[PATCH 2/9] fsdosfsname01: New test
Ralf Kirchner ralf.kirchner at embedded-brains.de
Fri May 31 13:42:18 UTC 2013
Test handling of file names and directory names according to Microsofts
specification for the FAT file system. So far tested only for the
default character set (code page 850).
 testsuites/fstests/Makefile.am                     |    1 +
 testsuites/fstests/configure.ac                    |    1 +
 testsuites/fstests/fsdosfsname01/Makefile.am       |   33 +
 testsuites/fstests/fsdosfsname01/fsdosfsname01.doc |   18 +
 testsuites/fstests/fsdosfsname01/fsdosfsname01.scn |    2 +
 testsuites/fstests/fsdosfsname01/init.c            |  635 ++++++++++++++++++++
 6 Dateien geändert, 690 Zeilen hinzugefügt(+)
 create mode 100644 testsuites/fstests/fsdosfsname01/Makefile.am
 create mode 100644 testsuites/fstests/fsdosfsname01/fsdosfsname01.doc
 create mode 100644 testsuites/fstests/fsdosfsname01/fsdosfsname01.scn
 create mode 100644 testsuites/fstests/fsdosfsname01/init.c
diff --git a/testsuites/fstests/Makefile.am b/testsuites/fstests/Makefile.am
index f39055e..068bbd4 100644
--- a/testsuites/fstests/Makefile.am
+++ b/testsuites/fstests/Makefile.am
@@ -1,6 +1,7 @@
 ACLOCAL_AMFLAGS = -I ../aclocal
 SUBDIRS =
+SUBDIRS += fsdosfsname01
 SUBDIRS += fsdosfswrite01
 SUBDIRS += fsdosfsformat01
 SUBDIRS += fsfseeko01
diff --git a/testsuites/fstests/configure.ac b/testsuites/fstests/configure.ac
index 8985464..ec98454 100644
--- a/testsuites/fstests/configure.ac
+++ b/testsuites/fstests/configure.ac
@@ -77,6 +77,7 @@ AC_CHECK_SIZEOF([blkcnt_t])
 # Explicitly list all Makefiles here
 AC_CONFIG_FILES([Makefile
+fsdosfsname01/Makefile
 fsdosfswrite01/Makefile
 fsdosfsformat01/Makefile
 fsfseeko01/Makefile
diff --git a/testsuites/fstests/fsdosfsname01/Makefile.am b/testsuites/fstests/fsdosfsname01/Makefile.am
new file mode 100644
index 0000000..623f0e5
--- /dev/null
+++ b/testsuites/fstests/fsdosfsname01/Makefile.am
@@ -0,0 +1,33 @@
+rtems_tests_PROGRAMS = fsdosfsname01
+fsdosfsname01_SOURCES = init.c \
+  ../support/ramdisk_support.c
+#  ../mdosfs_support/fs_support.c
+#  ../support/fstest_support.h
+#  ../support/ramdisk_support.h
+dist_rtems_tests_DATA = fsdosfsname01.scn fsdosfsname01.doc
+#old_path = $(PATH)
+#export PATH:=/scratch/install-gcc-4.6.3/bin:$(old_path)
+#export PATH:=/scratch/install-gcc-4.6.3/bin:$(PATH)
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+AM_CPPFLAGS += -I$(top_srcdir)/support
+#AM_CPPFLAGS += -I$(top_srcdir)/../psxtests/include
+LINK_OBJS = $(fsdosfsname01_OBJECTS)
+LINK_LIBS = $(fsdosfsname01_LDLIBS)
+fsdosfsname01$(EXEEXT): $(fsdosfsname01_OBJECTS) $(fsdosfsname01_DEPENDENCIES)
+	@echo old_path=$(old_path)
+	@echo PATH=$(PATH)
+	@rm -f fsdosfsname01$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/fstests/fsdosfsname01/fsdosfsname01.doc b/testsuites/fstests/fsdosfsname01/fsdosfsname01.doc
index 0000000..adf11d3
--- /dev/null
+++ b/testsuites/fstests/fsdosfsname01/fsdosfsname01.doc
@@ -0,0 +1,18 @@
+This file describes the directives and concepts tested by this test set.
