[PATCH v2] score: Add maximum_processors field to config
Mon May 13 12:18:46 UTC 2013
Delete rtems_configuration_get_smp_maximum_processors().  Delete
rtems_configuration_smp_maximum_processors variable.  Add
maximum_processors field to rtems_configuration_table if RTEMS_SMP is
defined.  Add rtems_configuration_get_maximum_processors().
 c/src/lib/libbsp/i386/shared/smp/smp-imps.c  |    8 ++++----
 c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c |    6 +++---
 cpukit/rtems/include/rtems/rtems/smp.h       |   14 --------------
 cpukit/sapi/include/confdefs.h               |   13 +++----------
 cpukit/sapi/include/rtems/config.h           |   19 +++++++++++++++++++
 cpukit/sapi/src/exinit.c                     |    2 +-
 cpukit/score/src/percpu.c                    |    2 +-
 cpukit/score/src/thread.c                    |    2 +-
 8 files changed, 32 insertions(+), 34 deletions(-)
diff --git a/c/src/lib/libbsp/i386/shared/smp/smp-imps.c b/c/src/lib/libbsp/i386/shared/smp/smp-imps.c
index f1be625..60bb0e6 100644
--- a/c/src/lib/libbsp/i386/shared/smp/smp-imps.c
+++ b/c/src/lib/libbsp/i386/shared/smp/smp-imps.c
@@ -401,7 +401,7 @@ imps_read_config_table(unsigned start, int count)
   while (count-- > 0) {
     switch (*((unsigned char *)start)) {
     case IMPS_BCT_PROCESSOR:
-      if ( imps_num_cpus < rtems_configuration_smp_maximum_processors ) {
+      if ( imps_num_cpus < rtems_configuration_get_maximum_processors() ) {
 	add_processor((imps_processor *)start);
       } else
         imps_num_cpus++;
@@ -428,13 +428,13 @@ imps_read_config_table(unsigned start, int count)
     start += 8;
-  if ( imps_num_cpus > rtems_configuration_smp_maximum_processors ) {
+  if ( imps_num_cpus > rtems_configuration_get_maximum_processors() ) {
     printk(
       "WARNING!! Found more CPUs (%d) than configured for (%d)!!\n",
       imps_num_cpus - 1,
-      rtems_configuration_smp_maximum_processors
+      rtems_configuration_get_maximum_processors()
-    imps_num_cpus = rtems_configuration_smp_maximum_processors;
+    imps_num_cpus = rtems_configuration_get_maximum_processors();
     return;
diff --git a/c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c b/c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c
index 1f371bf..a9f4a0e 100644
--- a/c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c
+++ b/c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c
@@ -71,13 +71,13 @@ int bsp_smp_initialize(
     printk( "Found %d CPUs\n", found_cpus );
   #endif
-  if ( found_cpus > rtems_configuration_smp_maximum_processors ) {
+  if ( found_cpus > rtems_configuration_get_maximum_processors() ) {
     printk(
       "%d CPUs IS MORE THAN CONFIGURED -- ONLY USING %d\n",
       found_cpus,
-    found_cpus = rtems_configuration_smp_maximum_processors;
+    found_cpus = rtems_configuration_get_maximum_processors();
   if ( found_cpus == 1 )
diff --git a/cpukit/rtems/include/rtems/rtems/smp.h b/cpukit/rtems/include/rtems/rtems/smp.h
index e62084c..1b0618e 100644
--- a/cpukit/rtems/include/rtems/rtems/smp.h
+++ b/cpukit/rtems/include/rtems/rtems/smp.h
@@ -36,8 +36,6 @@ extern "C" {
-extern uint32_t rtems_configuration_smp_maximum_processors;
  * @brief Obtain Number of Cores in System
@@ -51,18 +49,6 @@ extern uint32_t rtems_configuration_smp_maximum_processors;
     (_SMP_Processor_count)
- * @brief Obtain Maximum Cores Configured
- * This method returns the number of CPU cores that were configured
- * in the system. The actual number of cores will always be less than
- * or equal to the number  of maximum number of cores which were configured.
- * @retval This method returns the number of cores configured.
