statvfs for MS-DOS filesystem and 'df' coomand for shell
Andrei Mozzhuhin nopscmn at gmail.com
Sun May 12 19:32:07 UTC 2013
2013/4/16 Joel Sherrill <joel.sherrill at oarcorp.com>:
> On 4/15/2013 2:20 PM, Andrei Mozzhuhin wrote:
>> Hi,
>> Send patch with improvements as Sebastian Huber suggest in
>> https://www.rtems.org/bugzilla/show_bug.cgi?id=2114.
> My quick comments while trying to see what happened in Boston. :(
> + Don't use tabs in source files. Use spaces for indentation.
> Standard style is two spaces.
> + doc/shell/file.t needs an entry for df.
> Not your issue.. but I was surprised to see that there is no
> group of "common disk commands" like networking has.
> Thanks. Please swing at these and update the PR.
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
Updated patch.
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130512/cc327c7c/attachment.obj>