+test set name: fsdosfsname01
+directives:
+- close ()
+- closedir ()
+- mkdir ()
+- mount ()
+- open ()
+- opendir ()
+- readdir ()
+- remove ()
+- rmdir ()
+- unlink ()
+concepts:
+- Make sure short file- and directory names and long file- and directory names are handled correctly for the default character set (code page 850)
diff --git a/testsuites/fstests/fsdosfsname01/fsdosfsname01.scn b/testsuites/fstests/fsdosfsname01/fsdosfsname01.scn
index 0000000..218ddf9
--- /dev/null
+++ b/testsuites/fstests/fsdosfsname01/fsdosfsname01.scn
@@ -0,0 +1,2 @@
+*** TEST fsdosfsname01 ***
+*** END OF TEST fsdosfsname01 ***
diff --git a/testsuites/fstests/fsdosfsname01/init.c b/testsuites/fstests/fsdosfsname01/init.c
index 0000000..260d955
--- /dev/null
+++ b/testsuites/fstests/fsdosfsname01/init.c
@@ -0,0 +1,635 @@
+ * Copyright (c) 2012, 2013 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#ifdef HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include "tmacros.h"
+#include <fcntl.h>
+#include <dirent.h>
+#include <bsp.h>
+#include <rtems/io.h>
+#include <rtems/libio.h>
+#include <rtems/dosfs.h>
+#include <rtems/ramdisk.h>
+#include <rtems/libcsupport.h>
+#include "ramdisk_support.h"
+#define MOUNT_DIR "/mnt"
+#define MOUNT_DIR_SIZE 4
+#define START_DIR_SIZE 4
+#define NUMBER_OF_DIRECTORIES 8
+#define NUMBER_OF_FILES 13
+#define NUMBER_OF_DIRECTORIES_INVALID 18
+#define NUMBER_OF_DIRECTORIES_DUPLICATED 2
+#define NUMBER_OF_FILES_DUPLICATED 2
+#define MAX_NAME_LENGTH ( 255 + 1 )
+#define MAX_NAME_LENGTH_INVALID ( 255 + 2 )
+#define MAX_DUPLICATES_PER_NAME 3
+#define BLOCK_SIZE 512
+#define BLOCK_COUNT ( sizeof( image_bin ) / BLOCK_SIZE )
+static rtems_resource_snapshot            before_mount;
+static const msdos_format_request_param_t rqdata = {
+  .OEMName             = "RTEMS",
+  .VolLabel            = "RTEMSDisk",
+  .sectors_per_cluster = 2,
+  .fat_num             = 0,
+  .files_per_root_dir  = 0,
+  .media               = 0,
+  .quick_format        = true,
+  .skip_alignment      = 0,
+  .info_level          = 0
+static const char                         DIRECTORY_NAMES[NUMBER_OF_DIRECTORIES]
+[MAX_NAME_LENGTH] = {
+  "a dir",
+  "Shortdir",
+  "shrtdir",
+  "shrt.dir",
+  "long_conventional_dir",
+  "long_conventional.dir",
+  "LongConventionalDir",
+  "This is a directory name with with 255 characters. The following numbers are aligned in that way, that the character 0 is the mentioned one. xxxxxx150xxxxxxx160xxxxxxx170xxxxxxx180xxxxxxx190xxxxxxx200xxxxxxx210xxxxxxx220xxxxxxx230xxxxxxx240xxxxxxx250xxxxx"
+static const char DIRECTORY_NAMES_INVALID[
+  NUMBER_OF_DIRECTORIES_INVALID][MAX_NAME_LENGTH_INVALID] = {
+  "This is a directory name with with 256 characters. The following numbers are aligned in that way, that the character 0 is the mentioned one. xxxxxx150xxxxxxx160xxxxxxx170xxxxxxx180xxxxxxx190xxxxxxx200xxxxxxx210xxxxxxx220xxxxxxx230xxxxxxx240xxxxxxx250xxxxxx",
+  { 0, 1, 2, 3, 4, 5, 6, 7, 8, 9,
+    10, 11, 12, 13, 14, 15, 16, 17, 18, 19,
+    20, 21, 22, 23, 24, 25, 26, 17, 28, 29, 30, 31},
+  {127}
+static const char FILE_NAMES[NUMBER_OF_FILES][
+  MAX_NAME_LENGTH] = {
+  "a file",
+  "shrtfile",
+  "ShrtFle",
+  "The quick brown.fox",
+  "long_conventional_file",
+  "This is a filename with with 255 characters. The following numbers are aligned in that way, that the character 0 is the mentioned one. xx140xxxxxxx150xxxxxxx160xxxxxxx170xxxxxxx180xxxxxxx190xxxxxxx200xxxxxxx210xxxxxxx220xxxxxxx230xxxxxxx240xxxxxxx250xxxxx",