-#define rtems_configuration_get_smp_maximum_processors() \
-    (rtems_configuration_smp_maximum_processors)
  * @brief Obtain Current Core Number
  * This method returns the id of the current CPU core.
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index f4b9232..569b7a7 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -2372,22 +2372,15 @@ const rtems_libio_helper rtems_fs_init_helper =
     #if defined(RTEMS_MULTIPROCESSING)
       CONFIGURE_MULTIPROCESSING_TABLE,        /* pointer to MP config table */
     #endif
+    #ifdef RTEMS_SMP
+      CONFIGURE_SMP_MAXIMUM_PROCESSORS
+    #endif
 #endif
 #endif /* CONFIGURE_HAS_OWN_CONFIGURATION_TABLE */
 #if defined(RTEMS_SMP)
-   * Instantiate the variable which specifies the number of CPUs
-   * in an SMP configuration.
-  #if defined(CONFIGURE_INIT)
-    uint32_t rtems_configuration_smp_maximum_processors = \
-        CONFIGURE_SMP_MAXIMUM_PROCESSORS;
-  #else
-    extern uint32_t rtems_configuration_smp_maximum_processors;
-  #endif
   * Instantiate the Per CPU information based upon the user configuration.
diff --git a/cpukit/sapi/include/rtems/config.h b/cpukit/sapi/include/rtems/config.h
index 58d2d92..d483471 100644
--- a/cpukit/sapi/include/rtems/config.h
+++ b/cpukit/sapi/include/rtems/config.h
@@ -230,6 +230,9 @@ typedef struct {
     rtems_multiprocessing_table   *User_multiprocessing_table;
   #endif
+  #ifdef RTEMS_SMP
+    uint32_t                     maximum_processors;
+  #endif
 } rtems_configuration_table;
@@ -335,6 +338,22 @@ extern const rtems_configuration_table Configuration;
         NULL
 #endif
+ * @brief Returns the configured maximum count of processors.
+ * The actual number of processors available for the application will be less
+ * than or equal to the configured maximum count of processors.
+ * @return The configured maximum count of processors.
+#ifdef RTEMS_SMP
+  #define rtems_configuration_get_maximum_processors() \
+        (Configuration.maximum_processors)
+#else
+        1
+#endif
 #define rtems_configuration_get_rtems_api_configuration() \
         (&Configuration_RTEMS_API)
diff --git a/cpukit/sapi/src/exinit.c b/cpukit/sapi/src/exinit.c
index 34e8075..a0abe11 100644
--- a/cpukit/sapi/src/exinit.c
+++ b/cpukit/sapi/src/exinit.c
@@ -164,7 +164,7 @@ void rtems_initialize_data_structures(void)
     _SMP_Processor_count =
-        bsp_smp_initialize( rtems_configuration_smp_maximum_processors );
+        bsp_smp_initialize( rtems_configuration_get_maximum_processors() );
   #endif
   _System_state_Set( SYSTEM_STATE_BEFORE_MULTITASKING );
diff --git a/cpukit/score/src/percpu.c b/cpukit/score/src/percpu.c
index 4a93fd8..7027093 100644
--- a/cpukit/score/src/percpu.c
+++ b/cpukit/score/src/percpu.c
@@ -46,7 +46,7 @@
     size = rtems_configuration_get_interrupt_stack_size();
     _Per_CPU_Information_p[0] = &_Per_CPU_Information[0];
-    for (cpu=1 ; cpu < rtems_configuration_smp_maximum_processors; cpu++ ) {
+    for (cpu=1 ; cpu < rtems_configuration_get_maximum_processors(); cpu++ ) {
       Per_CPU_Control *p = &_Per_CPU_Information[cpu];
diff --git a/cpukit/score/src/thread.c b/cpukit/score/src/thread.c
index b266d6e..391ea52 100644
--- a/cpukit/score/src/thread.c
+++ b/cpukit/score/src/thread.c
@@ -84,7 +84,7 @@ void _Thread_Handler_initialization(void)
    *  coupled multiprocessing system, account for the MPCI Server Thread.
-    maximum_internal_threads = rtems_configuration_smp_maximum_processors;
+    maximum_internal_threads = rtems_configuration_get_maximum_processors();
   #else
     maximum_internal_threads = 1;
   #endif
1.7.7
