r18, FRAME_OFFSET_R18(sp)
>> +       ldw     r17, FRAME_OFFSET_R17(sp)
>> +       ldw     r16, FRAME_OFFSET_R16(sp)
>> +       addi    sp, sp, FRAME_SIZE
>> +       ret
>> diff --git a/cpukit/score/cpu/nios2/nios2-context-volatile-clobber.S b/cpukit/score/cpu/nios2/nios2-context-volatile-clobber.S
>> index 0000000..7b484e7
>> --- /dev/null
>> +++ b/cpukit/score/cpu/nios2/nios2-context-volatile-clobber.S
>> @@ -0,0 +1,42 @@
>> + *  Dornierstr. 4
>> + *  82178 Puchheim
>> + *  Germany
>> +#endif
>> +       .set    noat
>> +       .section        .text
>> +       .global _CPU_Context_volatile_clobber
>> +_CPU_Context_volatile_clobber:
>> +       subi    at, r4, 11
>> +       subi    r2, r4, 12
>> +       subi    r3, r4, 13
>> +       subi    r5, r4, 1
>> +       subi    r6, r4, 2
>> +       subi    r7, r4, 3
>> +       subi    r8, r4, 4
>> +       subi    r9, r4, 5
>> +       subi    r10, r4, 6
>> +       subi    r11, r4, 7
>> +       subi    r12, r4, 8
>> +       subi    r13, r4, 9
>> +       subi    r14, r4, 10
>> +       subi    r15, r4, 11
>> +       ret
>> diff --git a/cpukit/score/cpu/nios2/rtems/score/cpu.h b/cpukit/score/cpu/nios2/rtems/score/cpu.h
>> index b0e94c5..d3b5046 100644
>> --- a/cpukit/score/cpu/nios2/rtems/score/cpu.h
>> +++ b/cpukit/score/cpu/nios2/rtems/score/cpu.h
>> @@ -333,6 +333,10 @@ void _CPU_Context_restore(
>> diff --git a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
>> index 8c4a61b..fae7677 100644
>> --- a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
>> +++ b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
>> @@ -1295,6 +1295,33 @@ void _CPU_Context_restore_fp(
>> + * @ingroup CPUContext
>> + * @brief Clobbers all volatile registers with values derived from the pattern
>> + * parameter.
>> + * This function is used in test sptests/spcontext01.
>> + * @param[in] pattern Pattern used to generate distinct register values.
>> + * @brief Initializes and validates the CPU context with values derived from
>> + * the pattern parameter.
>> + * This function will not return if the CPU context remains consistent.  In
>> + * case this function returns the CPU port is broken.
>>    * The CPU exception frame may be available in fatal error conditions like for
>> diff --git a/cpukit/score/cpu/powerpc/Makefile.am b/cpukit/score/cpu/powerpc/Makefile.am
>> index 7fd64ef..b205762 100644
>> --- a/cpukit/score/cpu/powerpc/Makefile.am
>> +++ b/cpukit/score/cpu/powerpc/Makefile.am
>> @@ -14,6 +14,8 @@ include_rtems_powerpc_HEADERS = rtems/powerpc/registers.h
>>   libscorecpu_a_SOURCES = cpu.c
>> +libscorecpu_a_SOURCES += ppc-context-volatile-clobber.S
>> +libscorecpu_a_SOURCES += ppc-context-validate.S
>>   libscorecpu_a_SOURCES += ppc-isr-vector-install.c
>> diff --git a/cpukit/score/cpu/powerpc/ppc-context-validate.S b/cpukit/score/cpu/powerpc/ppc-context-validate.S
>> index 0000000..0e3154e
>> --- /dev/null
>> +++ b/cpukit/score/cpu/powerpc/ppc-context-validate.S
>> @@ -0,0 +1,263 @@
>> + *  Dornierstr. 4
>> + *  82178 Puchheim
>> + *  Germany
>> +#endif
>> +#include <rtems/score/cpu.h>
>> +#define LR_OFFSET 8
>> +#define CR_OFFSET 12
>> +#define OFFSET(i) ((i) * PPC_GPR_SIZE + 16)
>> +#define GPR14_OFFSET OFFSET(0)