+  "a.a",
+typedef struct {
+  char name[MAX_NAME_LENGTH];
+  unsigned int number_of_duplicates;
+  char name_duplicates[MAX_DUPLICATES_PER_NAME][MAX_NAME_LENGTH];
+} name_duplicates;
+static const name_duplicates DIRECTORY_DUPLICATES[
+  NUMBER_OF_DIRECTORIES_DUPLICATED] = {
+    "shrtdir",
+    3,
+      "shrtdir",
+      "SHRTDIR",
+      "Shrtdir"
+    3,
+      "LONG_CONVENTIONAL_DIR",
+      "Long_conventional_dir"
+static const name_duplicates MULTIBYTE_DUPLICATES[
+  NUMBER_OF_MULTIBYTE_NAMES_DUPLICATED] = {
+    /* The angstroem encoded differently. These encodings might become short entries */
+    {0xc3, 0x85}, /* '̊A' */
+    2,
+      {0xe2, 0x84, 0xab} /* 'Å' */
+  /* Again the angstroem encoded differently,
+   * but this time with additional characters in order to enforce a long entry. */
+    {'1', '2', '3', '4', '5', '6', '7', '8', '9', '0', '1', '2', '3', 0xc3,
+     0x85},
+    2,
+       0x85},
+      {'1', '2', '3', '4', '5', '6', '7', '8', '9', '0', '1', '2', '3', 0xe2,
+       0x84, 0xab}
+static const name_duplicates FILES_DUPLICATES[NUMBER_OF_FILES_DUPLICATED] = {
+    "shrtfile",
+    3,
+      "shrtfile",
+      "SHRTFILE",
+      "Shrtfile"
+    3,
+      "LONG_CONVENTIONAL_FILE",
+      "Long_conventional_file"
+static int path_is_directory( const char *path )
+  struct stat s_buf;
+  if ( stat( path, &s_buf ) )
+    return 0;
+  return S_ISDIR( s_buf.st_mode );
+static void delete_folder_tree( const char *directory_name )
+  DIR           *dp;
+  struct dirent *ep;
+  char           p_buf[1024] = {0};
+  int            rc          = 0;
+  dp = opendir( directory_name );
+  rtems_test_assert( dp != NULL );
+  while ( ( ep = readdir( dp ) ) != NULL && rc == 0 ) {
+    if ( 0 != strcmp( ".", ep->d_name )
+         && 0 != strcmp( "..", ep->d_name ) ) {
+      snprintf( p_buf, sizeof( p_buf ), "%s/%s", directory_name, ep->d_name );
+      if ( path_is_directory( p_buf ) ) {
+        delete_folder_tree( p_buf );
+        rc = rmdir( p_buf );
+        rtems_test_assert( rc == 0 );
+        rewinddir( dp );
+      } else {
+        rc = unlink( p_buf );
+        rewinddir( dp );
+  rc = closedir( dp );
+static void mount_device( const char *start_dir,
+  const rtems_dosfs_mount_options    *mount_opts )
+  int rc;
+  rc = mount(
+    RAMDISK_PATH,
+    MOUNT_DIR,
+    "dosfs",
+    RTEMS_FILESYSTEM_READ_WRITE,
+    mount_opts );
+  if ( NULL == opendir( start_dir ) ) {
+    rc = mkdir( start_dir, S_IRWXU | S_IRWXG | S_IRWXO );
+static void mount_device_with_defaults( const char *start_dir )
+  int rc;
+  rc = msdos_format( RAMDISK_PATH, &rqdata );
+  rtems_resource_snapshot_take( &before_mount );
+  mount_device( start_dir, NULL );
+static void unmount_and_close_device( void )
+  int                     rc;
+  rtems_resource_snapshot now;
+  bool                    are_resources_freed;
+  delete_folder_tree( MOUNT_DIR );
+  rc = unmount( MOUNT_DIR );
+  are_resources_freed = rtems_resource_snapshot_check( &before_mount );
+  if ( !are_resources_freed )
+    rtems_resource_snapshot_take( &now );
+  rtems_test_assert( are_resources_freed );
+ * Simply create a few directories. These tests should all succeed
+static void test_creating_directories(
+  const char        *start_dir,
+  const char        *directories,
