[PATCH 2/4] score: Add CPU context validation
Wed May 8 14:07:21 UTC 2013
On 05/08/2013 03:54 PM, Joel Sherrill wrote:
> On 5/8/2013 8:32 AM, Gedare Bloom wrote:
>> This change needs some explanation and documentation in the CPU
>> Porting Guide. What are the two new CPU functions supposed to do?
> And why would an infinite loop be a valid implementation?
Because this function doesn't return if everything is ok.  This results in a
test pass.  An alternative would be to issue a fatal error.  This results in a
test failure.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