>> +#define GPR15_OFFSET OFFSET(1)
>> +#define GPR16_OFFSET OFFSET(2)
>> +#define GPR17_OFFSET OFFSET(3)
>> +#define GPR18_OFFSET OFFSET(4)
>> +#define GPR19_OFFSET OFFSET(5)
>> +#define GPR20_OFFSET OFFSET(6)
>> +#define GPR21_OFFSET OFFSET(7)
>> +#define GPR22_OFFSET OFFSET(8)
>> +#define GPR23_OFFSET OFFSET(9)
>> +#define GPR24_OFFSET OFFSET(10)
>> +#define GPR25_OFFSET OFFSET(11)
>> +#define GPR26_OFFSET OFFSET(12)
>> +#define GPR27_OFFSET OFFSET(13)
>> +#define GPR28_OFFSET OFFSET(14)
>> +#define GPR29_OFFSET OFFSET(15)
>> +#define GPR30_OFFSET OFFSET(16)
>> +#define GPR31_OFFSET OFFSET(17)
>> +#define FRAME_SIZE \
>> +  ((OFFSET(18) + CPU_STACK_ALIGNMENT - 1) & (CPU_STACK_ALIGNMENT - 1))
>> +       /* Save */
>> +       stwu    r1, -FRAME_SIZE(r1)
>> +       mflr    r4
>> +       stw     r4, LR_OFFSET(r1)
>> +       mfcr    r4
>> +       stw     r4, CR_OFFSET(r1)
>> +       stw     r14, GPR14_OFFSET(r1)
>> +       stw     r15, GPR15_OFFSET(r1)
>> +       stw     r16, GPR16_OFFSET(r1)
>> +       stw     r17, GPR17_OFFSET(r1)
>> +       stw     r18, GPR18_OFFSET(r1)
>> +       stw     r19, GPR19_OFFSET(r1)
>> +       stw     r20, GPR20_OFFSET(r1)
>> +       stw     r21, GPR21_OFFSET(r1)
>> +       stw     r22, GPR22_OFFSET(r1)
>> +       stw     r23, GPR23_OFFSET(r1)
>> +       stw     r24, GPR24_OFFSET(r1)
>> +       stw     r25, GPR25_OFFSET(r1)
>> +       stw     r26, GPR26_OFFSET(r1)
>> +       stw     r27, GPR27_OFFSET(r1)
>> +       stw     r28, GPR28_OFFSET(r1)
>> +       stw     r29, GPR29_OFFSET(r1)
>> +       stw     r30, GPR30_OFFSET(r1)
>> +       stw     r31, GPR31_OFFSET(r1)
>> +       /* Fill */
>> +       /* CR and GPR29 are equal most of the time */
>> +       addi    r4, r3, 24
>> +       mtcr    r4
>> +       addi    r4, r3, 25
>> +       mtlr    r4
>> +       addi    r4, r3, 26
>> +       mtctr   r4
>> +       addi    r4, r3, 27
>> +       mtxer   r4
>> +       addi    r0, r3, 28
>> +       /* GPR4 is used for temporary values */
>> +       addi    r5, r3, 1
>> +       addi    r6, r3, 2
>> +       addi    r7, r3, 3
>> +       addi    r8, r3, 4
>> +       addi    r9, r3, 5
>> +       addi    r10, r3, 6
>> +       addi    r11, r3, 7
>> +       addi    r12, r3, 8
>> +       addi    r14, r3, 9
>> +       addi    r15, r3, 10
>> +       addi    r16, r3, 11
>> +       addi    r17, r3, 12
>> +       addi    r18, r3, 13
>> +       addi    r19, r3, 14
>> +       addi    r20, r3, 15
>> +       addi    r21, r3, 16
>> +       addi    r22, r3, 17
>> +       addi    r23, r3, 18
>> +       addi    r24, r3, 19
>> +       addi    r25, r3, 20
>> +       addi    r26, r3, 21
>> +       addi    r27, r3, 22
>> +       addi    r28, r3, 23
>> +       /* GPR29 and CR are equal most of the time */
>> +       addi    r29, r3, 24
>> +       /* GPR30 contains the MSR pattern */
>> +       mfmsr   r30
>> +       xor     r30, r30, r3
>> +       /* GPR31 contains the stack pointer */
>> +       mr      r31, r1
>> +       /* Check */
>> +check:
>> +       mfcr    r4
>> +       cmpw    r4, r29
>> +       bne     restore
>> +       addi    r4, r3, 1
>> +       cmpw    r4, r5
>> +       bne     restore
>> +       addi    r4, r3, 2
>> +       cmpw    r4, r6
>> +       bne     restore
