[PATCH 11/11] smp: Move secondary CPU initialization request
Tue May 28 07:28:02 UTC 2013
On 05/27/2013 06:12 PM, Joel Sherrill wrote:
> Are you sure it was a scheduling bug and not a dispatch disable nesting problem? If the count does not go back to zero, then a blocked thread will continue to execute.
Yes, I am sure that it is a scheduling bug.  I reach a state in which the
executing task is not ready after the dispatch loop in _Thread_Dispatch().
> If it is a bug I would like to know the detailed scenario so I can reproduce it in the simulator.
The bug can be reproduced with smptests/smp08 on Qemu.
After the current patch set review and integration I will propose a new
spinlock API.  After that I am ready to commit the ARM SMP support with the
existing scheduler.  We can then look this problem more closely.
I have a working alternative simple scheduler.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