+  const unsigned int number_of_directories )
+  unsigned int   index;
+  int            rc;
+  char           dirname[MAX_NAME_LENGTH + strlen( start_dir ) + 1];
+  DIR           *dirp;
+  struct dirent *dp;
+  for ( index = 0; index < number_of_directories; ++index ) {
+    snprintf( dirname, sizeof( dirname ), "%s/%s", start_dir, directories
+              + ( index * MAX_NAME_LENGTH ) );
+    rc = mkdir( dirname, S_IRWXU | S_IRWXG | S_IRWXO );
+  dirp = opendir( start_dir );
+  rtems_test_assert( NULL != dirp );
+  index = 0;
+  dp    = readdir( dirp );
+  rtems_test_assert( 0 == strcmp( ".", dp->d_name ) );
+  rtems_test_assert( 0 == strcmp( "..", dp->d_name ) );
+  while ( dp != NULL ) {
+                       == strcmp( directories + ( index * MAX_NAME_LENGTH ),
+                                  dp->d_name ) );
+    ++index;
+  rtems_test_assert( number_of_directories == index );
+  rc = closedir( dirp );
+ * Try creating directories with invalid names.
+static void test_creating_invalid_directories( void )
+  int          rc;
+  char         dirname[MAX_NAME_LENGTH_INVALID + MOUNT_DIR_SIZE + 1];
+  for ( index = 0; index < NUMBER_OF_DIRECTORIES_INVALID; ++index ) {
+              sizeof( dirname ),
+              "%s/%s",
+              MOUNT_DIR,
+              DIRECTORY_NAMES_INVALID[index] );
+    rtems_test_assert( rc == -1 );
+ * Try creating directories which do already exist
+ * (although names may have different capitalization/encoding)
+static void test_creating_duplicate_directories(
+  const name_duplicates *duplicates,
+  const unsigned int     number_of_duplicates )
+  unsigned int index_dir;
+  unsigned int index_duplicate;
+  int          rc;
+  char         dirname[MAX_NAME_LENGTH + MOUNT_DIR_SIZE + START_DIR_SIZE + 2];
+  for ( index_dir = 0; index_dir < number_of_duplicates; ++index_dir ) {
+              duplicates[index_dir].name );
+    for ( index_duplicate = 0;
+          index_duplicate < duplicates[index_dir].number_of_duplicates;
+          ++index_duplicate ) {
+                duplicates[index_dir].name_duplicates[index_duplicate] );
+      rtems_test_assert( rc < 0 );
+ * Try creating and opening files with valid names
+static void test_handling_files(
+  const char        *dirname,
+  const char        *file_names,
+  const unsigned int number_of_files )
+  int          rc;
+  char         filename[MAX_NAME_LENGTH * 2 + MOUNT_DIR_SIZE + START_DIR_SIZE
+                        + 4];
+  int          fd;
+  for ( index = 0; index < number_of_files; ++index ) {
+    snprintf(
+      filename,
+      sizeof( filename ) - 1,
+      "%s/%s",
+      dirname,
+      file_names + index * MAX_NAME_LENGTH );
+    fd = open( filename,
+               O_RDWR | O_CREAT,
+               S_IRUSR | S_IWUSR | S_IRGRP | S_IWGRP | S_IROTH | S_IWOTH );
+    rtems_test_assert( fd >= 0 );
+    rc = close( fd );
+    /* See if the file still exists and can be found */
+    fd = open( filename, O_RDWR );
+    rc = close( fd );
+ * Try opening files which do already exist (with different capitalization in their names)
+static void test_duplicated_files( const char *dirname,
+  const name_duplicates                       *files_duplicated,
+  const unsigned int                           number_of_files_duplicated )
+  unsigned int index_file;
+  int          rc;
+  char         filename[MAX_NAME_LENGTH + strlen( dirname ) + 1];