>> +       addi    r4, r3, 3
>> +       cmpw    r4, r7
>> +       bne     restore
>> +       addi    r4, r3, 4
>> +       cmpw    r4, r8
>> +       bne     restore
>> +       addi    r4, r3, 5
>> +       cmpw    r4, r9
>> +       bne     restore
>> +       addi    r4, r3, 6
>> +       cmpw    r4, r10
>> +       bne     restore
>> +       addi    r4, r3, 7
>> +       cmpw    r4, r11
>> +       bne     restore
>> +       addi    r4, r3, 8
>> +       cmpw    r4, r12
>> +       bne     restore
>> +       lis     r4, _SDA_BASE_ at h
>> +       ori     r4, r4, _SDA_BASE_ at l
>> +       cmpw    r4, r13
>> +       bne     restore
>> +       addi    r4, r3, 9
>> +       cmpw    r4, r14
>> +       bne     restore
>> +       addi    r4, r3, 10
>> +       cmpw    r4, r15
>> +       bne     restore
>> +       addi    r4, r3, 11
>> +       cmpw    r4, r16
>> +       bne     restore
>> +       addi    r4, r3, 12
>> +       cmpw    r4, r17
>> +       bne     restore
>> +       addi    r4, r3, 13
>> +       cmpw    r4, r18
>> +       bne     restore
>> +       addi    r4, r3, 14
>> +       cmpw    r4, r19
>> +       bne     restore
>> +       addi    r4, r3, 15
>> +       cmpw    r4, r20
>> +       bne     restore
>> +       addi    r4, r3, 16
>> +       cmpw    r4, r21
>> +       bne     restore
>> +       addi    r4, r3, 17
>> +       cmpw    r4, r22
>> +       bne     restore
>> +       addi    r4, r3, 18
>> +       cmpw    r4, r23
>> +       bne     restore
>> +       addi    r4, r3, 19
>> +       cmpw    r4, r24
>> +       bne     restore
>> +       addi    r4, r3, 20
>> +       cmpw    r4, r25
>> +       bne     restore
>> +       addi    r4, r3, 21
>> +       cmpw    r4, r26
>> +       bne     restore
>> +       addi    r4, r3, 22
>> +       cmpw    r4, r27
>> +       bne     restore
>> +       addi    r4, r3, 23
>> +       cmpw    r4, r28
>> +       bne     restore
>> +       addi    r4, r3, 24
>> +       cmpw    r4, r29
>> +       bne     restore
>> +       mfmsr   r4
>> +       xor     r4, r4, r3
>> +       cmpw    r4, r30
>> +       bne     restore
>> +       addi    r4, r3, 25
>> +       mflr    r5
>> +       cmpw    r4, r5
>> +       bne     restore
>> +       addi    r4, r3, 26
>> +       mfctr   r5
>> +       cmpw    r4, r5
>> +       bne     restore
>> +       addi    r4, r3, 27
>> +       mfxer   r5
>> +       cmpw    r4, r5
>> +       bne     restore
>> +       addi    r4, r3, 28
>> +       cmpw    r4, r0
>> +       bne     restore
>> +       cmpw    r31, r1
>> +       bne     restore
>> +#if 0
>> +       /* This is only valid if we use the EABI */
>> +       lis     r4, _SDA2_BASE_ at h
>> +       ori     r4, r4, _SDA2_BASE_ at l
>> +       cmpw    r4, r2
>> +       bne     restore
>> +#endif
>> +       mtcr    r29
>> +       addi    r5, r3, 1
>> +       b       check
>> +       /* Restore */
>> +restore:
>> +       lwz     r31, GPR31_OFFSET(r1)
>> +       lwz     r30, GPR30_OFFSET(r1)
>> +       lwz     r29, GPR29_OFFSET(r1)
>> +       lwz     r28, GPR28_OFFSET(r1)
>> +       lwz     r27, GPR27_OFFSET(r1)
>> +       lwz     r26, GPR26_OFFSET(r1)
>> +       lwz     r25, GPR25_OFFSET(r1)
>> +       lwz     r24, GPR24_OFFSET(r1)
