[PATCH 4/4] smptests/smplock01: New test
Wed May 29 15:31:09 UTC 2013
 testsuites/smptests/Makefile.am             |    1 +
 testsuites/smptests/configure.ac            |    1 +
 testsuites/smptests/smplock01/Makefile.am   |   19 ++
 testsuites/smptests/smplock01/init.c        |  405 +++++++++++++++++++++++++++
 testsuites/smptests/smplock01/smplock01.doc |   15 +
 testsuites/smptests/smplock01/smplock01.scn |   22 ++
 6 files changed, 463 insertions(+), 0 deletions(-)
 create mode 100644 testsuites/smptests/smplock01/Makefile.am
 create mode 100644 testsuites/smptests/smplock01/init.c
 create mode 100644 testsuites/smptests/smplock01/smplock01.doc
 create mode 100644 testsuites/smptests/smplock01/smplock01.scn
diff --git a/testsuites/smptests/Makefile.am b/testsuites/smptests/Makefile.am
index 7fc0066..70e1000 100644
--- a/testsuites/smptests/Makefile.am
+++ b/testsuites/smptests/Makefile.am
@@ -19,6 +19,7 @@ SUBDIRS += smpatomic04
 SUBDIRS += smpatomic05
 SUBDIRS += smpatomic06
 SUBDIRS += smpatomic07
+SUBDIRS += smplock01
 endif
 include $(top_srcdir)/../automake/subdirs.am
diff --git a/testsuites/smptests/configure.ac b/testsuites/smptests/configure.ac
index 89af868..6a2a443 100644
--- a/testsuites/smptests/configure.ac
+++ b/testsuites/smptests/configure.ac
@@ -48,5 +48,6 @@ smpatomic04/Makefile
 smpatomic05/Makefile
 smpatomic06/Makefile
 smpatomic07/Makefile
+smplock01/Makefile
 AC_OUTPUT
diff --git a/testsuites/smptests/smplock01/Makefile.am b/testsuites/smptests/smplock01/Makefile.am
new file mode 100644
index 0000000..05bffe6
--- /dev/null
+++ b/testsuites/smptests/smplock01/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = smplock01
+smplock01_SOURCES = init.c
+dist_rtems_tests_DATA = smplock01.scn smplock01.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(smplock01_OBJECTS)
+LINK_LIBS = $(smplock01_LDLIBS)
+smplock01$(EXEEXT): $(smplock01_OBJECTS) $(smplock01_DEPENDENCIES)
+	@rm -f smplock01$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/smptests/smplock01/init.c b/testsuites/smptests/smplock01/init.c
index 0000000..88ef985
--- /dev/null
+++ b/testsuites/smptests/smplock01/init.c
@@ -0,0 +1,405 @@
+ * Copyright (c) 2013 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#ifdef HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include <rtems.h>
+#include "tmacros.h"
+/* FIXME: Use C11 for atomic operations */
+static void atomic_store(int *addr, int value)
+  *addr = value;
+  RTEMS_COMPILER_MEMORY_BARRIER();
+static unsigned int atomic_load(const int *addr)
+  return *addr;
+/* FIXME: Add barrier to Score */
+typedef struct {
+	int value;
+	int sense;
+  SMP_lock_Control lock;
+} barrier_control;
+typedef struct {
+	int sense;
+} barrier_state;
+#define BARRIER_CONTROL_INITIALIZER { 0, 0, SMP_LOCK_INITIALIZER }
+#define BARRIER_STATE_INITIALIZER { 0 }
+static void barrier_wait(
+  barrier_control *control,
+  barrier_state *state,
+  int cpu_count
+  int sense = ~state->sense;
+  int value;
+  state->sense = sense;
+  _SMP_lock_Acquire(&control->lock);
+  value = control->value;
+  ++value;
+  control->value = value;
+  _SMP_lock_Release(&control->lock);
+  if (value == cpu_count) {
+    atomic_store(&control->value, 0);
+    atomic_store(&control->sense, sense);
+  while (atomic_load(&control->sense) != sense) {
+    /* Wait */
