[PATCH] RTL module file loading
Mohammed Khoory
mkhoory at eiast.ae
Thu May 16 10:05:07 UTC 2013
Two issues were fixed in these patches for the RTL project:
1. The mksyms.awk script did not correctly handle --no-embed
2. loading an ELF object file from the file system using dlopen failed with
a similar error to the following: "offset past end of file: offset=54660
size=0", where in reality the size is actually supposed to be bigger than
the offset.
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130516/7447a578/attachment.obj>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130516/7447a578/attachment-0001.obj>