>> +       lwz     r23, GPR23_OFFSET(r1)
>> +       lwz     r22, GPR22_OFFSET(r1)
>> +       lwz     r21, GPR21_OFFSET(r1)
>> +       lwz     r20, GPR20_OFFSET(r1)
>> +       lwz     r19, GPR19_OFFSET(r1)
>> +       lwz     r18, GPR18_OFFSET(r1)
>> +       lwz     r17, GPR17_OFFSET(r1)
>> +       lwz     r16, GPR16_OFFSET(r1)
>> +       lwz     r15, GPR15_OFFSET(r1)
>> +       lwz     r14, GPR14_OFFSET(r1)
>> +       lwz     r4, CR_OFFSET(r1)
>> +       mtcr    r4
>> +       lwz     r4, LR_OFFSET(r1)
>> +       mtlr    r4
>> +       addi    r1, r1, FRAME_SIZE
>> +       blr
>> diff --git a/cpukit/score/cpu/powerpc/ppc-context-volatile-clobber.S b/cpukit/score/cpu/powerpc/ppc-context-volatile-clobber.S
>> index 0000000..f4a5721
>> --- /dev/null
>> +++ b/cpukit/score/cpu/powerpc/ppc-context-volatile-clobber.S
>> @@ -0,0 +1,45 @@
>> + *  Dornierstr. 4
>> + *  82178 Puchheim
>> + *  Germany
>> +#endif
>> +       addi    r4, r3, 10
>> +       rlwinm  r4, r4, 0, 20, 7
>> +       mfcr    r5
>> +       rlwinm  r5, r5, 0, 8, 19
>> +       or      r4, r4, r5
>> +       mtcr    r4
>> +       addi    r4, r3, 11
>> +       mtctr   r4
>> +       addi    r4, r3, 12
>> +       mtxer   r4
>> +       addi    r0, r3, 13
>> +       addi    r4, r3, 1
>> +       addi    r5, r3, 2
>> +       addi    r6, r3, 3
>> +       addi    r7, r3, 4
>> +       addi    r8, r3, 5
>> +       addi    r9, r3, 6
>> +       addi    r10, r3, 7
>> +       addi    r11, r3, 8
>> +       addi    r12, r3, 9
>> +       blr
>> diff --git a/cpukit/score/cpu/powerpc/rtems/score/cpu.h b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
>> index 37d8c34..080c5bb 100644
>> --- a/cpukit/score/cpu/powerpc/rtems/score/cpu.h
>> +++ b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
>> @@ -992,6 +992,10 @@ void _CPU_Context_restore_fp(
>>   typedef struct {
>>     uint32_t EXC_SRR0;
>>     uint32_t EXC_SRR1;
>> diff --git a/cpukit/score/cpu/sh/rtems/score/cpu.h b/cpukit/score/cpu/sh/rtems/score/cpu.h
>> index f5ad90c..d4412f6 100644
>> --- a/cpukit/score/cpu/sh/rtems/score/cpu.h
>> +++ b/cpukit/score/cpu/sh/rtems/score/cpu.h
>> @@ -886,6 +886,18 @@ void _CPU_Context_restore_fp(
>> +  /* TODO */
>> +  while (1) {
>> +    /* TODO */
>>   /* FIXME */
>> diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
>> index b95d411..2209c89 100644
>> --- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
>> +++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
>> @@ -1227,6 +1227,18 @@ void _CPU_Context_restore_fp(
>> +  /* TODO */
>> +  while (1) {
>> +    /* TODO */
>>   typedef struct {
>>     uint32_t trap;
>>     CPU_Interrupt_frame *isf;
>> diff --git a/cpukit/score/cpu/sparc64/rtems/score/cpu.h b/cpukit/score/cpu/sparc64/rtems/score/cpu.h
>> index 36c7144..314143b 100644
>> --- a/cpukit/score/cpu/sparc64/rtems/score/cpu.h
>> +++ b/cpukit/score/cpu/sparc64/rtems/score/cpu.h
>> @@ -1028,6 +1028,18 @@ void _CPU_Context_restore_fp(
>> +  /* TODO */
>> +  while (1) {
>> +    /* TODO */
>>   /* FIXME */
>> diff --git a/cpukit/score/cpu/v850/rtems/score/cpu.h b/cpukit/score/cpu/v850/rtems/score/cpu.h
>> index c0b6f9e..12c824b 100644
>> --- a/cpukit/score/cpu/v850/rtems/score/cpu.h
>> +++ b/cpukit/score/cpu/v850/rtems/score/cpu.h
