Changes in rtems-testing to run pc386 smp tests
Wed May 29 12:37:56 UTC 2013
So add a parameter that implicitly turns on SMP when ncores is specified >1?
On Tue, May 28, 2013 at 11:55 PM, Joel Sherrill
<Joel.Sherrill at oarcorp.com> wrote:
> I am still in a car riding home from a long birthday weekend road trip.. But
> I have been thinking it would make sense to add a command line option for
> number of cores. If a simulator supports it, then it can turn on the
> appropriate options. This would be similar to how coverage and graphics can
> be ignored when a simulator doesn't support it.
> Sree Harsha Konduri <sreehars at buffalo.edu> wrote:
> Hello,
> The following changes are to be made to the pc386 script in rtems-testing in
> order to run pc386 SMP tests in qemu.
>  > $RTEMS_TESTING/sim-scripts/pc386.in needs to be changed as follows
> -cpu 486 needs to be changed to core2duo and also a new option -smp
> <number_of_cores> needs to be added and
> then make to regenerate the pc386 script.
> Then running $RTEMS_TESTING/sim-scripts/pc386 -i <filepath> will run the
> scripts.
> Thanks,
> Sree harsha Konduri
> rtems-devel mailing list
> rtems-devel at rtems.org
