[PATCH 2/4] score: Remove idle field of Per_CPU_Control
Wed May 29 20:08:58 UTC 2013
On 29/05/13 21:56, Joel Sherrill wrote:
> On 5/29/2013 2:35 PM, Sebastian Huber wrote:
>> On 29/05/13 21:14, Joel Sherrill wrote:
>>> I think the use of _Objects_Name_to_id_u32 should be
>>> calling rtems_task_ident.
>> The problem is that the idle threads are not RTEMS tasks.  You cannot
>> find them with rtems_task_ident().
> That's right. :(
> It is still a violation of the layering. I wonder if we need a helper.
Using _Thread_Idle was also a violation, so nothing changes in this respect.
> And the fast idle trick is also violating the layering. Grrr...
> Also in a multi-core system, all the IDLE threads have the same name.
> So you don't know which one you are getting. Is this OK based on
> your test change?
This is a single processor test.  On SMP this test is invalid.
> FWIW it is not ok to have no tasks in the ready set.
Yes, the cardinality of the ready set must be greater than or equal to
the processor count.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