>> @@ -1128,6 +1128,18 @@ void _CPU_Context_restore_fp(
>>   #endif
>> +  /* TODO */
>> +  while (1) {
>> +    /* TODO */
>>   /* FIXME */
>> diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
>> index c9d20dd..4b0fff6 100644
>> --- a/testsuites/sptests/Makefile.am
>> +++ b/testsuites/sptests/Makefile.am
>> @@ -30,6 +30,7 @@ SUBDIRS = \
>>       spcbssched01 spcbssched02 spcbssched03 spqreslib sptimespec01 \
>>       spatomic01 spatomic02 spatomic03 spatomic04 spatomic05 \
>>       spatomic06 spatomic07
>> +SUBDIRS += spcontext01
>>   SUBDIRS += spfatal26
>>   SUBDIRS += speventtransient01
>>   SUBDIRS += speventsystem01
>> diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
>> index a43a1ad..ba3aa92 100644
>> --- a/testsuites/sptests/configure.ac
>> +++ b/testsuites/sptests/configure.ac
>> @@ -27,6 +27,7 @@ AC_CHECK_SIZEOF([time_t])
>>   # Explicitly list all Makefiles here
>>   AC_CONFIG_FILES([Makefile
>> +spcontext01/Makefile
>>   spfatal26/Makefile
>>   spinternalerror02/Makefile
>>   spinternalerror01/Makefile
>> diff --git a/testsuites/sptests/spcontext01/Makefile.am b/testsuites/sptests/spcontext01/Makefile.am
>> index 0000000..b1c7de2
>> --- /dev/null
>> +++ b/testsuites/sptests/spcontext01/Makefile.am
>> @@ -0,0 +1,19 @@
>> +rtems_tests_PROGRAMS = spcontext01
>> +spcontext01_SOURCES = init.c
>> +dist_rtems_tests_DATA = spcontext01.scn spcontext01.doc
>> +include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
>> +include $(top_srcdir)/../automake/compile.am
>> +include $(top_srcdir)/../automake/leaf.am
>> +AM_CPPFLAGS += -I$(top_srcdir)/../support/include
>> +LINK_OBJS = $(spcontext01_OBJECTS)
>> +LINK_LIBS = $(spcontext01_LDLIBS)
>> +spcontext01$(EXEEXT): $(spcontext01_OBJECTS) $(spcontext01_DEPENDENCIES)
>> +       @rm -f spcontext01$(EXEEXT)
>> +       $(make-exe)
>> +include $(top_srcdir)/../automake/local.am
>> diff --git a/testsuites/sptests/spcontext01/init.c b/testsuites/sptests/spcontext01/init.c
>> index 0000000..f9c1803
>> --- /dev/null
>> +++ b/testsuites/sptests/spcontext01/init.c
>> @@ -0,0 +1,188 @@
>> + *  Dornierstr. 4
>> + *  82178 Puchheim
>> + *  Germany
>> +#endif
>> +#include "tmacros.h"
>> +#define ITERATION_COUNT 2000
>> +#define PRIORITY_HIGH 2
>> +#define PRIORITY_LOW 3
>> +#define FINISH_EVENT RTEMS_EVENT_0
>> +typedef struct {
>> +  rtems_id control_task;
>> +  rtems_id validate_tasks[2];
>> +  size_t task_index;
>> +  int iteration_counter;
>> +} test_context;
>> +static test_context test_instance;
>> +static void validate_task(rtems_task_argument arg)
>> +  _CPU_Context_validate(arg);
>> +  rtems_test_assert(0);
>> +static void start_validate_task(
>> +  rtems_id *id,
>> +  uintptr_t pattern,
>> +  rtems_task_priority priority
>> +  rtems_status_code sc;
>> +  sc = rtems_task_create(
>> +    rtems_build_name('V', 'A', 'L', 'I'),
>> +    priority,
>> +    RTEMS_MINIMUM_STACK_SIZE,
>> +    RTEMS_DEFAULT_MODES,
>> +    RTEMS_DEFAULT_ATTRIBUTES,
>> +    id
>> +  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
>> +  sc = rtems_task_start(*id, validate_task, pattern);
>> +static void reset_timer_or_finish(test_context *self, rtems_id timer)
>> +  int i = self->iteration_counter;
>> +  if (i < ITERATION_COUNT) {
