[PATCH] sptests: add test for priority inversion with nested locks.
Gedare Bloom
gedare at rtems.org
Sat May 18 14:16:54 UTC 2013
testsuites/sptests/Makefile.am | 2 +-
testsuites/sptests/configure.ac | 1 +
testsuites/sptests/spsemaphore01/Makefile.am | 21 +++
testsuites/sptests/spsemaphore01/init.c | 155 ++++++++++++++++++++++
testsuites/sptests/spsemaphore01/spsemaphore.doc | 1 +
testsuites/sptests/spsemaphore01/spsemaphore.scn | 15 ++
6 files changed, 194 insertions(+), 1 deletions(-)
create mode 100644 testsuites/sptests/spsemaphore01/Makefile.am
create mode 100644 testsuites/sptests/spsemaphore01/init.c
create mode 100644 testsuites/sptests/spsemaphore01/spsemaphore.doc
create mode 100644 testsuites/sptests/spsemaphore01/spsemaphore.scn
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index 4b0fff6..5c2300f 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -25,7 +25,7 @@ SUBDIRS = \
spintrcritical09 spintrcritical10 spintrcritical11 spintrcritical12 \
spintrcritical13 spintrcritical14 spintrcritical15 spintrcritical16 \
spintrcritical17 spintrcritical18 spmkdir spmountmgr01 spheapprot \
- spsimplesched01 spsimplesched02 spsimplesched03 spnsext01 \
+ spsemaphore01 spsimplesched01 spsimplesched02 spsimplesched03 spnsext01 \
spedfsched01 spedfsched02 spedfsched03 \
spcbssched01 spcbssched02 spcbssched03 spqreslib sptimespec01 \
spatomic01 spatomic02 spatomic03 spatomic04 spatomic05 \
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index ba3aa92..8a60767 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -188,6 +188,7 @@ spprintk/Makefile
spprivenv01/Makefile
spqreslib/Makefile
sprbtree01/Makefile
+spsemaphore01/Makefile
spsimplesched01/Makefile
spsimplesched02/Makefile
spsimplesched03/Makefile
diff --git a/testsuites/sptests/spsemaphore01/Makefile.am b/testsuites/sptests/spsemaphore01/Makefile.am
new file mode 100644
index 0000000..c3638ba
--- /dev/null
+++ b/testsuites/sptests/spsemaphore01/Makefile.am
@@ -0,0 +1,21 @@
+rtems_tests_PROGRAMS = spsemaphore
+spsemaphore_SOURCES = init.c
+dist_rtems_tests_DATA = spsemaphore.scn
+dist_rtems_tests_DATA += spsemaphore.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(spsemaphore_OBJECTS)
+LINK_LIBS = $(spsemaphore_LDLIBS)
+spsemaphore$(EXEEXT): $(spsemaphore_OBJECTS) $(spsemaphore_DEPENDENCIES)
+ @rm -f spsemaphore$(EXEEXT)
+ $(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/spsemaphore01/init.c b/testsuites/sptests/spsemaphore01/init.c
index 0000000..2f38baf
--- /dev/null
+++ b/testsuites/sptests/spsemaphore01/init.c
@@ -0,0 +1,155 @@
+ * Copyright (c) 2013 Gedare Bloom.
+ * http://www.rtems.com/license/LICENSE.