+  int          fd;
+  for ( index_file = 0; index_file < number_of_files_duplicated;
+        ++index_file ) {
+    snprintf( filename,
+              "%s/%s",
+              dirname,
+              files_duplicated[index_file].name );
+               O_RDWR | O_CREAT,
+    rc = close( fd );
+          index_duplicate < files_duplicated[index_file].number_of_duplicates;
+                "%s/%s",
+                dirname,
+                files_duplicated[index_file].name_duplicates[index_duplicate] );
+      rc = close( fd );
+    rc = remove( filename );
+ * Open and read existing valid directories
+static void test_handling_directories(
+  const char        *directory_names,
+  const unsigned int number_of_directories,
+  unsigned int   index_directory;
+  int            rc;
+  DIR           *dir_stream;
+  char           dirname[MAX_NAME_LENGTH * 2];
+  for ( index_directory = 0;
+        index_directory < number_of_directories;
+        ++index_directory ) {
+    snprintf(
+      dirname,
+      sizeof( dirname ) - 1,
+      "%s/%s",
+      start_dir,
+      directory_names + index_directory * MAX_NAME_LENGTH );
+    test_handling_files(
+      dirname,
+      file_names,
+      number_of_files );
+    dir_stream = opendir( dirname );
+    rtems_test_assert( dir_stream != NULL );
+    dp = readdir( dir_stream );
+    index_file = 0;
+                           file_names + index_file * MAX_NAME_LENGTH,
+                           dp->d_name ) );
+      ++index_file;
+    rtems_test_assert( number_of_files == index_file );
+    rc = closedir( dir_stream );
+ * Main test method
+static void test( void )
+  int  rc;
+  char start_dir[MOUNT_DIR_SIZE + START_DIR_SIZE + 2];
+  rc = mkdir( MOUNT_DIR, S_IRWXU | S_IRWXG | S_IRWXO );
+  init_ramdisk();
+  snprintf( start_dir, sizeof( start_dir ), "%s/%s", MOUNT_DIR, "strt" );
+   * Tests with code page 850 compatible directory and file names
+   * and the code page 850 backwards compatible default mode mode of the
+   * FAT file system
+  mount_device_with_defaults( start_dir );
+  test_creating_duplicate_directories(
+    &start_dir[0],
+    &DIRECTORY_DUPLICATES[0],
+    NUMBER_OF_DIRECTORIES_DUPLICATED );
+  unmount_and_close_device();
+  test_duplicated_files(
+    MOUNT_DIR,
+    FILES_DUPLICATES,
+    NUMBER_OF_FILES_DUPLICATED );
+  test_creating_invalid_directories();
+  test_creating_directories(
+    &start_dir[0],
+    &DIRECTORY_NAMES[0][0],
+    NUMBER_OF_DIRECTORIES );
+  test_handling_directories(
+    &start_dir[0],
+    NUMBER_OF_DIRECTORIES,
+    &FILE_NAMES[0][0],
+    NUMBER_OF_FILES );
+  del_ramdisk();
+static void Init( rtems_task_argument arg )
+  puts( "\n\n*** TEST fsdosfsname01 ***" );
+  test();
+  puts( "*** END OF TEST fsdosfsname01 ***" );
+  rtems_test_exit( 0 );
+#define CONFIGURE_INIT_TASK_STACK_SIZE ( 1024 * 64 )
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_DRIVERS 4
+#define CONFIGURE_MAXIMUM_SEMAPHORES RTEMS_DOSFS_SEMAPHORES_PER_INSTANCE
+#define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
+#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
+#define CONFIGURE_FILESYSTEM_DOSFS
+/* 1 RAM disk device file + 1 mount_dir + stdin + stdout + stderr + 2 for open directories/files */
+#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS ( 5 + 2 )
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
1.7.10.4