>> +    self->iteration_counter = i + 1;
>> +    sc = rtems_timer_reset(timer);
>> +  } else {
>> +    sc = rtems_event_send(self->control_task, FINISH_EVENT);
>> +static void switch_priorities(test_context *self)
>> +  size_t index = self->task_index;
>> +  size_t next = (index + 1) & 0x1;
>> +  size_t task_high = index;
>> +  size_t task_low = next;
>> +  rtems_task_priority priority;
>> +  self->task_index = next;
>> +  sc = rtems_task_set_priority(
>> +    self->validate_tasks[task_high],
>> +    PRIORITY_HIGH,
>> +    &priority
>> +    self->validate_tasks[task_low],
>> +    PRIORITY_LOW,
>> +    &priority
>> +static void clobber_and_switch_timer(rtems_id timer, void *arg)
>> +  uintptr_t pattern = (uintptr_t) 0xffffffffffffffffU;
>> +  test_context *self = arg;
>> +  reset_timer_or_finish(self, timer);
>> +  switch_priorities(self);
>> +  _CPU_Context_volatile_clobber(pattern);
>> +static void start_timer(test_context *self)
>> +  rtems_id timer;
>> +  sc = rtems_timer_create(rtems_build_name('C', 'L', 'S', 'W'), &timer);
>> +  sc = rtems_timer_fire_after(timer, 2, clobber_and_switch_timer, self);
>> +static void wait_for_finish(void)
>> +  rtems_event_set out;
>> +  sc = rtems_event_receive(
>> +    FINISH_EVENT,
>> +    RTEMS_WAIT | RTEMS_EVENT_ALL,
>> +    RTEMS_NO_TIMEOUT,
>> +    &out
>> +  rtems_test_assert(out == FINISH_EVENT);
>> +static void test(test_context *self)
>> +  uintptr_t pattern_0 = (uintptr_t) 0xaaaaaaaaaaaaaaaaU;
>> +  uintptr_t pattern_1 = (uintptr_t) 0x5555555555555555U;
>> +  memset(self, 0, sizeof(*self));
>> +  self->control_task = rtems_task_self();
>> +  start_validate_task(&self->validate_tasks[0], pattern_0, PRIORITY_LOW);
>> +  start_validate_task(&self->validate_tasks[1], pattern_1, PRIORITY_HIGH);
>> +  start_timer(self);
>> +  wait_for_finish();
>> +static void Init(rtems_task_argument arg)
>> +  test_context *self = &test_instance;
>> +  puts("\n\n*** TEST SPCONTEXT 1 ***");
>> +  test(self);
>> +  puts("*** END OF TEST SPCONTEXT 1 ***");
>> +  rtems_test_exit(0);
>> +#define CONFIGURE_MICROSECONDS_PER_TICK 1000
>> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>> +#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
>> +#define CONFIGURE_MAXIMUM_TASKS 3
>> +#define CONFIGURE_MAXIMUM_TIMERS 1
>> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>> +#define CONFIGURE_INIT
>> +#include <rtems/confdefs.h>
>> diff --git a/testsuites/sptests/spcontext01/spcontext01.doc b/testsuites/sptests/spcontext01/spcontext01.doc
>> index 0000000..2c2c4cf
>> --- /dev/null
>> +++ b/testsuites/sptests/spcontext01/spcontext01.doc
>> @@ -0,0 +1,11 @@
>> +This file describes the directives and concepts tested by this test set.
>> +test set name: spcontext01
>> +directives:
>> +  TBD
>> +concepts:
>> +  - Ensure the context switching and interrupt processing works
>> diff --git a/testsuites/sptests/spcontext01/spcontext01.scn b/testsuites/sptests/spcontext01/spcontext01.scn
>> index 0000000..b7b823b
>> --- /dev/null
>> +++ b/testsuites/sptests/spcontext01/spcontext01.scn
>> @@ -0,0 +1,2 @@
>> +*** TEST SPCONTEXT 1 ***
>> +*** END OF TEST SPCONTEXT 1 ***
>> 1.7.7
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