+#define TASK_PRIORITY 1
+#define CPU_COUNT 32
+#define TEST_COUNT 5
+typedef enum {
+  INITIAL,
+  START_TEST,
+  STOP_TEST
+} states;
+typedef struct {
+  int state;
+  barrier_control barrier;
+  rtems_id timer_id;
+  rtems_interval timeout;
+  unsigned long counter[TEST_COUNT];
+  unsigned long test_counter[TEST_COUNT][CPU_COUNT];
+} global_context;
+static global_context context = {
+  .state = INITIAL,
+  .barrier = BARRIER_CONTROL_INITIALIZER,
+  .lock = SMP_LOCK_INITIALIZER
+static const char *test_names[TEST_COUNT] = {
+  "aquire global lock with local counter",
+  "aquire global lock with global counter",
+  "aquire local lock with local counter",
+  "aquire local lock with global counter",
+  "aquire global lock with busy section"
+static void stop_test_timer(rtems_id timer_id, void *arg)
+  global_context *ctx = arg;
+  atomic_store(&ctx->state, STOP_TEST);
+static void wait_for_state(global_context *ctx, int desired_state)
+  while (atomic_load(&ctx->state) != desired_state) {
+    /* Wait */
+static bool assert_state(global_context *ctx, int desired_state)
+  return atomic_load(&ctx->state) == desired_state;
+typedef void (*test_body)(
+  int test,
+  global_context *ctx,
+  barrier_state *bs,
+  int cpu_count,
+  int cpu_self
+static void test_0_body(
+  int test,
+  int cpu_count,
+  int cpu_self
+  unsigned long counter = 0;
+  while (assert_state(ctx, START_TEST)) {
+    _SMP_lock_Acquire(&ctx->lock);
+    _SMP_lock_Release(&ctx->lock);
+    ++counter;
+  ctx->test_counter[test][cpu_self] = counter;
+static void test_1_body(
+  int test,
+  int cpu_count,
+  int cpu_self
+    ++ctx->counter[test];
+    ++counter;
+static void test_2_body(
+  int test,
+  int cpu_count,
+  int cpu_self
+  SMP_lock_Control lock = SMP_LOCK_INITIALIZER;
+    _SMP_lock_Acquire(&lock);
+    _SMP_lock_Release(&lock);
+    ++counter;
+static void test_3_body(
+  int test,
+  int cpu_count,
+  int cpu_self
+    /* The counter value is not interesting, only the access to it */
+    ++counter;
+static void busy_section(void)
+  int i;
+  for (i = 0; i < 101; ++i) {
+static void test_4_body(
+  int test,
+  int cpu_count,
+  int cpu_self
+    busy_section();
+    ++counter;
+static const test_body test_bodies[TEST_COUNT] = {
+  test_0_body,
+  test_1_body,
+  test_2_body,
+  test_3_body,
+  test_4_body
+static void run_tests(
+  int cpu_count,
+  int cpu_self,
+  bool master
+  int test;
+  for (test = 0; test < TEST_COUNT; ++test) {
+    barrier_wait(&ctx->barrier, bs, cpu_count);
+    if (master) {
+      rtems_status_code sc = rtems_timer_fire_after(
+        ctx->timer_id,
+        ctx->timeout,
+        stop_test_timer,
+        ctx
+      rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+      atomic_store(&ctx->state, START_TEST);
+    wait_for_state(ctx, START_TEST);
+    (*test_bodies[test])(test, ctx, bs, cpu_count, cpu_self);
+static void task(rtems_task_argument arg)
+  global_context *ctx = (global_context *) arg;
+  int cpu_count = (int) rtems_smp_get_number_of_processors();
+  int cpu_self = rtems_smp_get_current_processor();
+  rtems_status_code sc;
+  barrier_state bs = BARRIER_STATE_INITIALIZER;
+  run_tests(ctx, &bs, cpu_count, cpu_self, false);
+  sc = rtems_task_suspend(RTEMS_SELF);
+static void test(void)
+  global_context *ctx = &context;