+#include <rtems.h>
+#include <stdio.h>
+#include "tmacros.h"
+/* configuration information */
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_EXTRA_TASK_STACKS (RTEMS_MINIMUM_STACK_SIZE * 3)
+#define CONFIGURE_MAXIMUM_TASKS 3
+#define CONFIGURE_MAXIMUM_SEMAPHORES 2
+#define CONFIGURE_INIT
+#include <rtems/confdefs.h>
+rtems_task Task01(rtems_task_argument ignored);
+rtems_task Task02(rtems_task_argument ignored);
+rtems_task Init(rtems_task_argument ignored);
+static int getprio(void)
+ rtems_status_code status;
+ rtems_task_priority pri;
+ status = rtems_task_set_priority(RTEMS_SELF, RTEMS_CURRENT_PRIORITY, &pri);
+ directive_failed( status, "rtems_task_set_priority");
+ return (int)pri;
+rtems_id Task_id[2];
+rtems_name Task_name[2];
+rtems_id sem_id[2];
+rtems_name sem_name[2];
+ rtems_attribute sem_attr;
+ printf("\n*** TEST SEMAPHORE01 ***\n");
+ sem_attr = RTEMS_INHERIT_PRIORITY | RTEMS_BINARY_SEMAPHORE | RTEMS_PRIORITY;
+ sem_name[0] = rtems_build_name( 'S','0',' ',' ');
+ status = rtems_semaphore_create(
+ sem_name[0],
+ 1,
+ sem_attr,
+ 0,
+ &sem_id[0]
+ directive_failed( status, "rtems_semaphore_create of S0");
+ printf("init: S0 created\n");
+ sem_name[1] = rtems_build_name( 'S','1',' ',' ');
+ sem_name[1],
+ 1,
+ sem_attr,
+ 0,
+ &sem_id[1]
+ directive_failed( status, "rtems_semaphore_create of S1");
+ printf("init: S1 created\n");
+ Task_name[0] = rtems_build_name( 'T','A','0','1');
+ status = rtems_task_create(
+ Task_name[0],
+ 36,
+ RTEMS_MINIMUM_STACK_SIZE*2,
+ RTEMS_DEFAULT_MODES,
+ RTEMS_DEFAULT_ATTRIBUTES,
+ &Task_id[0]
+ directive_failed( status, "rtems_task_create of TA01");
+ printf("init: TA01 created with priority 36\n");
+ Task_name[1] = rtems_build_name( 'T','A','0','2');
+ Task_name[1],
+ 34,
+ &Task_id[1]
+ directive_failed( status , "rtems_task_create of TA02\n");
+ printf("init: TA02 created with priority 34\n");
+ status = rtems_task_start( Task_id[0], Task01, 0);
+ directive_failed( status, "rtems_task_start of TA01");
+ status = rtems_task_delete( RTEMS_SELF);
+ directive_failed( status, "rtems_task_delete of INIT");
+/* Task01 starts with priority 36 */
+ printf("TA01: priority %d\n", getprio());
+ status = rtems_semaphore_obtain( sem_id[0], RTEMS_WAIT, 0 );
+ directive_failed( status, "rtems_semaphore_obtain of S0\n");
+ printf("TA01: priority %d, holding S0\n", getprio());
+ status = rtems_semaphore_obtain( sem_id[1], RTEMS_WAIT, 0 );
+ directive_failed( status, "rtems_semaphore_obtain of S1");
+ printf("TA01: priority %d, holding S0, S1\n", getprio());
+ /* Start Task 2 (TA02) with priority 34. It will run immediately. */
+ status = rtems_task_start( Task_id[1], Task02, 0);
+ directive_failed( status, "rtems_task_start of TA02\n");
+ status = rtems_semaphore_release(sem_id[1]);
+ directive_failed( status, "rtems_semaphore_release of S1\n");
+ status = rtems_semaphore_release(sem_id[0]);
+ directive_failed( status, "rtems_semaphore_release of S0\n");
+ printf("TA01: exiting\n");
+ printf("*** END OF SEMAPHORE01 ***\n");
+ directive_failed( status, "rtems_task_delete TA01");
+/* TA02 starts at Task02 with priority 34 */
+ printf("TA02: priority %d\n", getprio());
+ /* Obtain S1, which should be held by TA01 by now */
+ directive_failed( status, " rtems_semaphore_obtain S1");
+ printf("TA02: priority %d, holding S1\n", getprio());
+ printf("TA02: exiting\n");
+ directive_failed( status, "rtems_task_delete TA02");
diff --git a/testsuites/sptests/spsemaphore01/spsemaphore.doc b/testsuites/sptests/spsemaphore01/spsemaphore.doc
index 0000000..8b13789
--- /dev/null
+++ b/testsuites/sptests/spsemaphore01/spsemaphore.doc
@@ -0,0 +1 @@
diff --git a/testsuites/sptests/spsemaphore01/spsemaphore.scn b/testsuites/sptests/spsemaphore01/spsemaphore.scn
index 0000000..977af61
--- /dev/null
+++ b/testsuites/sptests/spsemaphore01/spsemaphore.scn
@@ -0,0 +1,15 @@
+*** TEST SEMAPHORE01 ***
+init: S0 created
+init: S1 created
+init: TA01 created with priority 36
+init: TA02 created with priority 34
+TA01: priority 36
+TA01: priority 36, holding S0
+TA01: priority 36, holding S0, S1
+TA02: priority 34
+TA02: priority 34, holding S1
+TA02: exiting
+TA01: priority 34, holding S0
+TA01: priority 36
+TA01: exiting
+*** END OF SEMAPHORE01 ***
1.7.1