+  int cpu;
+  int test;
+  for (cpu = 0; cpu < cpu_count; ++cpu) {
+    if (cpu != cpu_self) {
+      rtems_id task_id;
+      sc = rtems_task_create(
+        rtems_build_name('T', 'A', 'S', 'K'),
+        TASK_PRIORITY,
+        RTEMS_MINIMUM_STACK_SIZE,
+        RTEMS_DEFAULT_MODES,
+        RTEMS_DEFAULT_ATTRIBUTES,
+        &task_id
+      sc = rtems_task_start(task_id, task, (rtems_task_argument) ctx);
+  ctx->timeout = 10 * rtems_clock_get_ticks_per_second();
+  sc = rtems_timer_create(rtems_build_name('T', 'I', 'M', 'R'), &ctx->timer_id);
+  run_tests(ctx, &bs, cpu_count, cpu_self, true);
+    unsigned long sum = 0;
+    printf("%s\n", test_names[test]);
+      unsigned long local_counter = ctx->test_counter[test][cpu];
+      sum += local_counter;
+      printf(
+        "\tprocessor %i, local counter %lu\n",
+        cpu,
+        local_counter
+    printf(
+      "\tglobal counter %lu, sum of local counter %lu\n",
+      ctx->counter[test],
+      sum
+static void Init(rtems_task_argument arg)
+  puts("\n\n*** TEST SMPLOCK 1 ***");
+  test();
+  puts("*** END OF TEST SMPLOCK 1 ***");
+  rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_SMP_APPLICATION
+#define CONFIGURE_SMP_MAXIMUM_PROCESSORS CPU_COUNT
+#define CONFIGURE_MAXIMUM_TASKS CPU_COUNT
+#define CONFIGURE_MAXIMUM_SEMAPHORES 1
+#define CONFIGURE_MAXIMUM_TIMERS 1
+#define CONFIGURE_INIT_TASK_PRIORITY TASK_PRIORITY
+#define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES
+#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_DEFAULT_ATTRIBUTES
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/smptests/smplock01/smplock01.doc b/testsuites/smptests/smplock01/smplock01.doc
index 0000000..32f0a3a
--- /dev/null
+++ b/testsuites/smptests/smplock01/smplock01.doc
@@ -0,0 +1,15 @@
+This file describes the directives and concepts tested by this test set.
+test set name: smplock01
+The screen file was obtained on a PowerPC QorIQ P1020E target running with a
+processor frequency of 800MHz.
+directives:
+  - _SMP_lock_Acquire()
+  - _SMP_lock_Release()
+concepts:
+  - Benchmark the SMP lock implementation
diff --git a/testsuites/smptests/smplock01/smplock01.scn b/testsuites/smptests/smplock01/smplock01.scn
index 0000000..4d995fb
--- /dev/null
+++ b/testsuites/smptests/smplock01/smplock01.scn
@@ -0,0 +1,22 @@
+*** TEST SMPLOCK 1 ***
+aquire global lock with local counter
+        processor 0, local counter 15964
+        processor 1, local counter 99982377
+        global counter 0, sum of local counter 99998341
+aquire global lock with global counter
+        processor 0, local counter 166073
+        processor 1, local counter 99569103
+        global counter 99735176, sum of local counter 99735176
+aquire local lock with local counter
+        processor 0, local counter 148133948
+        processor 1, local counter 148148108
+        global counter 0, sum of local counter 296282056
+aquire local lock with global counter
+        processor 0, local counter 55938783
+        processor 1, local counter 55951781
+        global counter 55951781, sum of local counter 111890564
+aquire global lock with busy section
+        processor 0, local counter 10694328
+        processor 1, local counter 10694346
+        global counter 0, sum of local counter 21388674
+*** END OF TEST SMPLOCK 1 ***
1.7.7
